ROCKPro64 Software Release
Contents
Linux Images
Please note recent release notes for all 0.7.x images below:
   0.7.9: Fix upgrade problem (u-boot-* packages),
   0.7.8: Improve eMMC compatibility on RockPro64,
   0.7.8: Disable sdio (no wifi/bt) to fix pcie/nvme support on 4.4 for RockPro64,
   0.7.8: Fix OMV builds (missing initrd.img),
   0.7.8: Make all packages virtual, conflicting and replacing making possible to do linux-rock64/rockpro64 to replace basesystem,
   0.7.7: Fix memory corruptions caused by Mali/Display subsystem (4.4),
   0.7.7: Enable SDR104 mode for SD cards (this requires u-boot upgrade if booting from SD),
   0.7.6: Change OPP's for Rock64 and RockPro64: ayufan-rock64/linux-kernel@4.4.132-1059-rockchip-ayufan...ayufan-rock64:4.4.132-1062-rockchip-ayufan,
   0.7.5: Various stability fixes for kernel and u-boot,
   0.7.5: Added memtest to kernels and extlinux,
   0.7.5: Show early boot log when booting kernels,
   0.7.4: Fix resize_rootfs.sh script to respect boot flags (fixes second boot problem introduced by 0.7.0),
   0.7.4: Add rock(pro)64_erase_spi_flash.sh,
   0.7.4: Fix cursor on desktop for rockpro64,
Armbian
Armbian Debian Stretch [microSD / eMMC Boot] [5.67]
  • Login with
    • username: root
    • password: 1234
Armbian Ubuntu 18.04 Bionic Desktop [microSD / eMMC Boot] [5.67]
  • Login with
    • username: root
    • password: 1234
Debian Stretch
Forum thread concerning this release can be found here
Minimal aarch64 [microSD / eMMC Boot] [0.7.9]
Ubuntu 18.04 Bionic
LXDE Desktop aarch64 [microSD / eMMC Boot] [0.7.9]
Minimal armhf [microSD / eMMC Boot] [0.7.9]
Containers aarch64 (DockerCE & Kubernetes) [microSD / eMMC Boot] [0.7.9]
Debian by mrfixit2001
Minimal Debian [microSD / eMMC Boot]
DietPi
DietPi Community Build Image [microSD / eMMC boot]
  • Login with
    • username: root
    • password: dietpi
Arch
Folks are working on getting Arch going here in the forum.
OpenMediaVault
OpenMediaVault is the next generation network attached storage (NAS) solution, click this link to OMV main page to learn more.
Stretch armhf [microSD / eMMC Boot] [0.7.9]
Stretch aarch64 [microSD / eMMC Boot] [0.7.9]
LibreELEC Nightly Build
These LibreElec images are Alpha releases, which means that it is not stable nor ready for prime-time use. New features or functionality are added weekly or monthly.
LibreElec KODI Community Build Image [microSD / eMMC boot] [NIGHTLY BUILD]
Slackware
Slackware Aarch64 Miniroot Community Build Image [microSD Boot] [20190201]
Slackware Aarch64 XFCE Community Build Image [microSD Boot] [20190201]
  • Login with
    • Username : root
    • Password : password
  • To run the OS on eMMC
        • example : dd if=slack-current-aarch64-xfce_29Sep18-4.4.162-rockpro64-build-20181126.img of=/dev/mmcblk1 bs=10M
Batocera Linux
Batocera Linux Community Build Image [microSD / eMMC Boot] [5.20-20190121]
Recalbox
Recalbox Community Build Image [microSD / eMMC Boot]
BSD Images
NetBSD
To learn more about NetBSD please visit NetBSD main page
OpenBSD
Instructions to get OPenBSD on your ROCKPro64 are here.
Forum discussions are there.
Android Images
Android 8.1.0
Stock for DD method [eMMC Boot] [20180828]
  • This build supports PINE64 7" LCD panel and UI follow tablet way (means not Android TV)
    • MD5 (XZ file): 9AEE21BC1B9DE886DCB0E64FA123988A
    • File Size: 414MB
Stock for RK Flash tool [eMMC Boot] [20180828]
  • The OTG port located at USB type-C connector, needs USB type A to type C cable.
    • MD5 (XZ file): 4DACFE927BB09EE9C56B5232A7F624EE
    • File Size: 415MB
Android 7.1.2
Stock for DD method [eMMC Boot] [20180809]
  • Highly recommend using Etcher or PINE64 Installer
    • MD5 (XZ file): 00F194017557017C2588724686E90CEA
    • File Size: 498MB
Stock for RK Flash tool [eMMC Boot] [20180809]
    • MD5 (XZ file): 197A9905B48441D8655E7542F4643FE9
    • File Size: 483MB
Stock for DD method [micro SD Boot] [20180920]
  • DD image to microSD card and boot.
    • MD5 (XZ file): CE39642A379B357BB3E4BC80ACA2E0CE
    • File Size: 765MB
Stock for DD method [eMMC Boot] [20180518]
    • MD5 (XZ file): 33622034ACDBC31A7D7BB01ED634E29B
    • File Size: 345MB
Stock for RK Flash tool [eMMC Boot] [20180518]
    • MD5 (XZ file): 90C1991DADAE13ADC94E927F171F8920
    • File Size: 342MB
Stock for install from SDcard to eMMC [microSD Boot] [20180921]
  • DD image to microSD card and boot. Highly recommend using Etcher or PINE64 Installer
    • MD5 (XZ file): c6900e82a1d6ef397dcac241f76f43c9
    • File Size: 350MB
Android SDK
Android Nougat [v7.1]
Android NN (Neural Network) SDK Release Note
For Linux Developer
The Ayufan github page
Below are the LPDDR4 driver for RK3399
ROCKPro64 related files
Miscellaneous tools
Top of page
