SOEDGE
Revision as of 11:35, 1 February 2023 by Fxc (talk | contribs) (Fxc moved page SOEdge to SOEDGE: Streamlined the name)
The SOEdge
The SOEdge is a 3TOPS compute module that can be paired with the SOPINE Baseboard or USB 3.0 and PCIe adapters for development. It can connect to a SBC, such as the ROCKPro64 or a regular PC.
Software releases
The SOEdge software releases can be found in the article SOEdge Software Releases.
SoC and Memory Specification
  • Dual-core ARM Cortex-A35 Processor@1600-2000Mhz
  • A power-efficient ARM 64-Bit Armv8-A architecture
  • AArch32 for full backward compatibility with Armv7
  • VFPv4 Floating Point Unit
  • TrustZone security technology
  • Neon Advanced SIMD
  • DSP and SIMD extensions
  • VFPv4 Floating point
  • 128KB L2 cache
Neural Process Unit NPU Capability
  • RAM Memory Variants: 2GB DDR4.
  • Storage Memory: 128Mb SPI Flash and optional eMMC module from 16GB up to 128GB
SOEdge Baseboard Features
Network
  • 10/100/1000Mbps Ethernet
Storage
  • USB - 2 USB2.0 Host port
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
  • PCIe 2x open ended slot
SOEdge Module and Baseboard Information, Schematics, and Certifications
  • Model "A" Baseboard Dimensions: 133mm x 80mm x 19mm
  • Input Power: DC 12V @ 3A 5.5OD/2.1ID Barrel DC Jack connector
SOEdge/SOPine Cluster Board Resource
Debugging
Serial Console
System Serial is located on PI-5 bus (11x2 GPIO header).
  • TXD: Pin 6 (Yellow cable) (Connect to RXD on Serial adapter)
  • RXD: Pin 8 (Orange cable) (Connect to TXD on Serial adapter)
  • GND: Pin 10 (Black cable) (Connect to GND on Serial adapter)
The default baudrate is 1500000, note that not all serial adapters support this high baudrate.
Linux Image Releases
Stock BSP
BSP Linux ver 1.1 Build from SDK
BSP Linux ver 1.1 Build as USB Stick application from SDK
Factory Test Build
  • Factory Test Build by Gamiee
  • DD image (for 8GB microSD card or eMMC Module and above)
Linux BSP SDK
Linux BSP Kernel ver 1.1.7
Linux BSP Kernel ver 1.1 as USB Stick application
Other Resources
