ROCKPro64 Hardware compatibility
Revision as of 02:11, 22 July 2020 by Lrissman (talk | contribs) (→‎PCIe devices: Added support for Ziyituod SATA Card)
ROCKPro64 accessories - by type
PCIe devices
Type Make/Model Hardware IDs Kernel Result Notes
NIC Intel I350 Dual Port Mainline-5.4 good SR-IOV fails
NIC Intel X520 Dual Port 8086:10fb Mainline-5.6 good SR-IOV fails
NIC Intel 82571EB Dual Port (HP NC360T) Mainline-5.6 crash kernel crash on boot
GPU nVidia GTX-645 Mainline-5.4 crash BAR size too small, triggers PCIe error handling bug
PCIe Switch PCIE-EUX1-04 Ver.002 Mainline-5.4 good
SATA Controller ASM1062 4-Port Mainline-5.6 good tested only with one disk attached
SATA Controller ASM1062 (rev 02) 4-Port 1d87:0100 Ayufan-4.4.190 good tested with four disks, 3 in raid 5
SATA Controller Ziyituod SATA Card ASM 1062+1093 6-Port 1b21:0625 Mainline-4.4 (armbian) good tested with 6 disks Host Bus Adapter LSI SAS 9211-4i 1000:0070 Ayufan-4.4.197 good tested with four disks attached
NVMe SSD drives
Type Make/Model Size Hardware IDs Kernel Result Notes Power options
Active only
Save
power
setting?
NVMe Samsung 970 Evo 500 GB Mainline-5.6 good - defaults defaults
USB hardware
USB C alternate mode DP
Note that only USB C alternate mode Display Port will pass video. Any HDMI, DVI or VGA port must be converted internally by the device from Display Port - or the device won't work for video.
Other hardware
