SOQuartz
The SOQuartz
The SOQuartz is a RK3566 based compute module and parts of Quartz64 series.
Software releases
The SOQuartz software releases can be found in the article SOQuartz Software Releases.
SoC and Memory Specification
  • Supports Vulkan 1.0 and 1.1
Neural Process Unit NPU Capability
  • RAM Memory Variants: 2GB, 4GB, 8GB LPDDR4.
  • Storage Memory: optional 128Mb SPI Flash and optional eMMC module from 16GB up to 128GB
Network
  • 10/100/1000Mbps Ethernet
  • WiFi 802.11 b/g/n/ac with Bluetooth 5.0
SOQuartz exposed peripherals
Displays / Cameras
  • 1x HDMI
  • 2x DSI
  • 1x eDP (Instead of HDMI1)
  • 1x LVDS (not available when dual-mode DSI)
  • 1x CSI 4-line
Connectivity
  • 1x Ethernet (1Gbit)
  • 1x USB 2.0 OTG
  • 1x SD Card (SD)
  • 1x PCIe 1-Line
  • 28x GPIO (TBD)
Connector Pins Definition
SOQuartz Model-A Baseboard Features
  • Model "A" Baseboard Dimensions: 133mm x 80mm x 19mm
  • Input Power: DC 12V @ 3A 5.5OD/2.1ID Barrel DC Jack connector
Storage
  • microSD - bootable, support SDHC and SDXC, storage up to 2TB
  • USB - 2 USB2.0 Host port
Expansion Ports
  • MiPi-CSI - 1x 2 lanes, 1x 4 lanes
  • MiPi-DSI - 1x 2 lanes, 1x 4 lanes
  • 2x20 pins "Pi2" GPIO Header
  • PCIe 1x open ended slot
SOQuartz Module and Baseboard Information, Schematics, and Certifications
  • SOQuartz Model "A" Baseboard Schematic and PCB Board Resource:
  • SOQuartz Blade Baseboard Schematic and PCB Board Resource:
SOQuartz BLADE Baseboard
SOQuartz BLADE 3D Print 1U half width server rack
SOQuartz BLADE 3D Print 1U full width server rack
SOQuartz Module with various CM4 carrier boards
SOQuartz with DF Robot CM4 Carrier Board
SOQuartz with Waveshare CM4 Carrier Board
SOQuartz with Waveshare CM4 PoE Board
BSP Linux SDK
BSP Linux SDK ver 4.19 for Quartz64 model A SBC
Android SDK
Android 11 SDK for Quartz64 model A SBC
Other Resources
