SOEDGE
Revision as of 04:35, 12 May 2021 by Tllim (talk | contribs)
The SOEdge is a 3TOPS compute module that can be paired with the SOPine base board or USB 3.0 and PCIe adapters for development. It can connect to a SBC, such as the ROCKPro64 or a regular PC.
SOEdge Software Release
The SOEdge software releases can be found in the article SOEdge Software Release.
Under 'Guides for model A baseboard accessories' you can find instructions and guides concerning:
  • Enclosures
  • Bluetooth and WiFi module
  • Real Time Clock (RTC) battery
  • Real Time Clock (RTC) battery holder
  • First and third party cases
  • Featured 3D printed cases (and more)
SoC and Memory Specification
  • Dual-core ARM Cortex-A35 Processor@1600-2000Mhz
  • A power-efficient ARM 64-Bit Armv8-A architecture
  • AArch32 for full backward compatibility with Armv7
  • VFPv4 Floating Point Unit
  • TrustZone security technology
  • Neon Advanced SIMD
  • DSP and SIMD extensions
  • VFPv4 Floating point
  • 128KB L2 cache
Neural Process Unit NPU Capability
  • RAM Memory Variants: 2GB DDR4.
  • Storage Memory: SPI Flash and optional eMMC module from 16MB up to 128MB
SOEdge Baseboard Features
Network
  • 10/100/1000Mbps Etherne
Storage
  • USB - 2 USB2.0 Host port
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
  • PCIe 2x open ended slot
SOEdge Module and Baseboard Information, Schematics, and Certifications
  • Model "A" Baseboard Dimensions: 133mm x 80mm x 19mm
  • Input Power: DC 12V @ 3A 5.5OD/2.1ID Barrel DC Jack connector
SOEdge/SOPine Cluster Board Resource
Linux Image Releases
Stock BSP
BSP Linux ver 1.1 Build from SDK
BSP Linux ver 1.1 Build as USB Stick application from SDK
Factory Test Build
  • Factory Test Build by Gamiee
  • DD image (for 8GB micoSD card or eMMC Module and above)
Linux BSP SDK
Linux BSP Kernel ver 1.1
Linux BSP Kernel ver 1.1 as USB Stick application
Other Resources
