SOPINE Software Release
Jump to navigation
Jump to search
Note that, SOPINE OS images are also compatible with PINE A64-LTS
Contents
Linux Image Releases
Armbian
Armbian Community Build Image [microSD Boot] {mainline kernel 4.19.y]
- Armbian provides a build system and images for Debian/Xenial with BSP kernel and mainline kernel (beta)
- Two versions of Armbian images are available: legacy and vanilla. Legacy is strongly recommended for most users, whilst vanilla includes a mainline kernel which doesn't support DVFS, HDMI, onboard analog audio output, onboard IR receiver, CSI, DSI and TP interfaces
- DD image (for 8GB micoSD card and above)
- Login with
- username: root
- password: 1234
- To find out more about Armbian and available options please visit their site
- Setup SOPINE Armbian LCD and Camera
Arch Mainline Linux XFCE
- Included XFCE Desktop, and Firefox browser
- DD image (for 8GB and above SD Card):
- Login with
- User Name: alarm, Password: alarm
- User Name: root, Password: root
- please login root and execute "pacman -Syu" for latest update
* From SSH Login default disable root to access . So please first login alarm after command su password root to switch root
OpenMediaVault
OpenMediaVault Community Build Image [microSD Boot]
- openmediavault is the next generation network attached storage (NAS) solution, click link to OMV main page
- Direct download from pine64.org
- Direct download from pine64.uk
- MD5 (GZip file): 54f720163fac3a1d4863de12f3ca91ee
- File Size: 3.98MB
- Credentials (OMV for Web): admin/openmediavault
- Credentials (OMV for console): root/openmediavault
- If no HDMI output: After boot, you can use tools (e.g. netscan) to search for IP Address with PINE64SO hostname. Use the IP Address on PC browser to access to the OMV Web.
- OpenMediaVault Basic Setup
- OpenMediaVault Plugins
Volumio Digital Audio Player
Volumio Digital Audio Player [2.383-2018-03-17]
- This version works with (Spdif / Coaxial / RCA).
- You need to enable Volume Normalization in the Playback Options to fix sound low.
- supports booting from eMMC and SD card.
- supports a select number of simple I2S DACS. tested with the Pine64 DAC POT, a wired ES9023 DAC module and a pcm5121 DAC module.
- Volumio is a linux-based headless DAP (digital audio player), which connects to your home stereo system or your DAC
- Visit the project's website here
- Login with
- Username: volumio
- Password: volumio
- Volumio is controlled using a Web-GUI which can be accessed via a web browser using the boards IP or volumio.local/
Volumio Digital Audio Player [2.315-2017-11-11]
- For listen headphones this version have "hiss"
- Login with
- Username: volumio
- Password: volumio
Xenial Mate
Xenial Mate [20170306] built by PINE64
- This is a build including DE based on longsleep works and may not have all the up-to-date features offered by longsleep and Sunxi community. For latest build, you can create one and following this thread
- This build optimizes Gigabit Ethernet parameter and improves on GbE connectivity
- Included Mate Desktop, Firebox Browser, and LibreOffice Suite
- Included libvdpau-sunxi with SMPlayer
- Included with Wifi and Bluetooth
- Included library set that provides access to the GPIO headers in Linux as provided by community member KB3VGW (https://devhub.io/repos/kb3vgw-wiringPi-Pine64)
- Not yet optimize for Graphic acceleration
- Auto execute resize_rootfs.sh script on first boot-up to resize the root partition in order to fully utilize the SD Card
- Suitable for SOPINE Board only
- MD5 (GZip file): 67E3CBF695AB4196C00F205AEB0F3623
- File Size: 2.09GB
- Login with
- username: ubuntu
- password: ubuntu
openSUSE Base Image
openSUSE Base Image [20170328]
- Thanks to Terra854 for contributing the openSUSE build based on longsleep's kernel
- You can visit the project's website here
- To find out more about openSUSE on the PINE64 please visit the PINE64 forum thread
- MD5 (XZ file): 9D1F3CA66B6637132CC6900ABA96B1D7
- File Size: 174MB
- Login with
- Username: pine64
- Password: pine64linux
- Root password: pine64root
The image includes a config tool which, among other options, allows users to install a desktop environment: sudo /usr/local/sbin/pine64-config.sh
Android Image Releases
Android 7.x
Android 7.1 Community Build Image [v0.3.10-r66]
- Special thanks to ayufan, Icenowy, lennyraposo, longsleep, lukasz, tkaiser, Xalius and PINE64 community contributors
- ayufan Android 7.1 ver 0.3.10 GitHub
- Please use good random IO access performance microSD card such as Samsung EVO when try out Android 7.1
- DD images (advise 4GB microSD card and above):
- Android 7.1 ver 0.3.10 build 66 Direct download from GitHub
- MD5 (GZip file): 0D11F8D2297077BE70CC4D72156A4AAB
- File Size: 783MB
- Please allows some time (around 5 minutes) for the initialization process on 1st boot
Android 6.x
Android 6.0.1 [20170726]
- Support dual display (LCD + HDMI output) output
- Note that, there will be about 1 minute of blank screen on HDMI output during boot up. The boot logo will appear on the LCD Panel
- Please use good random IO access performance microSD card such as Samsung EVO when try out Android 6.0.1
- DD image (for 8GB microSD Card)
- MD5 (XZ file): FF0F1C29E5B51795A61308DFA03282BA
- File Size: 427MB
- DD image (for 16GB microSD Card)
- MD5 (XZ file): FE4EAC11E751BAD2B5243D72E8913606
- File Size: 428MB
- DD image (for 32GB microSD Card)
- MD5 (XZ file): D21960E25E2421D466BAB8915D58A2E4
- File Size: 430MB
- DD image (for 64GB microSD Card)
- MD5 (XZ file): B3D3DE1086F1BF22146B47DCD1CE945C
- File Size: 434MB
[OLD] Android 6.0.1 [20170331]
- MD5 (Zip file): 4936361E31EDC1E4BA44FBAC08C1619F
- File Size: 951MB
- MD5 (Zip file): BF27C58001C1CEA02CECA9082BD8BC41
- File Size: 936MB
- DD image (for microSD Card to eMMC)
- Burn this image to a 8GB microSD Card, insert into SOPINE and it will start program to eMMC. The power LED will be turn off when the process is completed. Unplug the MicroSD card from SOPINE to boot from eMMC
- MD5 (Zip file): 99736D857E675254D4C3ACA95024B3F3
- File Size: 673MB
Android 5.x
Android 5.1.1 [20160630]
- MD5 (Zip file): D5A5CE806D6E65F6F841E9E1711A6B77
- File Size: 681MB
Linux BSP SDK
Linux BSP [4.0]
- Direct Download from pine64.org
- MD5 (TAR-GZip file): 802D7C92D27177CBD17567359F9845A7
- File Size: 4.67GB
Linux BSP [3.0]
- MD5 (TAR-GZip file): 898ACF446851DF3BE7B643F62CE3CE84
- File Size: 4.18GB
- MD5 (TAR-GZip file): 2EE11C9AED246C17995493F213A6A6DA
- File Size: 6.41GB
Android SDK
Android Oreo [v8.1]
- MD5 (TAR-Gzip file): 7E73672FE84F8CD099264D640E107EA3
- File Size: 28.87.95GB
Android Nougat [v7.0]
- MD5 (TAR-GZip file): 5D23D65BC1AA32B9048F62A4176BD9B3
- File Size: 22.60GB
Android Marshmallow [v6.0]
- MD5 (Zip file): 12362D0B63EBF29FC363A50A942346D5
- File Size: 12.17GB
Android Lollipop [v5.1.1]
- MD5 (Zip file): 26860B070C48CFDF36EBF87E76A232DB
- File Size: 18.00GB
Linux BSP SDK
Linux BSP [4.0]
- File Size: 4.67GB
Linux BSP [3.0]
- File Size: 4.18GB
- File Size: 6.41GB
Android SDK
Android Oreo [v8.1]
