ROCKPro64
Revision as of 18:52, 17 August 2018 by Lucho (talk | contribs) (→‎ROCKPro64 Board layout: it turned out that the version without "1" is OK, it must have been my browser's cache that's not updated)
ROCKPro64
The ROCKPro64 is the most powerful Single Board Computer released by Pine64. It is powered by a Rockchip RK3399 Hexa-Core (dual ARM Cortex A72 and quad ARM Cortex A53) 64-Bit Processor with MALI T-860 Quad-Core GPU. The ROCKPro64 is equipped with 2GB or 4GB LPDDR4 system memory and 128Mb SPI boot Flash. There is also an optional eMMC module (up to 128GB) and microSD slot for booting. The board is equipped with a PCIe x4 open ended slot, 1x USB 3.0 type C Host with DP 1.2, 1x USB 3.0 type A Host, 2x USB 2.0 Host, Gigabit Ethernet, PI-2 GPIO Bus, MiPi DSI interface, eDP interface, touch Panel interface, stereo MiPi CSI interface, as well as many other peripheral device interface such as UART, SPI, I2C, for makers to integrate with sensors and other peripherals. Various Operating System (OS) are made available by open source community such Android 7.1, Linux (Ubuntu, Debian, Arch) and many more to come.
SoC and memory
  • RK3399 system-on-chip (1)
  • LPDDR4 SDRAM 1 (17)
  • LPDDR4 SDRAM 2 (3)
  • SPI NOR flash memory (16)
LEDs
A red LED behind the reset button comes on if there is an error condition.
Switches
The reset button (10): perfoms a reset.
The recover button (27): Ayufan has documented the usage here. Note the OTG port on your ROCKPro64 is the top USB2 socket.
Connectors, sockets and headers
  • Power (23): 12V/3A minimum (positive tip)
  • HDMI (25)
  • RJ45 (24)
  • Dual USB-2 (9)
  • USB-3 and USB Type C (8)
  • Headphones+mic jack (12)
  • 34 pin eMMC connector (13)
  • 13 pin TF-card, a.k.a. microSD (under 13 on the bottom side)
  • 64 pin PCI-express socket (18)
  • 40 pin Pi-2 bus (2)
  • 14 pin SDIO WIFI/BT module-MIMO 1 (14)
  • 16 pin SDIO WIFI/BT module-MIMO 2 (7)
  • 4 pin DC IN (22): 12V for SATA disk cable
  • 2 pin fan (4): PWM controlled fan header
  • 3 pin SPDIF (5)
  • 2 pin RTC (6)
  • 8 pin touch-screen (21)
  • 32 pin EDP (20)
  • 32 pin DSI (19)
  • 26 pin CIF (29)
  • 32 pin MIPI-1 (26)
  • 32 pin MIPI-2 (28)
Jumpers
There is an unlabelled (on the PCB silk-screen) 2-pin jumper (15) between the eMMC socket (13) and the SPI chip (16). The default condition is OPEN (no jumper). It is useful for controlling the boot as follows:
ROCKPro64 Software Images
In the 'ROCKPro64 Software and OS Image Download Section' you will find a complete list of currently supported Operating System images that work with the ROCKPro64 as well as other related software.
Getting started - Android
Please see the NOOB page for detailed instructions to get your RockPro64 running Android.]
Getting started - Linux
There are a couple of distribution options available:
Folks are working on getting Arch going here in the forum.
Please see the NOOB page for detailed instructions to get your RockPro64 running linux.]
How to update your linux
For Debian/Ubuntu images apt-get update/upgrade will keep the distribution up to date.
Should also update Ayufan images to next release when available (modify /etc/apt/sources.list.d/ayufan-rock64.list if you want to pick up pre-releases)
Need to manually install pre-release kernel versions - best to use package manager (e.g. synaptic) (need to clarify this point)
More advanced linux bits
After you install an Ayufan image you will find some scripts in /usr/local/sbin/ that may be useful. (Need to expand this section)
Ayufan has some old documentation on video playback here. (Of course for RockPro64 you need midgard modules - this section to be updated.)
extlinux is in use on Ayufan images (at least) which enables some switching between installed kernel versions - intro documentation is here.
Getting started - BSD
Instructions to get BSD on your ROCKPro64 are here.
Forum discussions are there.
NVMe drives
Board Features
SoC and Memory Specification
  • Based on Rockchip RK3399
  • Cortex-A72:
    • DSP & SIMD extensions
    • VFPv4 floating point
  • Cortex A53:
GPU Architecture
  • Frequency 650MHz
Display
Video
  • 4K HDR @ 30fps
  • VP9, up to 4Kx2K @ 60fps
Audio
  • 3.5mm Phone Jack
  • Audio via HDMI
Camera
Network
  • 10/100/1000Mbps Ethernet
Storage
  • 1 USB3.0 Host port
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
  • ROCKPro64 Certifications:
Other Resources
