SOEDGE
Revision as of 13:17, 4 April 2023 by Fxc (talk | contribs) (→‎Stock BSP: Redundant)
The SOEDGE
The SOEDGE is a 3TOPS compute module that can be paired with the SOEDGE Baseboard, the Clusterboard or USB 3.0 and PCIe adapters for development. It can connect to a SBC, such as the ROCKPro64 or a regular PC.
Software releases
The SOEDGE software releases can be found in the article SOEDGE Software Releases.
SoC and Memory Specification
  • Dual-core ARM Cortex-A35 Processor@1600-2000Mhz
  • A power-efficient ARM 64-Bit Armv8-A architecture
  • AArch32 for full backward compatibility with Armv7
  • VFPv4 Floating Point Unit
  • TrustZone security technology
  • Neon Advanced SIMD
  • DSP and SIMD extensions
  • VFPv4 Floating point
  • 128KB L2 cache
Neural Process Unit NPU Capability
  • RAM Memory Variants: 2GB DDR4.
  • Storage Memory: 128Mb SPI Flash and optional eMMC module from 16GB up to 128GB
Schematics and certifications
SOEDGE module schematics:
SOEDGE Neural AI Stick schematic:
SOEDGE/SOPINE/PINE A64 WiFi/BT module schematics:
SOEDGE module together with the baseboard certification:
  • Disclaimer: Please note that SOEDGE module is not a "final" product and in general certification is not necessary. However, SOEDGE module still submits the mpdel A baseboard for FCC, CE, and ROHS certifications and obtain the certificates to prove that can pass the testing. Please note, a final commercial product needs to perform its own testing and obtain its own certificate.
  • Not yet available
Rockchip RK1808 SoC information:
Rockchip RK809 PMU (Power Management Unit) information:
DDR4 information:
eMMC information:
SPI NOR Flash information:
SOEDGE Related:
Debugging
Serial Console
System Serial is located on PI-5 bus (11x2 GPIO header).
  • TXD: Pin 6 (Yellow cable) (Connect to RXD on Serial adapter)
  • RXD: Pin 8 (Orange cable) (Connect to TXD on Serial adapter)
  • GND: Pin 10 (Black cable) (Connect to GND on Serial adapter)
The default baudrate is 1500000, note that not all serial adapters support this high baudrate.
Linux Image Releases
Factory Test Build
  • Factory Test Build by Gamiee
  • DD image (for 8GB microSD card or eMMC Module and above)
