ROCKPro64 Hardware compatibility
ROCKPro64 accessories - by type
PCIe devices
Type Make/Model Hardware IDs Kernel Result Notes
NIC Intel I350 Dual Port Mainline-5.4 good SR-IOV fails
NIC Intel I350 Quad Port ?
NIC Intel X520 Dual Port 8086:10fb Mainline-5.6 good SR-IOV fails
NIC Intel X550-T2 Dual Port 8086:1563 5.15.0-trunk-arm64 (Debian) good netperf throughput in FW mode, 20 streams: between 4136-6613mb/s across use cases.
NIC Intel 82571EB Dual Port (HP NC360T) Mainline-5.6 crash kernel crash on boot
NIC Intel 82575/82576 8086:1521 OpenWrt 21.02-rc1 ; 5.4.111-1 good opkg: kmod-igb ; OpenWrt 21.02-rc1 5.4.111-1 ; ~92.8 KB ; Kernel modules for Intel(R) 82575/82576 PCI-Express Gigabit Ethernet adapters.
GPU nVidia GTX-645 Mainline-5.4 crash BAR size too small, triggers PCIe error handling bug
PCIe Switch PCIE-EUX1-04 Ver.002 Mainline-5.4 good
SATA Controller ASM1062 4-Port Mainline-5.6 good tested only with one disk attached
SATA Controller ASM1062 (rev 02) 4-Port 1d87:0100 Ayufan-4.4.190 good tested with four disks, 3 in raid 5
SATA Controller IOCrest (Same as Syba?) SI-PEX40063 4-port, Marvell 88SE9235 chip 1b4b:9235 Debian unstable 5.7, 5.8 good Tested with two disks. SATA errors occurred with a WD Red drive in a cheap enclosure; resolved by connecting the same drive directly to the card.
SATA Controller Ziyituod SATA Card ASM 1062+1093 6-Port 1b21:0625 Mainline-4.4 (armbian) good tested with 6 disks
SATA Controller BEYMEI RAID 4-Port, Marvell 88SE9230 chip 1b4b:9230 Ayufan-5.6.0-1137 good Tested with 3 disks in RAID 5. I added pci=nomsi to /boot/extlinux/extlinux.conf kernel parameters and an udev rule before the disks were recognized: ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x1b4b", ATTR{device}=="0x9230", RUN+="/bin/bash -c 'echo %k > /sys/bus/pci/drivers/ahci/bind'"
SATA Controller QNINE 4-Port, Marvell 88SE9215 chip Ayufan-5.6.0-1137 very slow Tested with 3 disks in RAID 5. Top speeds were around 50 MiB/s but quickly dropped to below 2 MiB/s due to SATA CRC errors
Host Bus Adapter LSI SAS 9211-4i 1000:0070 Ayufan-4.4.197 good tested with four disks attached
USB Controller ASMedia Technology Inc. ASM1142 USB 3.1 Host Controller 1b21:1242 Mainline-5.15.0-rc5 good
NVMe SSD drives
Type Make/Model Size Hardware IDs Kernel Result Notes Power options
Active only
Save
power
setting?
NVMe Samsung 970 Evo 500 GB Mainline 5.6 good - defaults defaults
NVMe Samsung 960 Evo 500 GB 144d:a804 Mainline 5.13-rc4 doesn't work Likely due to 64/32 BAR mismatch issue on Linux 5.11+ defaults defaults
USB hardware
USB C alternate mode DP
Note that only USB C alternate mode Display Port will pass video. Any HDMI, DVI or VGA port must be converted internally by the device from Display Port - or the device won't work for video.
Other hardware
