SOPINE Software Releases
Revision as of 20:57, 28 December 2020 by Tllim (talk | contribs)
Note that, SOPINE OS images are also compatible with PINE A64-LTS
Linux Image Releases
Armbian
Armbian Debian Buster for Server and Light Desktop Usage
Armbian Ubuntu Bionic for Server and Light Desktop Usage
Armbian Ubuntu Focal for Desktop Usage
AOSC
AOSC Community Build Image with Mate Desktop [microSD and eMMC Boot]
AOSC Community Build Image with XFCE Desktop [[microSD and eMMC Boot]
  • To learn more about AOSC, please visit the official AOSC website
  • Known issue: no audio sound output.
  • Login with
    • username: aosc
    • password: anthon
AOSC Community Build Image with LXDE Desktop [[microSD and eMMC Boot]
  • Login with
    • username: aosc
    • password: anthon
Volumio 2 Digital Audio Player
Volumio 2 Digital Audio Player [2.861-2020-12-22]
  • This version works with (Spdif / Coaxial / RCA).
  • You need to enable Volume Normalization in the Playback Options to fix sound low.
  • supports booting from eMMC and SD card.
  • supports a select number of simple I2S DACS. tested with the Pine64 DAC POT, a wired ES9023 DAC module and a pcm5121 DAC module.
  • Login with
    • Username: volumio
    • Password: volumio
Arch Linux [No Longer Maintained]
* From SSH Login default disable root to access . So please first login alarm after command su password root to switch root
OpenEmbedded/Yocto Images
OpenEmbedded is the build framework for embedded Linux. OpenEmbedded offers a best-in-class cross-compile environment. It allows developers to create a complete Linux Distribution for embedded systems. See https://www.openembedded.org/wiki/Main_Page for more information on OpenEmbedded.
meta-pine64
OpenMediaVault
OpenMediaVault Community Build Image [microSD Boot]
FreedomBox
Stable built
LibreELEC(KODI) [No Longer Maintained]
Nightly Build Image [microSD and eMMC Boot] [20191226]
  • DD image to microSD card ir eMMC module and boot. Highly recommend using Etcher
      • MD5 (GZip file): 7A67D20D1E915AFF0DDBEB086ED2CA46
      • File Size: 111MB
    • FEATURES:
      • mainline kernel & U-Boot
      • latest Kodi
      • HDMI CEC
      • multi channel HDMI audio (correct audio output must be selected)
      • IR receiver
OpenWRT
OpenWRT Community Build Image [microSD Boot]
NEMS Linux [No Longer Maintained]
  • Login with
    • Username: nemsadmin
    • Password: nemsadmin
  • Installation Guide
NEMS Linux [v1.5 - Build 1]
Android Image Releases
Android 7.x
Android 7.1 Community Build Image [v0.3.10-r66] [No Longer Maintained]
  • ayufan Android 7.1 ver 0.3.10 GitHub
  • Please use good random IO access performance microSD card such as Samsung EVO when try out Android 7.1
  • DD images (advise 4GB microSD card and above):
  • Please allows some time (around 5 minutes) for the initialization process on 1st boot
Android 6.x
Stock Android 6.0.1 [20170726]
  • Support dual display (LCD + HDMI output) output
  • Note that, there will be about 1 minute of blank screen on HDMI output during boot up. The boot logo will appear on the LCD Panel
  • Please use good random IO access performance microSD card such as Samsung EVO when try out Android 6.0.1
  • DD image (for 8GB microSD Card)
  • DD image (for 16GB microSD Card)
  • DD image (for 32GB microSD Card)
  • DD image (for 64GB microSD Card)
Stock Android 5.x
Android 5.1.1 [20160630]
Linux BSP SDK
Linux BSP Kernel 4.9
Android SDK
Android Oreo [v8.1]
Mali-400 64-bit Driver
