SOPine Pin Assignment Table
Revision as of 22:08, 28 October 2020 by Fxc (talk | contribs) (https)
This table contains Pin Assignment of SOPine Edge Finger. For more information about peripherals, GPIOs, powering look:
For Edge Finger view, look Edge Finger Pin Assignment Table
a PDF mapping the pins from the A64 chip itself, to the gold-fingers on the SO-DIMM edge, to the multiple connectors on the baseboard and on the clusterboard, attached to this forum post.
SOPine Pin SOPine Name Allwinner name Allwinner category Ball Type Description
1 HBIAS HBIAS AUDIO_CODEC D13 AO Master Analog Headphone Bias Voltage Output
2 EAROUT_P EAROUTP AUDIO_CODEC B13 AO Earpiece Amplifier Positive Differential Output
3 HPOUTL HPOUTL AUDIO_CODEC C13 AO Headphone Output Left Channel
4 EAROUT_N EAROUTN AUDIO_CODEC A13 AO Earpiece Amplifier Negative Differential Output
5 HPOUTR HPOUTR AUDIO_CODEC C12 AO Headphone Output Right Channel
6 HS-MIC MIC-DET AUDIO_CODEC B10 AI Headphone MIC Detect
7 GND GND POWER ? G
8 GND GND POWER ? G
9 MIC2N MICIN2N AUDIO_CODEC A17 AI Microphone Negative Input 2
10 HPOUTFB HP-FB AUDIO_CODEC C10 AI Headphone Common Reference Feedback Input
11 MIC2P MICIN2P AUDIO_CODEC B17 AI Microphone Positive Input 2
12 KEYADC KEYADC ADC A16 AI ADC input for key
13 GPIO363 PL11 GPIO PL11 GPIO General Purpose Input Output #363
14 GPIO356 PL4 GPIO PL4 GPIO General Purpose Input Output #356
15 GPIO360 PL8 GPIO PL8 GPIO General Purpose Input Output #360
16 GPIO358 PL6 GPIO PL6 GPIO General Purpose Input Output #358
17 GPIO361 PL9 GPIO PL9 GPIO General Purpose Input Output #361
18 GPIO357 PL5 GPIO PL5 GPIO General Purpose Input Output #357
19 GND GND POWER ? G
20 GND GND POWER ? G
21 GPIO354 PL2 GPIO PL2 GPIO General Purpose Input Output #354
22 HP-DET HP-DET AUDIO_CODEC D11 AI Headphone Detect
23 GPIO355 PL3 GPIO PL3 GPIO General Purpose Input Output #355
24 GPIO359 PL7 GPIO PL7 GPIO General Purpose Input Output #359
25 GPIO69 PC5 GPIO PC5 GPIO General Purpose Input Output #69
26 GPIO234 PH10 GPIO PH10 GPIO General Purpose Input Output #234
27 GPIO37 PB5 GPIO PB5 GPIO General Purpose Input Output #37
28 GPIO36 PB4 GPIO PB4 GPIO General Purpose Input Output #36
29 GPIO39 PB7 GPIO PB7 GPIO General Purpose Input Output #39
30 GPIO35 PB3 GPIO PB3 GPIO General Purpose Input Output #35
31 GND GND POWER ? G
32 GND GND POWER ? G
33 GPIO41 PB9 GPIO PB9 GPIO General Purpose Input Output #41
34 GPIO40 PB8 GPIO PB8 GPIO General Purpose Input Output #40
35 GPIO32 PB0 GPIO PB0 GPIO General Purpose Input Output #32
36 GPIO34 PB2 GPIO PB2 GPIO General Purpose Input Output #34
37 GPIO227 PH3 GPIO PH3 GPIO General Purpose Input Output #227
38 GPIO232 PH8 GPIO PH8 GPIO General Purpose Input Output #232
39 GPIO38 PB6 GPIO PB6 GPIO General Purpose Input Output #38
40 GPIO103 PD7 GPIO PD7 GPIO General Purpose Input Output #103
41 GND GND POWER ? G
42 GND GND POWER ? G
43 GPIO224 PH0 GPIO PH0 GPIO General Purpose Input Output #224
44 GPIO101 PD5 GPIO PD5 GPIO General Purpose Input Output #101
45 GPIO102 PD6 GPIO PD6 GPIO General Purpose Input Output #102
46 GPIO225 PH1 GPIO PH1 GPIO General Purpose Input Output #225
47 GPIO116 PD20 GPIO PD20 GPIO General Purpose Input Output #116
48 GPIO107 PD11 GPIO PD11 GPIO General Purpose Input Output #107
49 GPIO97 PD1 GPIO PD1 GPIO General Purpose Input Output #97
50 GPIO120 PD24 GPIO PD24 GPIO General Purpose Input Output #120
51 GPIO106 PD10 GPIO PD10 GPIO General Purpose Input Output #106
52 GPIO100 PD4 GPIO PD4 GPIO General Purpose Input Output #100
53 GPIO118 PD22 GPIO PD22 GPIO General Purpose Input Output #118
54 GPIO133 PE5 GPIO PE5 GPIO General Purpose Input Output #133
55 GND GND POWER ? G
56 GND GND POWER ? G
57 GPIO98 PD2 GPIO PD2 GPIO General Purpose Input Output #98
58 GPIO128 PE0 GPIO PE0 GPIO General Purpose Input Output #128
59 GPIO137 PE9 GPIO PE9 GPIO General Purpose Input Output #137
60 GPIO96 PD0 GPIO PD0 GPIO General Purpose Input Output #96
61 GPIO99 PD3 GPIO PD3 GPIO General Purpose Input Output #99
62 GPIO226 PH2 GPIO PH2 GPIO General Purpose Input Output #226
63 GPIO194 PG2 GPIO PG2 GPIO General Purpose Input Output #194
64 GPIO228 PH4 GPIO PH4 GPIO General Purpose Input Output #228
65 GPIO135 PE7 GPIO PE7 GPIO General Purpose Input Output #135
66 GPIO230 PH6 GPIO PH6 GPIO General Purpose Input Output #230
67 GPIO235 PH11 GPIO PH11 GPIO General Purpose Input Output #235
68 GPIO229 PH5 GPIO PH5 GPIO General Purpose Input Output #229
69 GND GND POWER ? G
70 GND GND POWER ? G
71 GPIO231 PH7 GPIO PH7 GPIO General Purpose Input Output #231
72 GPIO192 PG0 GPIO PG0 GPIO General Purpose Input Output #192
73 GPIO104 PD8 GPIO PD8 GPIO General Purpose Input Output #104
74 GPIO117 PD21 GPIO PD21 GPIO General Purpose Input Output #117
75 GPIO33 PB1 GPIO PB1 GPIO General Purpose Input Output #33
76 GPIO119 PD23 GPIO PD23 GPIO General Purpose Input Output #119
77 GPIO233 PH9 GPIO PH9 GPIO General Purpose Input Output #233
78 GPIO113 PD17 GPIO PD17 GPIO General Purpose Input Output #113
79 GPIO115 PD19 GPIO PD19 GPIO General Purpose Input Output #115
80 GPIO111 PD15 GPIO PD15 GPIO General Purpose Input Output #111
81 GND GND POWER ? G
82 GPIO112 PD16 GPIO PD16 GPIO General Purpose Input Output #112
83 GPIO105 PD9 GPIO PD9 GPIO General Purpose Input Output #105
84 GND GND POWER ? G
85 GPIO114 PD18 GPIO PD18 GPIO General Purpose Input Output #114
86 GPIO203 PG11 GPIO PG11 GPIO General Purpose Input Output #203
87 GPIO110 PD14 GPIO PD14 GPIO General Purpose Input Output #110
88 GPIO200 PG8 GPIO PG8 GPIO General Purpose Input Output #200
89 GPIO109 PD13 GPIO PD13 GPIO General Purpose Input Output #109
90 GPIO198 PG6 GPIO PG6 GPIO General Purpose Input Output #198
91 GPIO108 PD12 GPIO PD12 GPIO General Purpose Input Output #108
92 GPIO144 PE16 GPIO PE16 GPIO General Purpose Input Output #144
93 GND GND POWER ? G
94 GND GND POWER ? G
95 GPIO132 PE4 GPIO PE4 GPIO General Purpose Input Output #132
96 GPIO134 PE6 GPIO PE6 GPIO General Purpose Input Output #134
97 GPIO205 PG13 GPIO PG13 GPIO General Purpose Input Output #205
98 GPIO140 PE12 GPIO PE12 GPIO General Purpose Input Output #140
99 GPIO202 PG10 GPIO PG10 GPIO General Purpose Input Output #202
100 GPIO130 PE2 GPIO PE2 GPIO General Purpose Input Output #130
101 GPIO131 PE3 GPIO PE3 GPIO General Purpose Input Output #131
102 GPIO129 PE1 GPIO PE1 GPIO General Purpose Input Output #129
103 GND GND POWER ? G
104 GND GND POWER ? G
105 GPIO136 PE8 GPIO PE8 GPIO General Purpose Input Output #136
106 GPIO196 PG4 GPIO PG4 GPIO General Purpose Input Output #196
107 GPIO138 PE10 GPIO PE10 GPIO General Purpose Input Output #138
108 GPIO193 PG1 GPIO PG1 GPIO General Purpose Input Output #193
109 GPIO145 PE17 GPIO PE17 GPIO General Purpose Input Output #145
110 GPIO195 PG3 GPIO PG3 GPIO General Purpose Input Output #195
111 GPIO139 PE11 GPIO PE11 GPIO General Purpose Input Output #139
112 GPIO197 PG5 GPIO PG5 GPIO General Purpose Input Output #197
113 GPIO141 PE13 GPIO PE13 GPIO General Purpose Input Output #141
114 GND GND POWER ? G
115 GND GND POWER ? G
116 DSI-D1P MDSI-D1P MIPI_DSI P22 AO MIPI DSI Positive Differential Data Line 1
117 GPIO201 PG9 GPIO PG9 GPIO General Purpose Input Output #201
118 DSI-D1N MDSI-D1N MIPI_DSI R22 AO MIPI DSI Negative Differential Data Line 1
119 GPIO199 PG7 GPIO PG7 GPIO General Purpose Input Output #199
120 GPIO204 PG12 GPIO PG12 GPIO General Purpose Input Output #204
121 DSI-D0P MDSI-D0P MIPI_DSI T22 AO MIPI DSI Positive Differential Data Line 0
122 DSI-D3P MDSI-D3P MIPI_DSI L23 AO MIPI DSI Positive Differential Data Line 3
123 DSI-D0N MDSI-D0N MIPI_DSI T23 AO MIPI DSI Negative Differential Data Line 0
124 DSI-D3N MDSI-D3N MIPI_DSI L22 AO MIPI DSI Negative Differential Data Line 3
125 GND GND POWER ? G
126 DSI-D2P MDSI-D2P MIPI_DSI M22 AO MIPI DSI Positive Differential Data Line 2
127 DSI-CKP MDSI-CKP MIPI_DSI N23 AO MIPI DSI Positive Differential Clock Line
128 DSI-D2N MDSI-D2N MIPI_DSI N22 AO MIPI DSI Negative Differential Data Line 2
129 DSI-CKN MDSI-CKN MIPI_DSI P23 AO MIPI DSI Negative Differential Clock Line
130 GPIO72 PC8 GPIO PC8 GPIO General Purpose Input Output #72
131 GND GND POWER ? G
132 GPIO71 PC7 GPIO PC7 GPIO General Purpose Input Output #71
133 GPIO79 PC15 GPIO PC15 GPIO General Purpose Input Output #79
134 GPIO64 PC0 GPIO PC0 GPIO General Purpose Input Output #64
135 GPIO68 PC4 GPIO PC4 GPIO General Purpose Input Output #68
136 VIDEO-HTX0P HTX0P HDMI G22 AO HDMI Positive Differential Data Line 0
137 GND GND POWER ? G
138 VIDEO-HTX0N HTX0N HDMI G23 AO HDMI Negative Differential Data Line 0
139 VIDEO-HTX2N HTX2N HDMI E22 AO HDMI Negative Differential Data Line 2
140 GND GND POWER ? G
141 VIDEO-HTX2P HTX2P HDMI D23 AO HDMI Positive Differential Data Line 2
142 GPIO66 PC2 GPIO PC2 GPIO General Purpose Input Output #66
143 VIDEO-HTX1P HTX1P HDMI E23 AO HDMI Positive Differential Data Line 1
144 GPIO80 PC16 GPIO PC16 GPIO General Purpose Input Output #80
145 VIDEO-HTX1N HTX1N HDMI F22 AO HDMI Negative Differential Data Line 1
146 GPIO76 PC12 GPIO PC12 GPIO General Purpose Input Output #76
147 GND GND POWER ? G
148 GPIO67 PC3 GPIO PC3 GPIO General Purpose Input Output #67
149 VIDEO-TXCN HTXCN HDMI H23 AO HDMI Negative Differential Clock Line
150 GPIO65 PC1 GPIO PC1 GPIO General Purpose Input Output #65
151 VIDEO-TXCP HTXCP HDMI H22 AO HDMI Positive Differential Clock Line
152 GND GND POWER ? G
153 GPIO73 PC9 GPIO PC9 GPIO General Purpose Input Output #73
154 GPIO70 PC6 GPIO PC6 GPIO General Purpose Input Output #70
155 GPIO78 PC14 GPIO PC14 GPIO General Purpose Input Output #78
156 GPIO74 PC10 GPIO PC10 GPIO General Purpose Input Output #74
157 GPIO77 PC13 GPIO PC13 GPIO General Purpose Input Output #77
158 USB1-DP USB1-DP USB B23 A I/O USB 1 Data Positive
159 GND GND POWER ? G
160 USB1-DM USB1-DM USB C22 A I/O USB 1 Data Negative
161 VIDEO-SCL HSCL HDMI G21 I/O HDMI DDC Clock
162 GND GND POWER ? G
163 VIDEO-SDA HSDA HDMI E20 I/O HDMI DDC Data
164 VIDEO-HPD HHPD HDMI E21 I/O HDMI Hot Plug Detection
165 GPIO75 PC11 GPIO PC11 GPIO General Purpose Input Output #75
166 GPIO362 PL10 GPIO PL10 GPIO General Purpose Input Output #362
167 VIDEO-CEC HCEC HDMI F21 I/O HDMI CEC
168 PWR_ON PWRON PMU 60 I Power On-Off key input
169 GND GND POWER ? G
170 NC
171 USB0-DP USB0-DP USB A22 A I/O USB 0 Data Positive
172 DCDC1 DCDC1 POWER ? P 3.3V from DCDC for eMMC, LEDs and other external devices with higher power consumption
173 USB0-DM USB0-DM USB B22 A I/O USB 0 Data Negative
174 GPIO0-LDO GPIO0 POWER ? P 3.3V@100mA from LDO for Capacitive Touch Screen I2C interface as pull-up and other purposes with low power consumption
175 CHG_LED CHGLED OTHER 53 O Charger status indication
176 ALDO1 ALDO1 POWER ? P 2.8V@500mA from LDO for CSI Camera and other 2.8V based devices with low power consumption
177 RESET RESET OTHER ? I Pin for restarting of device, ground pin to perform device reset
178 NC
179 NC
180 DCIN ACIN POWER ? P 5V input, but probably can be more, look at the AXP803 datasheet
181 ELDO3 ELDO3 POWER ? P 1.8V@200mA from LDO for CSI Camera and other 1.8V based devices with low power consumption
182 DCIN ACIN POWER ? P 5V input, but probably can be more, look at the AXP803 datasheet
183 DLDO3 DLDO3 POWER ? P 2.8V@300mA from LDO for CSI Camera and other 2.8V based devices with low power consumption
184 DCIN ACIN POWER ? P 5V input, but probably can be more, look at the AXP803 datasheet
185 VCC-WIFI DLDO4 POWER ? P 3.3V@500mA from LDO for WiFi, Bluetooth and other 3.3V based devices
186 NC
187 DC1-SW DC1-SW POWER ? P 3.3V from DCDC for LCD and Ethernet (RGMII, RMII so GMAC and EMAC) and other 3.3V based devices
188 USBVBUS USBVBUS POWER ? P 5V for powering and charging PMU
189 DLDO2 DLDO2 POWER ? P Probably 1.8V@400mA (some sources indicate 3.3V) from DCDC for MIPI and other 1.8V based devices
190 USBVBUS USBVBUS POWER ? P 5V for powering and charging PMU
191 DLDO1 DLDO1 POWER ? P 3.3V@500mA from LDO for HDMI, MIPI DSI and other 3.3V based devices
192 USBVBUS USBVBUS POWER ? P 5V for powering and charging PMU
193 VCC-WIFI-IO DLDO4 POWER ? P 3.3V@500mA from LDO for WiFi, Bluetooth and other 3.3V based devices
194 NC
195 NC
196 BATT_SENSOR TS PMU ? I Battery Temperature Sensor Input
197 VRTC VCC-RTC PMU ? O Output pin of RTLCDO (NOT SURE)
198 NC
199 PS IPSOUT POWER 55 P 3.5V-5V@3A System power source
200 VBAT VBAT POWER ? P 3.5-4.2V power input from battery
201 PS IPSOUT POWER 55 P 3.5V-5V@3A System power source
202 VBAT VBAT POWER ? P 3.5-4.2V power input from battery
203 PS IPSOUT POWER 55 P 3.5V-5V@3A System power source
204 VBAT VBAT POWER ? P 3.5-4.2V power input from battery
