ROCKPro64 Software Release
Revision as of 10:57, 15 March 2021 by Wizzard (talk | contribs) (→‎Android Images: Slash TV)
Contents
Linux Images
Official Debian
As of April 2020 Debian have a ROCKPro64 image available. See forum thread here.
Instructions for creating a bootable image are in the README file on the Debian website, as at June 2020 these were in short
  • Download: firmware.rockpro64-rk3399.img.gz
  • Download: partition.img.gz
  • Create the disk image:
    • For Linux: zcat firmware.rockpro64-rk3399.img.gz partition.img.gz > complete_image.img
    • For Mac: gzcat firmware.rockpro64-rk3399.img.gz partition.img.gz > complete_image.img
  • Write the image to your boot device:
    • For Linux: dd if=complete_image.img of=your_chosen_boot_device bs=4M
    • For Mac: Etcher
What you now have is the official Debian installer that will boot and run on your ROCKPro64. You will need an Ethernet connection and to answer the various installer questions/options.
Manjaro ARM [microSD / eMMC Boot]
  • To learn more about Manjaro please visit Manjaro Forum
    • username: manjaro
    • password: manjaro
Manjaro KDE ARM Community Build Image [microSD / eMMC Boot]
Manjaro MATE ARM Community Build Image [microSD / eMMC Boot]
Manjaro XFCE ARM Community Build Image [microSD / eMMC Boot]
Manjaro I3 ARM Community Build Image [microSD / eMMC Boot]
Manjaro SWAY ARM Community Build Image [microSD / eMMC Boot]
Armbian
If your are booting from a Micro SD card than both Linux kernel versions will work but if you are trying to boot from an eMMC module then the 4.4.y will work but the newer 5.10.y will not.
  • Armbian pack as 7zip, please unzip first before dd.
Armbian Debian Buster XFCE Desktop [microSD / eMMC Boot]
Armbian Ubuntu Focal XFCE Desktop [microSD / eMMC Boot]
Armbian Ubuntu Bionic for Server and Light Desktop [microSD / eMMC Boot]
Armbian Ubuntu Focal for Server and Light Desktop [microSD / eMMC Boot]
AOSC
  • To learn more about AOSC, please visit the official AOSC website
  • AOSC using LZ4 compression algorithm, please visit the LZ4 github site for utility
  • 8GB microSD card or eMMC module and above
  • Login with
    • username: aosc
    • password: anthon
AOSC KDE Community Build Image [microSD and eMMC Boot]
AOSC GNOME Community Build Image [microSD and eMMC Boot]
AOSC MATE Community Build Image [microSD and eMMC Boot]
AOSC Cinnamon Community Build Image [microSD and eMMC Boot]
AOSC XFCE Community Build Image [microSD and eMMC Boot]
AOSC LXDE Community Build Image [microSD and eMMC Boot]
Twister OS
Twister OS Armbian-Reforged XFCE Dsktop beta images [SD boot]
Twister OS Monka-Manjaro XFCE Dsktop beta images [SD boot]
Ubuntu and Debian Release by ayufan
Forum thread concerning these releases can be found here
A number of release versions are available based on either Ubuntu or Debian. In addition releases are available that are stable (based on a 4.4 kernel which has all the RockChip patches in it) or pre-releases (based on the latest linux kernel). An overview of the philosophy is on this GitHub page.
Clicking through on any chosen release header (or expanding the "assets" section under the Changelog) will provide options to download many images suitable for the ROCKPro64 as well as others suitable for other devices such as the Rock64 and PinebookPro - please read the download filenames carefully to choose precisely the image you desire.
Debian Release by Mrfixit2001
Mrfixit has engineered 2 releases based on Debian.
Feature complete desktop release
Minimal Debian
Forum thread concerning this release can be found here
SkiffOS
Minimal cross-compiled OS optimized for hosting distributions in Docker containers.
Provides the reliability of firmware with the ease-of-use of package managers.
Uses the Buildroot cross-compilation tool for support for all Pine64 boards.
Use configuration packages to configure distro:
  • core/gentoo: Gentoo optimized for Rockpro64
  • core/nixos: NixOS arm64
You can also configure the skiff core yaml file to configure multiple distros to run in parallel.
The boot-up OS can be upgraded independently from the containers.
Download location
The repository and instructions can be found here.
Slackware
Slackware Aarch64 XFCE Community Build Image [microSD Boot]
Slackware Aarch64 Miniroot Community Build Image [microSD Boot]
  • To run the OS on eMMC
        • example : dd if=slack-current-aarch64-xfce_29Sep18-4.4.162-rockpro64-build-20181126.img of=/dev/mmcblk1 bs=10M
DietPi
OpenWrt
OpenWrt Snapshot Build [microSD Boot]
LibreELEC(KODI)
Official LibreElec KODI Build Image [microSD / eMMC boot]
OpenMediaVault
OpenMediaVault is the next generation network attached storage (NAS) solution, click this link to OMV main page to learn more.
Stretch 32bit (armhf) [microSD / eMMC Boot] [0.8.3]
Stretch 64bit (aarch64) [microSD / eMMC Boot] [0.8.3]
NextCloudPi
NextCloudPi Community Build Image [microSD / eMMC Boot] [03-10-19]
  • Visit the project's website
  • You can follow the ongoing discussion about NextCloudPi on the forum
  • Login with
    • username: root
    • password: 1234
Batocera Linux
Batocera Linux Community Build Image [microSD / eMMC Boot] [5.25-20200310]
Batocera Linux Community Build Image [microSD / eMMC Boot] [5.24-20191108]
Recalbox
Recalbox Community Build Image [microSD / eMMC Boot]
Retro Arena
Retro Arena Community Build Image [microSD / eMMC Boot] [Beta 0.0.8]
  • This is a BETA and therefore is not updatable nor supported however bugs or issues are appreciated to be identified and shared via the issues tab on our GitHub so that we can address them in the future. The Roshambo Case support is baked in with one major caveat due to kernel limitation: You can power the unit off by the POWER switch and the RESET button works 100% however to power the unit on you will need to manually plug/unplug the power cord. This limitation will not be present in future releases.
  • Visit the project's [1]
  • You can follow the ongoing discussion about Retro Arena on the forum
Nems Linux [No Longer Maintained]
  • Login with
    • Username: nemsadmin
    • Password: nemsadmin
NEMS Linux [microSD / eMMC Boot] [v1.5 - build 1]
CentOS [No Longer Maintained]
  • Centos-7.4.1708 with kernel from Armbian-5.67 (minimum build)
  • Login with
    • username: root
    • password: centos
BSD Images
NetBSD
To learn more about NetBSD please visit NetBSD main page
OpenBSD
Instructions to get OPenBSD on your ROCKPro64 are here.
Forum discussions are there.
Chromium OS
Chromium Community Build Image [microSD / eMMC Boot] [Beta (R76)]
  • To learn more please visit Forum
Android Images
Android 9.0.0
Stock for DD method [eMMC Boot] [20200804]
  • Use 'dd' to write the image to the eMMC module using the USB-to-eMMC adapter module and boot. Using Etcher or another specialized SD writing tool is preferred.
  • Supports new RockPro64 AP6256 Wifi/BT module
  • Support Sony IMX214 camera module and works on both MiPi-CSI ports
  • This build supports PINE64 7" LCD panel and UI follow tablet way (means not Android TV)
  • DD image for 8GB eMMC module
  • DD image for 16GB eMMC module
  • DD image for 32GB eMMC module
  • DD image for 64GB eMMC module
Stock for RK Flash tool [eMMC Boot] [20200804]
  • The OTG port located at USB type-C connector, needs USB type A to type C cable.
    • MD5 (GZip file): 9ac830527814521e15b009fa2503c9e3
    • File Size: 589MB
Stock for DD method [eMMC Boot] [20200708]
Stock for RK Flash tool [eMMC Boot] [20200708]
    • MD5 (GZip file): 6d060ddd47ebcfd5cfcdbf90ec042c97
    • File Size: 589MB
Stock for DD method [eMMC Boot] [20190427]
  • Please ignore "internal problem with your device" popup message if appear on Android boot-up page.
Stock for DD method [micro SD Boot] [20190506]
  • DD image for 8GB microSD card
  • DD image for 16GB microSD card
  • DD image for 32GB microSD card
  • DD image for 64GB microSD card
Stock for RK Flash tool [eMMC Boot] [20190427]
    • MD5 (GZip file): 046BA4A07933120809FBE1B9577B7341
    • File Size: 592MB
Android 8.1.0
Stock for DD method [eMMC Boot] [20180828]
    • MD5 (XZ file): 9AEE21BC1B9DE886DCB0E64FA123988A
    • File Size: 414MB
Stock for DD method [micro SD Boot] [20181212]
    • MD5 (XZ file): 5A6BB7FCD7B3F77FCEE99CE462AE7405
    • File Size: 616MB
Stock for RK Flash tool [eMMC Boot] [20180828]
    • MD5 (XZ file): 4DACFE927BB09EE9C56B5232A7F624EE
    • File Size: 415MB
Android 7.1.2
Stock for DD method [eMMC Boot] [20180809]
    • MD5 (XZ file): 00F194017557017C2588724686E90CEA
    • File Size: 498MB
Stock for RK Flash tool [eMMC Boot] [20180809]
    • MD5 (XZ file): 197A9905B48441D8655E7542F4643FE9
    • File Size: 483MB
Stock for DD method [micro SD Boot] [20180920]
    • MD5 (XZ file): CE39642A379B357BB3E4BC80ACA2E0CE
    • File Size: 765MB
Stock for DD method [eMMC Boot] [20180518]
    • MD5 (XZ file): 33622034ACDBC31A7D7BB01ED634E29B
    • File Size: 345MB
Stock for RK Flash tool [eMMC Boot] [20180518]
    • MD5 (XZ file): 90C1991DADAE13ADC94E927F171F8920
    • File Size: 342MB
Stock for install from SDcard to eMMC [microSD Boot] [20180921]
    • MD5 (XZ file): c6900e82a1d6ef397dcac241f76f43c9
    • File Size: 350MB
Android SDK
Android P SDK [v9.0]
Slash TV OS
Android 7 based system including Play Store, working only from SD card (does not boot when installed on eMMC)
For Linux Developer
The Ayufan github page
Below are the LPDDR4 driver for RK3399
ROCKPro64 related files
Miscellaneous tools
