ROCKPro64
Revision as of 15:57, 31 August 2018 by Luke (Talk | contribs) (Software and OS Image Builds)
Jump to: navigation, search
The ROCKPro64 is the most powerful Single Board Computer released by Pine64. It is powered by a Rockchip RK3399 Hexa-Core (dual ARM Cortex A72 and quad ARM Cortex A53) 64-Bit Processor with MALI T-860 Quad-Core GPU. The ROCKPro64 is equipped with 2GB or 4GB LPDDR4 system memory and 128Mb SPI boot Flash. There is also an optional eMMC module (up to 128GB) and microSD slot for booting. The board is equipped with a PCIe x4 open ended slot, 1x USB 3.0 type C Host with DP 1.2, 1x USB 3.0 type A Host, 2x USB 2.0 Host, Gigabit Ethernet, PI-2 GPIO Bus, MiPi DSI interface, eDP interface, touch Panel interface, stereo MiPi CSI interface, as well as many other peripheral device interface such as UART, SPI, I2C, for makers to integrate with sensors and other peripherals. Various Operating Systems (OS) are made available by open source community. These include Android 7.1, Linux (Ubuntu, Debian, Arch) and many more to come.
Board layout
A hi-res picture of v2.1 front
A hi-res picture of v2.1 rear
Main chips
  • RK3399 system-on-chip (1)
  • LPDDR4 SDRAM 1 (18)
  • LPDDR4 SDRAM 2 (3)
  • SPI NOR flash memory (17)
  • ES8316 Sound Codec (on rear of board)
  • The heatsink mounting holes around the RK3399 are 59 mm apart
LEDs
A red LED behind the reset button is DIY - it is lit for example if the board is in OTG mode with an Ayufan image, or if an Android image is in standby mode.
Switches
The Reset button (10): perfoms a reset.
The Recover button (28): used to enter maskrom mode.
Connectors, sockets and headers
Diagram Schematic
designator
Silkscreen
label
Number
of pins
Description
2 U39 PI-2-bus 40 Pi-2 bus
4 J8 +FAN- 2 PWM controlled fan header
5 J10 SPDIF 3 SPDIF header
6 U6 +RTC- 2 RTC battery backup header
7 U31 Wifi-BT 16 SDIO WIFI/BT module-MIMO 2
8 USB3 9 USB-3 and USB Type C
9 USB1 2×4 Dual USB-2 (top is OTG)
12 IR1 IR 3 infrared receiver socket
13 J16 Headphone+mic 4 Headphone + mic 3.5mm jack
14 U29 EMMC 34 eMMC connector
14* J13 13 TF-card, a.k.a. microSD (* under 14 on the bottom side)
15 U30 14 SDIO WIFI/BT module-MIMO 1
19 J15 PCI 64 PCI-express X4 socket
20 J21 DSI 32 DSI
21 J22 EDP 32 LCD EDP
22 CON1 TP 6 touch panel connector
23 CON15 4 DC out for SATA disk cable (direct connect from DC-IN)
24 J11 DC-IN 2 Power input, positive tip; 12V/3A (minimum) recommended
25 U32 8 RJ45
26 J14 19 HDMI
27 J17 MIPI CAM 32 MIPI-1
29 J19 MIPI CAM 32 MIPI-2
30 J18 CIF 26 CIF
Jumpers
Disable eMMC
µSD eMMC SW4 boot
0 0 0 X
0 0 1 X
0 1 0 M
0 1 1 X
1 0 0 S
1 0 1 S
1 1 0 M
1 1 1 S
Disable SPI
There is a second possibility to jumper your ROCKPro64: If you mess-up your SPI and are unable to boot, it seems jumpering pins 23 (CLK) and 25 pin (GND) on the PI-2-bus header will disable the SPI as a boot device. (This was taken from the IRC logs, 09 August 2018 @ 17:23)
Getting Started
This section gives important information to get the board up and running.
Start here
In the 'ROCKPro64 Software Release' page you will find a complete list of currently supported Operating System images that work with the ROCKPro64 as well as other related software. The Software Release page has links to download the images as well as high level instructions how to load each image.
More advanced Linux bits
Some Linux tips are given below.
How to update your Linux
For Debian/Ubuntu images entering the following commands at a terminal prompt
sudo apt-get update
sudo apt-get upgrade
will keep your installation up to date. To update Ayufan images to the next release (when available) use the following command
sudo apt-get dist-upgrade
If you are happy to update your system to pre-releases of Ayufan images then modify /etc/apt/sources.list.d/ayufan-rock64.list as per the comment in that file.
The kernel in Ayufan releases is under active development and, if you wish to install a later version, then it is best to use a package manager. In synaptic (for example), if you search for package names linux-image-4.4 you should see your currently installed vesion(s) as well as any more recent ones. Similarly if you wish to install the mainline kernel then searching for linux-image-4.18 will show you what is available. At the time of writing (August 2018) there are significant features missing from the mainline kernel for aarch64 processors (e.g. HDMI sound).
Useful scripts
Video playback
Ayufan has some old documentation on video playback here. For your ROCKPro64 the install should be
sudo apt-get install ffmpeg mpv libmali-rk-midgard-t86x-r14p0-gbm
(These modules are included in the Ayufan deskop releases.) At which stage rkmpv myvideo.mp4 will play a fullscreen, hardware assisted, version of your video. rkmpv is at /usr/local/bin/rkmpv
Swapping kernel versions
extlinux is in use on Ayufan images (at least) which enables some switching between installed kernel versions - intro documentation is here. In particular after you install any additional kernels, you can edit your /boot/extlinux/extlinux.conf file to specify which of the kernels you have installed to use for the next boot.
Using an NVMe disk for rootfs
This section gives some hints for advanced users.
Setup a serial console
Booting from USB or PXE
OTG mode
You can boot your ROCKPro64 into OTG mode with the use of the Recover button (see switch 28 above.) Note there are 2 OTG ports on your ROCKPro64: the type-C USB 3 socket is definitely one. From the schematic it appears the USB 3 (type A) socket is the other, but this has yet to be confirmed.
The method is to power off the board. Then push and hold the Recover button and push and release the Power button.
  • If you have an Ayufan bootable image in either the SDcard or eMMC then there are 4 OTG modes described here. Releasing the Recover button as soon as the white LED lights counts as 1 blink. Keeping it pressed you will get 2 blinks of the white LED etc. Once the board enters OTG mode the red LED will be lit. In mode 1 the boot and linux-root partitions of the card with the Ayufan image (partitions 6 & 7 of a linux installation) are made available as devices. In all cases the USB device made available at the host has device ID 18d1:d00d.
  • If you do not have an Ayufan image in either the SDcard or the eMMC, then neither white nor red LEDs will light, but the board will enter MaskROM mode where the USB device made available at the host has device ID 2207:330c.
NVMe drives
SATA drives
Wi-Fi & Bluetooth module
If you have bought the Wi-Fi and Bluetooth module from the Pine store then instructions for connecting it can be found on the accessories page here. Please note that the 0.7.9 linux releases (August 2018) have deliberately DISABLED support for this module in the search for stability. It can be tested and used with the Android image.
7" LCD Touch Screen
Note at present (August 2018) this screen is only supported by the Android image.
RTC battery backup
The Pine store has a couple of options for RTC battery backups: a AAA version here or a CR-2032 version here. Instructions for plugging in either of them are also on the Accessories page
Acryllic open enclosure
Assembly instructions for the acryllic enclosure from the Pine store are also on the Accessories page
NAS case
The Exploded View Installation Diagram for the NAS casing from the Pine store
Under ROCK64_Software_Release you will find a complete list of currently supported Operating System images that work with the ROCKPro64 as well as other related software.
Board Features
SoC and Memory Specification
  • Based on Rockchip RK3399
  • Cortex-A72:
    • DSP & SIMD extensions
    • VFPv4 floating point
  • Cortex-A53:
GPU Architecture
  • Frequency 650MHz
Display
Video
  • 4K HDR @ 30fps
  • VP9, up to 4Kx2K @ 60fps
Audio
  • 3.5mm Phone Jack
  • 3-pin S/PDIF header
  • Audio via HDMI
Camera
Network
  • 10/100/1000Mbps Ethernet
  • Wi-Fi 802.11 ac/a/b/g/n with Bluetooth 4.01 (optional)
Storage
  • 1 USB3.0 Host port
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
  • Certifications:
The NAS Case for the ROCKPro64
Please follow this this link for detailed instructions on how to assemble the ROCKPro64 NAS Case.
Other Resources
