SOQuartz
Jump to navigation
Jump to search
The SOQuartz is a RK3566 based compute module and parts of Quartz64 series.
Software releases
The SOQuartz software releases can be found in the article SOQuartz Software Releases.
SoC and Memory Specification
- Based on Rockchip RK3566
- Quad-core ARM Cortex-A55@1.8GHz
- AArch32 for full backwards compatibility with ARMv7
- ARM Neon Advanced SIMD (single instruction, multiple data) support for accelerated media and signal processing computation
- Includes VFP hardware to support single and double-precision operations
- ARMv8 Cryptography Extensions
- Integrated 32KB L1 instruction cache and 32KB L1 data cache per core
- 512KB unified system L3 cache
- Mali-G52 2EE Bifrost GPU@800MHz
- 4x Multi-Sampling Anti-Aliasing (MSAA) with minimal performance drop
- 128KB L2 Cache configurations
- Supports OpenGL ES 1.1, 2.0, and 3.2
- Supports Vulkan 1.0 and 1.1
- Supports OpenCL 2.0 Full Profile
- Supports 1600 Mpix/s fill rate when at 800MHz clock frequency
- Supports 38.4 GLOP/s when at 800MHz clock frequency
Neural Process Unit NPU Capability
- Neural network acceleration engine with processing performance of up to 0.8 TOPS
- Supports integer 8 and integer 16 convolution operations
- Supports the following deep learning frameworks: TensorFlow, TF-lite, Pytorch, Caffe, ONNX, MXNet, Keras, Darknet
- RAM Memory Variants: 2GB, 4GB, 8GB LPDDR4.
- Storage Memory: optional 128Mb SPI Flash and optional eMMC module from 8GB up to 128GB
Network
- 10/100/1000Mbps Ethernet
- WiFi 802.11 b/g/n/ac with Bluetooth 5.0
SOQuartz exposed peripherals
Displays / Cameras
- 1x HDMI
- 2x DSI
- 1x eDP (Instead of HDMI1)
- 1x LVDS (not available when dual-mode DSI)
- 1x CSI 4-line
Connectivity
- 1x Ethernet (1Gbit)
- 1x USB 2.0 OTG
- 1x SD Card (SD)
- 1x PCIe 1-Line
- 28x GPIO (TBD)
Connector Pins Definition
SOQuartz Model-A Baseboard Features
- Model "A" Baseboard Dimensions: 133mm x 80mm x 19mm
- Input Power: DC 12V @ 3A 5.5OD/2.1ID (IEC 60130-10 Type A) Barrel DC Jack connector
Storage
- microSD - bootable, support SDHC and SDXC, storage up to 2TB
- USB - 2 USB2.0 Host port
Expansion Ports
- MiPi-CSI - 1x 2 lanes, 1x 4 lanes
- MiPi-DSI - 1x 2 lanes, 1x 4 lanes
- 2x20 pins "Pi2" GPIO Header
- PCIe 1x open ended slot
- 1x5 pin USB Expansion Header (J15)
GPIO Pins
Attention! GPIOs are 3.3V!
Interesting alternate pin configurations are listed in [brackets].
Assigned To | Pin no. | Pin no. | Assigned To |
3.3 V | 1 | 2 | 5 V |
[I2C2_SDA_M1] GPIO4_B4_3V3 a | 3 | 4 | 5 V |
[I2C2_SCL_M1] GPIO4_B5_3V3 a | 5 | 6 | GND |
[GPCLK0] GPIO4_A4_3V3 | 7 | 8 | GPIO0_D1_3V3 [UART2_TX_M0] |
GND | 9 | 10 | GPIO0_D0_3V3 [UART2_RX_M0] |
[I2S1_MCLK_M1] GPIO3_C6_3V3 | 11 | 12 | GPIO3_C7_3V3 [I2S1_SCLK_M1] |
GPIO4_A0_3V3 | 13 | 14 | GND |
GPIO4_A2_3V3 | 15 | 16 | GPIO4_A3_3V3 |
3.3V | 17 | 18 | GPIO4_A1_3V3 |
[SPI3_MOSI_M0] GPIO4_B2_3V3 | 19 | 20 | GND |
[SPI3_MISO_M0] GPIO4_B0_3V3 | 21 | 22 | GPIO4_B1_3V3 |
[SPI3_CLK_M0] GPIO4_B3_3V3 | 23 | 24 | GPIO4_A6_3V3 [SPI3_CS0_M0] |
GND | 25 | 26 | GPIO4_A7_3V3 [SPI3_CS1_M0] |
[I2C3_SDA_M0] GPIO1_A0_3V3 a | 27 | 28 | GPIO1_A1_3V3 [I2C3_SCL_M0] a |
GPIO3_A5_3V3 | 29 | 30 | GND |
GPIO3_D4_3V3 | 31 | 32 | GPIO3_D6_3V3 |
GPIO3_D7_3V3 | 33 | 34 | GND |
[I2S1_LRCK_M1] GPIO3_D0_3V3 | 35 | 36 | GPIO3_D5_3V3 |
GPIO3_D3_3V3 | 37 | 38 | GPIO3_D2_3V3 [I2S1_SDI_M1] |
GND | 39 | 40 | GPIO3_D1_3V3 [I2S1_SDO_M1] |
Notes
- pulled high to 3.3V through 2.2kOhm resistor
Source: Page 11 of the board schematics.
Pin no | Assigned To |
1 | USB2_HOST_5V |
2 | HOST_DM3 |
3 | HOST_DP3 |
4 | GND |
5 | GND |
Source: Page 10 of the board schematics.
SOQuartz BLADE Baseboard Features
- SOQuartz BLADE Baseboard Dimensions: 200mm x 40mm x 15mm
- Input Power:
- DC 5V @ 3A 3.5OD/1.35ID (IEC 60130-10 Type H) Barrel DC Jack connector
- PoE
Storage
- USB - USB2.0 Host port (with header for setting OTG ID pin)
Expansion Ports
- M.2 slot
- PWM fan header
Jumpers
- OTG ID jumper
- GPIO voltage, select 3.3V or 1.8V
- PoE Enable
SOQuartz Module and Baseboard Information, Schematics, and Certifications
- SOQuartz Module Schematic:
- SOQuartz Model "A" Baseboard Schematic and PCB Board Resource:
- SOQuartz Model-A baseboard 20220522 Schematic PDF file
- SOQuartz Model-A baseboard 20220522 Schematic DSN source file
- SOQuartz SOQuartz Model-A baseboard 20220522 PCB Top Component Placement
- SOQuartz SOQuartz Model-A baseboard 20220522 PCB Bottom Component Placement
- SOQuartz Model-A baseboard 20220522 PCB DSN file
- SOQuartz Model-A baseboard 20220522 PCB Gerber file
- SOQuartz Blade Baseboard Schematic and PCB Board Resource:
- Rockchip RK3566 SoC information:
- Rockchip PMU (Power Management Unit) Information:
- DDR4 information:
- eMMC information:
- SPI NOR Flash information:
- Ethernet PHY information:
- WiFi/BT module info:
- i2C to PWM Controller user in BLADE info:
- GP7101 i2c to PWM Controller Datasheet in Chinese
- GP7101 i2c to PWM Controller Datasheet translated to English by neggles File:GP7101 cn V1 qsxn en.pdf
- I2C address is 0x58 despite what datasheet says
- PoE DC/DC Controller user in BLADE info:
SOQuartz Module with various CM4 carrier boards
- For CM4 carrier board comprehensive list, please visit Jeff Geerling collection
BSP Linux SDK
BSP Linux SDK ver 4.19 for Quartz64 model A SBC
- Direct Download from pine64.org
- MD5 (TAR-GZip file): 24554419aec29700add97167a3a4c9ed
- File Size: 32.67.00GB
Android SDK
Android 11 SDK for Quartz64 model A SBC
- MD5 (TAR-GZip file): 77c2ff57ea3372fb04da7fb49e17d12b
- File Size: 79.00GB
- Just the boot blobs (<1MB): File:Rk35-blobs.tar.gz
