SOPINE Software Releases
Revision as of 03:50, 29 December 2019 by Tllim (talk | contribs)
Note that, SOPINE OS images are also compatible with PINE A64-LTS
Linux Image Releases
Armbian
Armbian Buster for Desktop Usage
Armbian Bionic for Desktop Usage
Arch Mainline Linux XFCE
* From SSH Login default disable root to access . So please first login alarm after command su password root to switch root
LibreELEC(KODI)
Nightly Build Image [microSD and eMMC Boot] [20191226]
  • DD image to microSD card ir eMMC module and boot. Highly recommend using Etcher
      • MD5 (GZip file): 7A67D20D1E915AFF0DDBEB086ED2CA46
      • File Size: 111MB
    • FEATURES:
      • mainline kernel & U-Boot
      • latest Kodi
      • HDMI CEC
      • multi channel HDMI audio (correct audio output must be selected)
      • IR receiver
AOSC
AOSC Community Build Image with Mate Desktop [microSD Boot] [20190218]
  • To learn more about AOSC, please visit the official AOSC website
  • Known issue: no audio sound output.
  • Login with
    • username: aosc
    • password: anthon
AOSC Community Build Image with Mate Desktop [eMMC Boot] [20180216]
  • Login with
    • username: aosc
    • password: anthon
NEMS Linux
  • Login with
    • Username: nemsadmin
    • Password: nemsadmin
  • Installation Guide
NEMS Linux [v1.5 - Build 1]
Volumio Digital Audio Player
Volumio Digital Audio Player [2.383-2018-03-17]
  • This version works with (Spdif / Coaxial / RCA).
  • You need to enable Volume Normalization in the Playback Options to fix sound low.
  • supports booting from eMMC and SD card.
  • supports a select number of simple I2S DACS. tested with the Pine64 DAC POT, a wired ES9023 DAC module and a pcm5121 DAC module.
  • Login with
    • Username: volumio
    • Password: volumio
OpenMediaVault
OpenMediaVault Community Build Image [microSD Boot]
openSUSE Base Image
openSUSE Base Image [20170328]
  • Thanks to Terra854 for contributing the openSUSE build based on longsleep's kernel
  • You can visit the project's website here
  • To find out more about openSUSE on the PINE64 please visit the PINE64 forum thread
  • Login with
    • Username: pine64
    • Password: pine64linux
    • Root password: pine64root
The image includes a config tool which, among other options, allows users to install a desktop environment: sudo /usr/local/sbin/pine64-config.sh
FreedomBox
Testing built
OpenEmbedded/Yocto Images
OpenEmbedded is the build framework for embedded Linux. OpenEmbedded offers a best-in-class cross-compile environment. It allows developers to create a complete Linux Distribution for embedded systems. See https://www.openembedded.org/wiki/Main_Page for more information on OpenEmbedded.
meta-pine64
Android Image Releases
Android 7.x
Android 7.1 Community Build Image [v0.3.10-r66]
  • ayufan Android 7.1 ver 0.3.10 GitHub
  • Please use good random IO access performance microSD card such as Samsung EVO when try out Android 7.1
  • DD images (advise 4GB microSD card and above):
  • Please allows some time (around 5 minutes) for the initialization process on 1st boot
Android 6.x
Android 6.0.1 [20170726]
[OLD] Android 6.0.1 [20170331]
Android 5.x
Android 5.1.1 [20160630]
Linux BSP SDK
Linux BSP [4.0]
Linux BSP [3.0]
Android SDK
Android Oreo [v8.1]
Android Nougat [v7.0]
Android Marshmallow [v6.0]
Android Lollipop [v5.1.1]
Linux BSP SDK
Linux BSP [4.0]
Linux BSP [3.0]
Android SDK
Android Oreo [v8.1]
Mali-400 64-bit Driver
