SOPINE Software Release
Jump to navigation
Jump to search
Contents
Linux Image Releases
Ubuntu Mate
Ubuntu Mate Image [20161215] built by Pine64
- This is a build including DE based on longsleep works and may not have all the up-to-date features offered by longsleep and Sunxi community. For latest build, you can create one and following this thread
- This build optimizes Gigabit Ethernet parameter and improves on GbE connectivity.
- Included Mate Desktop, Firebox Browser, and LibreOffice Suite.
- Included libvdpau-sunxi with SMPlayer
- Included with Wifi and Bluetooth
- Included library set that provides access to the GPIO headers in Linux as provided by community member KB3VGW (https://devhub.io/repos/kb3vgw-wiringPi-Pine64)
- Not yet optimize for Graphic acceleration
- Suitable for Sopine Board only
- Login with
- username: ubuntu
- password: ubuntu
- Auto execute resize_rootfs.sh script on first boot-up to resize the root partition in order to fully utilize the SD Card
- DD image (for 8GB micoSD card and above):
- Direct download from pine64.org (US)
- Direct download from pine64.uk (UK)
- MD5 (Zip file): 67E3CBF695AB4196C00F205AEB0F3623
- File Size: 2.09GB
openSUSE Base Image
openSUSE Base Image [20170328]
- Thanks to Terra854 for contributing the openSUSE build based on longsleep's kernel.
- You can visit the project's website here
- File Size: 174MB
- Login with
- Username: pine64
- Password: pine64linux
- Root password: pine64root
- To find out more about openSUSE on the Pine64 please visit the Pine64 forum thread
The image includes a config tool which, among other options, allows users to install a desktop environment: sudo /usr/local/sbin/pine64-config.sh
Android Image Releases
Android 6.x
Android 6.0.1 Image [20170331]
- DD image (for 8GB microSD Card)
- MD5 (Zip file): 4936361E31EDC1E4BA44FBAC08C1619F
- File Size: 951MB
- DD image (for 16GB microSD Card)
- MD5 (Zip file): BF27C58001C1CEA02CECA9082BD8BC41
- File Size: 936MB
- DD image (for microSD Card to eMMC)
- Burn this image to a 8GB microSD Card, insert into SOPINE and it will start program to eMMC. The power LED will be turn off when the process is completed. Unplug the MicroSD card from SOPINE to boot from eMMC.
- MD5 (Zip file): 99736D857E675254D4C3ACA95024B3F3
- File Size: 673MB
Android 5.x
Android 5.1.1 Image [20160630]
- MD5 (Zip file): D5A5CE806D6E65F6F841E9E1711A6B77
- File Size: 681MB
