SOPINE Armbian LCD and Camera
Revision as of 20:59, 24 November 2020 by Pander (talk | contribs)
LCD
1. DD the Armbian SOPINE image to the microSD Card and run on the board
2. Login through the terminal
3. # vi /boot/armbianEnv.txt (Change off to on)
pine64_lcd=on
4. # vi /etc/modules (Add following line)
gt9xxf_ts
5. reboot
Then the display will be on LCD and not HDMI
Camera
3. Install Ubuntu Xenial Mate with ayufan's script
  1. cd ~
  2. wget https://github.com/longsleep/build-pine64-image/raw/master/simpleimage/platform-scripts/install_desktop.sh
  3. chmod +x install_desktop.sh
  4. ./install_desktop.sh mate
4. # vi /boot/armbianEnv.txt (Set to "s5k4ec" or "ov5640" depending on your camera module)
   camera_type=s5k4ec
5. # vi /etc/modules (Add the following depending on your camera_type "s5k4ec" or "ov5640" above. Note that "vfe_v4l2" has a small letter 'L'2 not 12)
   s5k4ec
   vfe_v4l2
6. # reboot
7. Following https://github.com/avafinger/pine64_camera (Change "s5k4ec" to "ov5640" depending on your camera module)
  1. apt-get update
  2. apt-get upgrade
  3. apt-get remove --purge guvcview
  4. apt-get remove --purge libguvcview-1.1-1
  5. modprobe -r -f vfe_v4l2
  6. modprobe -r -f s5k4ec
  7. modprobe s5k4ec
  8. modprobe vfe_v4l2
  9. ls /dev/video0
  10. dmesg | grep OK
  11. sudo apt-get install libmp3lame-dev libx264-dev libpulse-dev libv4l-dev libsdl1.2-dev libgtk-3-dev portaudio19-dev libpng12-dev libavcodec-dev libavutil-dev libudev-dev libusb-1.0-0-dev libpulse-dev libgsl0-dev libv4l-dev
  12. cd ~
  13. wget https://raw.githubusercontent.com/avafinger/pine64_camera/master/libguvcview-1.2-1_2.0.3%2Bdebian-1_arm64.deb
  14. wget https://raw.githubusercontent.com/avafinger/pine64_camera/master/guvcview_2.0.3%2Bdebian-1_arm64.deb
  15. dpkg -i libguvcview-1.2-1_2.0.3+debian-1_arm64.deb
  16. dpkg -i guvcview_2.0.3+debian-1_arm64.deb
8. For testing, use Xenial Mate -> Applications -> Sound & Video -> guvcview OR command line
  1. guvcview -d /dev/video0 -x 640x480 -r sdl -f yu12
  2. guvcview -d /dev/video0 -x 640x480 -r sdl -f nv12
