SOPINE Software Release
Note that, SOPINE OS images are also compatible with PINE A64-LTS
Linux Image Releases
Armbian
Armbian Debian Buster for Server and Light Desktop Usage
Armbian Ubuntu Bionic for Server and Light Desktop Usage
Armbian Ubuntu Focal for Server and Light Desktop Usage
AOSC
  • To learn more about AOSC, please visit the official AOSC website
  • AOSC using LZ4 compression algorithm, please visit the LZ4 github site for utility
  • 8GB microSD card and above
  • Login with
    • username: aosc
    • password: anthon
AOSC MATE Community Build Image [microSD and eMMC Boot]
AOSC XFCE Community Build Image [microSD and eMMC Boot]
AOSC LXDE Community Build Image [microSD and eMMC Boot]
OpenEmbedded/Yocto Images
OpenEmbedded is the build framework for embedded Linux. OpenEmbedded offers a best-in-class cross-compile environment. It allows developers to create a complete Linux Distribution for embedded systems. See https://www.openembedded.org/wiki/Main_Page for more information on OpenEmbedded.
meta-pine64
OpenWRT
OpenWRT Community Build Image [microSD Boot]
Volumio 2 Digital Audio Player
Volumio 2 Digital Audio Player [2.861-2020-12-22]
  • This version works with (Spdif / Coaxial / RCA).
  • You need to enable Volume Normalization in the Playback Options to fix sound low.
  • supports booting from eMMC and SD card.
  • supports a select number of simple I2S DACS. tested with the Pine64 DAC POT, a wired ES9023 DAC module and a pcm5121 DAC module.
  • DD image (for 8GB microSD card and above)
  • Login with
    • Username: volumio
    • Password: volumio
FreedomBox
Stable built
LibreELEC(KODI)
Nightly Build Image [microSD and eMMC Boot]
Arch Linux [No Longer Maintained]
* From SSH Login default disable root to access . So please first login alarm after command su password root to switch root
OpenMediaVault [No Longer Maintained]
OpenMediaVault Community Build Image [microSD Boot]
NEMS Linux
  • Login with
    • Username: nemsadmin
    • Password: nemsadmin
  • Installation Guide
NEMS Linux [v1.5 - Build 1]
BSD Image Releases
NetBSD
NetBSD Community Build Image [microSD Boot]
Android Image Releases
Android 7.x
Android 7.1 Community Build Image [v0.3.10-r66] [No Longer Maintained]
  • ayufan Android 7.1 ver 0.3.10 GitHub
  • Please use good random IO access performance microSD card such as Samsung EVO when try out Android 7.1
  • DD images (advise 4GB microSD card and above):
  • Please allows some time (around 5 minutes) for the initialization process on 1st boot
Stock Android 6.x
Stock Android 6.0.1 [20170726][No Longer Maintained]
  • Support dual display (LCD + HDMI output) output
  • Note that, there will be about 1 minute of blank screen on HDMI output during boot up. The boot logo will appear on the LCD Panel
  • Please use good random IO access performance microSD card such as Samsung EVO when try out Android 6.0.1
  • DD image (for 8GB microSD Card)
  • DD image (for 16GB microSD Card)
  • DD image (for 32GB microSD Card)
  • DD image (for 64GB microSD Card)
Stock Android 5.x
Stock Android 5.1.1 [20160630][No Longer Maintained]
Linux BSP SDK
Linux BSP Kernel 4.9
Android SDK
Android Oreo [v8.1]
Mali-400 64-bit Driver
