SOPine GPIO Alternate Functions Table
This is table of all available GPIOs on SOPine with their alternate functions. For more information about GPIOs, check Allwinner A64 Datasheet section 4.2 GPIO Multiplexing Functions and section 4.3 Detailed Pin/Signal Description
Pin name Linux SOPine Pin Direction Default Function Default Pull Function 2 Function 3 Function 4 Function 5 Function 6 SOPine Name
PB0 GPIO32 35 I/O DIS Z UART2_TX JTAG_MS0 PB_EINT0 PB0-UART2_TX
PB1 GPIO33 75 I/O DIS Z UART2_RX JTAG_CK0 SIM_PWREN PB_EINT1 PB1-UART2_RX
PB2 GPIO34 36 I/O DIS Z UART2_RTS JTAG_DO0 SIM_VPPEN PB_EINT2 PB2
PB3 GPIO35 30 I/O DIS Z UART2_CTS I2S0_MCLK JTAG_DI0 SIM_VPPPP PB_EINT3 PB3-I3S_MCLK
PB4 GPIO36 28 I/O DIS Z AIF2_SYNC PCM0_SYNC SIM_CLK PB_EINT4 PB4-I2S_SYNC
PB5 GPIO37 27 I/O DIS Z AIF2_BCLK PCM0_BCLK SIM_DATA PB_EINT5 PB5-I2S_BCLK
PB6 GPIO38 39 I/O DIS Z AIF2_DOUT PCM0_DOUT SIM_RST PB_EINT6 PB6-I2S_DOUT
PB7 GPIO39 29 I/O DIS Z AIF2_DIN PCM0_DIN SIM_DET PB_EINT7 PB7-I2S_DIN
PB8 GPIO40 34 I/O DIS Z UART0_TX PB_EINT8 PB8
PB9 GPIO41 33 I/O DIS Z UART0_RX PB_EINT9 PB9
PC0 GPIO64 134 I/O DIS Z NAND_WE SPI0_MOSI PC0-SPIO_MOSI
PC1 GPIO65 150 I/O DIS Z NAND_ALE SDC2_DS SPI0_MISO PC1-SPIO_MISO
PC2 GPIO66 142 I/O DIS Z NAND_CLE SPI0_CLK PC2-SPIO_CLK
PC3 GPIO67 148 I/O DIS Pull-Up NAND_CE1 SPI0_CS PC3-SPIO_CS
PC4 GPIO68 135 I/O DIS Pull-Up NAND_CE0 PC4
PC5 GPIO69 25 I/O DIS Z NAND_RE SDC2_CLK PC5
PC6 GPIO70 154 I/O DIS Pull-Up NAND_RB0 SDC2_CMD PC6
PC7 GPIO71 132 I/O DIS Pull-Up NAND_RB1 PC7
PC8 GPIO72 130 I/O DIS Z NAND_DQ0 SDC2_D0 PC8
PC9 GPIO73 153 I/O DIS Z NAND_DQ1 SDC2_D1 PC9
PC10 GPIO74 156 I/O DIS Z NAND_DQ2 SDC2_D2 PC10
PC11 GPIO75 165 I/O DIS Z NAND_DQ3 SDC2_D3 PC11
PC12 GPIO76 146 I/O DIS Z NAND_DQ4 SDC2_D4 PC12
PC13 GPIO77 157 I/O DIS Z NAND_DQ5 SDC2_D5 PC13
PC14 GPIO78 155 I/O DIS Z NAND_DQ6 SDC2_D6 PC14
PC15 GPIO79 133 I/O DIS Z NAND_DQ7 SDC2_D7 PC15
PC16 GPIO80 144 I/O DIS Z NAND_DQS SDC2_RST PC16
PD0 GPIO96 60 I/O DIS Z LCD_D2 UART3_TX SPI1_CS CCIR_CLK PD0-SPI1_CS
PD1 GPIO97 49 I/O DIS Z LCD_D3 UART3_RX SPI1_CLK CCIR_DE PD1-SPI1_CLK
PD2 GPIO98 57 I/O DIS Z LCD_D4 UART4_TX SPI1_MOSI CCIR_HSYNC PD2-SPI1_MOSI
PD3 GPIO99 61 I/O DIS Z LCD_D5 UART4_RX SPI1_MISO CCIR_VSYNC PD3-SPI1_MISO
PD4 GPIO100 52 I/O DIS Z LCD_D6 UART4_RTS CCIR_D0 PD4-UART4_RTS
PD5 GPIO101 44 I/O DIS Z LCD_D7 UART4_CTS CCIR_D1 PD5-UART4_CTS
PD6 GPIO102 45 I/O DIS Z LCD_D10 CCIR_D2 PD6
PD7 GPIO103 40 I/O DIS Z LCD_D11 CCIR_D3 PD7
PD8 GPIO104 73 I/O DIS Z LCD_D12 RGMII_RXD3/RMII_NULL CCIR_D4 GRXD3
PD9 GPIO105 83 I/O DIS Z LCD_D13 RGMII_RXD2/RMII_NULL CCIR_D5 GRXD2
PD10 GPIO106 51 I/O DIS Z LCD_D14 RGMII_RXD1/RMII_RXD1 RMII-RXD1
PD11 GPIO107 48 I/O DIS Z LCD_D15 RGMII_RXD0/RMII_RXD0 RMII-RXD0
PD12 GPIO108 91 I/O DIS Z LCD_D18 LVDS_VP0 RGMII_RXCK/RMII_NULL GRXCK
PD13 GPIO109 89 I/O DIS Z LCD_D19 LVDS_VN0 RGMII_RXCT/RMII_CRS_DV RMII-CRS-DV
PD14 GPIO110 87 I/O DIS Z LCD_D20 LVDS_VP1 RGMII_NULL/RMII_RXER RMII-RXER
PD15 GPIO111 80 I/O DIS Z LCD_D21 LVDS_VN1 RGMII_TXD3/RMII_NULL CCIR_D6 GTXD3
PD16 GPIO112 82 I/O DIS Z LCD_D22 LVDS_VP2 RGMII_TXD2/RMII_NULL CCIR_D7 GTXD2
PD17 GPIO113 78 I/O DIS Z LCD_D23 LVDS_VN2 RGMII_TXD1/RMII_TXD1 RMII-TXD1
PD18 GPIO114 85 I/O DIS Z LCD_CLK LVDS_VPC RGMII_TXD0/RMII_TXD0 RMII-TXD0
PD19 GPIO115 79 I/O DIS Z LCD_DE LVDS_VNC RGMII_TXCK/RMII_TXCK RMII-TXCK
PD20 GPIO116 47 I/O DIS Z LCD_HSYNC LVDS_VP3 RGMII_TXCTL/RMII_TXEN RMII-TXEN
PD21 GPIO117 74 I/O DIS Z LCD_VSYNC LVDS_VN3 RGMII_CLKINRMII_NULL GCLKIN
PD22 GPIO118 53 I/O DIS Z PWM0 MDC RMII-MDC
PD23 GPIO119 76 I/O DIS Z MDIO RMII-MDIO
PD24 GPIO120 50 I/O DIS Z LCD-RST
PE0 GPIO128 58 I/O DIS Z CSI_PCLK TS_CLK CSI-PCLK
PE1 GPIO129 102 I/O DIS Z CSI_MCLK TS_ERR CSI-MCLK
PE2 GPIO130 100 I/O DIS Z CSI_HSYNC TS_SYNC CSI-HSYNC
PE3 GPIO131 101 I/O DIS Z CSI_VSYNC TS_DVLD CSI-VSYNC
PE4 GPIO132 95 I/O DIS Z CSI_D0 TS_D0 CSI-D0
PE5 GPIO133 54 I/O DIS Z CSI_D1 TS_D1 CSI-D1
PE6 GPIO134 96 I/O DIS Z CSI_D2 TS_D2 CSI-D2
PE7 GPIO135 65 I/O DIS Z CSI_D3 TS_D3 CSI-D3
PE8 GPIO136 105 I/O DIS Z CSI_D4 TS_D4 CSI-D4
PE9 GPIO137 59 I/O DIS Z CSI_D5 TS_D5 CSI-D5
PE10 GPIO138 107 I/O DIS Z CSI_D6 TS_D6 CSI-D6
PE11 GPIO139 111 I/O DIS Z CSI_D7 TS_D7 CSI-D7
PE12 GPIO140 98 I/O DIS Z CSI_SCK CSI-SCK
PE13 GPIO141 113 I/O DIS Z CSI_SDA CSI-SDA
PE16 GPIO144 92 I/O DIS Z CSI-RST-F
PE17 GPIO145 109 I/O DIS Z CSI-STBY-F
PG0 GPIO192 72 I/O DIS Z SDC1_CLK PG_EINT0 WL-SDIO-CLK
PG1 GPIO193 108 I/O DIS Z SDC1_CMD PG_EINT1 WL-SDIO-CMD
PG2 GPIO194 63 I/O DIS Z SDC1_D0 PG_EINT2 WL-SDIO-D0
PG3 GPIO195 110 I/O DIS Z SDC1_D1 PG_EINT3 WL-SDIO-D1
PG4 GPIO196 106 I/O DIS Z SDC1_D2 PG_EINT4 WL-SDIO-D2
PG5 GPIO197 112 I/O DIS Z SDC1_D3 PG_EINT5 WL-SDIO-D3
PG6 GPIO198 90 I/O DIS Z UART1_TX PG_EINT6 BT-UART-RX
PG7 GPIO199 119 I/O DIS Z UART1_RX PG_EINT7 BT-UART-TX
PG8 GPIO200 88 I/O DIS Z UART1_RTS PG_EINT8 BT-UART-CTS
PG9 GPIO201 117 I/O DIS Z UART1_CTS PG_EINT9 BT-UART-RTS
PG10 GPIO202 99 I/O DIS Z AIF3_SYNC PCM1_SYNC PG_EINT10 BT-PCM-SYNC
PG11 GPIO203 86 I/O DIS Z AIF3_BCLK PCM1_BCLK PG_EINT11 BT-PCM-CLK
PG12 GPIO204 120 I/O DIS Z AIF3_DOUT PCM1_DOUT PG_EINT12 BT-PCM-DIN
PG13 GPIO205 97 I/O DIS Z AIF3_DIN PCM1_DIN PG_EINT13 BT-PCM-DOUT
PH0 GPIO224 43 I/O DIS Z I2C0_SCL PH_EINT0 TP-SCK
PH1 GPIO225 46 I/O DIS Z I2C0_SDA PH_EINT1 TP-SDA
PH2 GPIO226 62 I/O DIS Z I2C1_SCL PH_EINT2 PH2-TW1_SCK
PH3 GPIO227 37 I/O DIS Z I2C1_SDA PH_EINT3 PH3-TW1_SDA
PH4 GPIO228 64 I/O DIS Z UART3_TX PH_EINT4 TP-INT
PH5 GPIO229 68 I/O DIS Z UART3_RX PH_EINT5 PH5
PH6 GPIO230 66 I/O DIS Z UART3_RTS PH_EINT6 PH6
PH7 GPIO231 71 I/O DIS Z UART3_CTS PH_EINT7 PH7
PH8 GPIO232 38 I/O DIS Z OWA_OUT PH_EINT8 PH8-OWA_OUT
PH9 GPIO233 77 I/O DIS Z PH_EINT9 PH9
PH10 GPIO234 26 I/O DIS Z MIC_CLK PH_EINT10 LCD-BL-EN
PH11 GPIO235 67 I/O DIS Z MIC_DATA PH_EINT11 CTP-RST
PL2 GPIO354 21 I/O DIS Z S_UART_TX S_PL_EINT2 WL-REG-ON
PL3 GPIO355 23 I/O DIS Z S_UART_RX S_PL_EINT3 WL-WAKE-AP
PL4 GPIO356 14 I/O DIS Z S_JTAG_MS S_PL_EINT4 BT-RST-N
PL5 GPIO357 18 I/O DIS Z S_JTAG_CK S_PL_EINT5 BT-WAKE-AP
PL6 GPIO358 16 I/O DIS Z S_JTAG_DO S_PL_EINT6 AP-WAKE-BT
PL7 GPIO359 24 I/O DIS Z S_JTAG_DI S_PL_EINT7 PL7
PL8 GPIO360 15 I/O DIS Z S_I2C_CLK S_PL_EINT8 PL8-S_TWI_SCK
PL9 GPIO361 17 I/O DIS Z S_I2C_SDA S_PL_EINT9 PL9-S_TWI_SDA
PL10 GPIO362 166 I/O DIS Z S_PWM S_PL_EINT10 PL10-S_PWM
PL11 GPIO363 13 I/O DIS Z S_CIR_RX S_PL_EINT11 PL11-IR_RX
