ROCKPro64 Hardware compatibility
Revision as of 20:54, 23 April 2020 by Pgwipeout (talk | contribs) (Creating ROCKPro64 Hardware Accessory Compatibility Page)
ROCKPro64 accessories - by type
PCIe devices
Type Make/Model Hardware IDs Kernel Result Notes
NIC Intel I350 Dual Port Mainline-5.4 good SR-IOV fails
NIC Intel X520 Dual Port 8086:10fb Mainline-5.6 good SR-IOV fails
GPU nVidia GTX-645 Mainline-5.4 crash BAR size too small, Triggers PCIe Error Handling bug
PCIe Switch PCIE-EUX1-04 Ver.002 Mainline-5.4 good
NVMe SSD drives
Type Make/Model Size Hardware IDs Kernel Result Notes Power options
Active only
Save
power
setting?
USB hardware
USB C alternate mode DP
Note that only USB C alternate mode Display Port will pass video. Any HDMI, DVI or VGA port must be converted internally by the device from Display Port - or the device won't work for video.
Other hardware
