SOQuartz
Revision as of 03:17, 4 November 2021 by Tllim (talk | contribs)
The SOQuartz
The SOQuartz is a RK3566 based compute module and parts of Quartz64 series.
Software releases
The SOQuartz software releases can be found in the article SOQuartz Software Releases.
SoC and Memory Specification
  • Supports Vulkan 1.0 and 1.1
Neural Process Unit NPU Capability
  • RAM Memory Variants: 2GB, 4GB, 8GB LPDDR4.
  • Storage Memory: optional 128Mb SPI Flash and optional eMMC module from 16GB up to 128GB
Network
  • 10/100/1000Mbps Ethernet
  • WiFi 802.11 b/g/n/ac with Bluetooth 5.0
SOQuartz Model-A Baseboard Features
  • Model "A" Baseboard Dimensions: 133mm x 80mm x 19mm
  • Input Power: DC 12V @ 3A 5.5OD/2.1ID Barrel DC Jack connector
Storage
  • USB - 2 USB2.0 Host port
Expansion Ports
  • MiPi-CSI - 1x 2 lanes, 1x 4 lanes
  • MiPi-DSI - 1x 2 lanes, 1x 4 lanes
  • 2x20 pins "Pi2" GPIO Header
  • PCIe 1x open ended slot
SOQuartz Module and Baseboard Information, Schematics, and Certifications
BSP Linux SDK
BSP Linux SDK ver 4.19 for Quartz64 model A SBC
Android SDK
Android 11 SDK for Quartz64 model A SBC
Other Resources
