ROCKPro64
Revision as of 09:42, 21 August 2018 by Dukla2000 (talk | contribs) (→‎NVMe drives: add top)
ROCKPro64
The ROCKPro64 is the most powerful Single Board Computer released by Pine64. It is powered by a Rockchip RK3399 Hexa-Core (dual ARM Cortex A72 and quad ARM Cortex A53) 64-Bit Processor with MALI T-860 Quad-Core GPU. The ROCKPro64 is equipped with 2GB or 4GB LPDDR4 system memory and 128Mb SPI boot Flash. There is also an optional eMMC module (up to 128GB) and microSD slot for booting. The board is equipped with a PCIe x4 open ended slot, 1x USB 3.0 type C Host with DP 1.2, 1x USB 3.0 type A Host, 2x USB 2.0 Host, Gigabit Ethernet, PI-2 GPIO Bus, MiPi DSI interface, eDP interface, touch Panel interface, stereo MiPi CSI interface, as well as many other peripheral device interface such as UART, SPI, I2C, for makers to integrate with sensors and other peripherals. Various Operating Systems (OS) are made available by open source community. These include Android 7.1, Linux (Ubuntu, Debian, Arch) and many more to come.
ROCKPro64 Board layout
There is a hi-res photo of a v2.1 ROCKPro64 Media:ROCKPro64v21.jpg
SoC and memory
  • RK3399 system-on-chip (1)
  • LPDDR4 SDRAM 1 (18)
  • LPDDR4 SDRAM 2 (3)
  • SPI NOR flash memory (17)
LEDs
A red LED behind the reset button comes on if there is an error condition.
Switches
The reset button (10): perfoms a reset.
The recover button (28): Ayufan has documented the usage here. Note the OTG port on your ROCKPro64 is the top USB2 socket.
Connectors, sockets and headers
Diagram Silkscreen label Description
2 PI-2-bus 40-pin Pi-2 bus
4 +FAN- 2-pin PWM controlled fan header
5 SPDIF 3-pin SPDIF header
6 +RTC- 2-pin RTC battery backup header
7 Wifi-BT 16-pin SDIO WIFI/BT module-MIMO 2
8 USB-3 and USB Type C
9 Dual USB-2 (top is OTG)
12 IR 3-pin infrared receiver socket
13 Headphone+mic Headphone + mic 3.5mm jack
14 EMMC 34-pin eMMC connector
(14) 13-pin TF-card, a.k.a. microSD (under 14 on the bottom side)
15 14-pin SDIO WIFI/BT module-MIMO 1
19 PCI 64-pin PCI-express X4 socket
20 DSI 32-pin DSI
21 EDP 32-pin LCD EDP
22 TP 6-pin touch panel connector
23 DC out for SATA disk cable (direct connect from DC-IN)
24 DC-IN Power input +ve tip. 12V 3A (minimum) recommended
25 RJ45
26 HDMI
27 MIPI CAM 32-pin MIPI-1
29 MIPI CAM 32-pin MIPI-2
30 CIF 26-pin CIF
Jumpers
µSD eMMC SW4 boot
0 0 0 X
0 0 1 X
0 1 0 M
0 1 1 X
1 0 0 S
1 0 1 S
1 1 0 M
1 1 1 S
There is a second possibility to jumper your ROCKPro64: If you mess-up your SPI and are unable to boot, it seems jumpering pins 23 (CLK) and 25 pin (GND) on the PI-2-bus header will disable the SPI as a boot device. (This was taken from the IRC logs, 09 August 2018 @ 17:23)
ROCKPro64 Software Images
In the 'ROCKPro64 Software and OS Image Download Section' you will find a complete list of currently supported Operating System images that work with the ROCKPro64 as well as other related software.
Getting started - Android
Please see the NOOB page for detailed instructions to get your RockPro64 running Android.]
Getting started - Linux
There are a couple of distribution options available:
Folks are working on getting Arch going here in the forum.
Please see the NOOB page for detailed instructions to get your RockPro64 running linux.]
How to update your linux
For Debian/Ubuntu images apt-get update/upgrade will keep the distribution up to date.
Should also update Ayufan images to next release when available (modify /etc/apt/sources.list.d/ayufan-rock64.list if you want to pick up pre-releases)
Need to manually install pre-release kernel versions - best to use package manager (e.g. synaptic) (need to clarify this point)
More advanced Linux bits
After you install an Ayufan image you will find some scripts in /usr/local/sbin/ that may be useful. (Need to expand this section)
Ayufan has some old documentation on video playback here. (Of course for RockPro64 you need midgard modules - this section to be updated.)
extlinux is in use on Ayufan images (at least) which enables some switching between installed kernel versions - intro documentation is here.
Getting started - BSD
There are numerous *BSDs available for the RockPro64. Instructions to get OPenBSD on your ROCKPro64 are here.
Forum discussions are there.
Forum discussions on NetBSD are here. You can learn more about *BSD here.
NVMe drives
Top of page
Board Features
SoC and Memory Specification
  • Based on Rockchip RK3399
  • Cortex-A72:
    • DSP & SIMD extensions
    • VFPv4 floating point
  • Cortex A53:
GPU Architecture
  • Frequency 650MHz
Display
Video
  • 4K HDR @ 30fps
  • VP9, up to 4Kx2K @ 60fps
Audio
  • 3.5mm Phone Jack
  • Audio via HDMI
Camera
Network
  • 10/100/1000Mbps Ethernet
Storage
  • 1 USB3.0 Host port
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
  • ROCKPro64 Certifications:
Other Resources
Top of page
