ROCKPro64
Revision as of 02:29, 11 May 2018 by Pfeerick (Talk | contribs) (ROCKPro64)
Jump to: navigation, search
ROCKPro64
ROCKPro64 ROCKPro64 is the most powerful Single Board Computer released by Pine64. Its powered by a Rockchip RK3399 Hexa-Core (dual ARM Cortex A72 and quad ARM Cortex A53) 64-Bit Processor with MALI T-860 Quad-Core GPU. The ROCKPro64 is equipped with 4GB LPDDR4 system memory and 128Mb SPI boot Flash. There is also an optional eMMC module (up to 128GB) and microSD slot for booting. The board is equipped with a PCIe x4 open ended slot, 1x USB 3.0 type C Host with DP 1.2, 1x USB 3.0 type A Host, 2x USB 2.0 Host, Gigabit Ethernet, PI-2 GPIO Bus, MiPi DSI interface, eDP interface, touch Panel interface, stereo MiPi CSI interface, as well as many other peripheral device interface such as UART, SPI, I2C, for makers to integrate with sensors and other peripherals. Various Operating System (OS) are made available by open source community such Android 7.1, Debian, Arch Linux and many more to come.
File:ROCKPro64 sideimg.jpg
ROCKPro64 Software Images
ROCKPro64
Under 'ROCKPro64 Software and OS Image Download Section' you will find a complete list of currently supported Operating System images that work with the ROCKPro64 as well as other related software. The list includes OS images and descriptions of:
Android (ETA 15th May)
SoC and Memory Specification
  • Based on Rockchip RK3399
  • Big.Little architecture: Dual Cortex-A72 + Quad Cortex-A53, 64-bit CPU
  • Cortex-A72:
    • DSP & SIMD extensions
    • VFPv4 floating point
  • Cortex A53:
GPU Architecture
  • Frequency 650MHz
Board Features
Display
  • HDMI 2.0 for 4K 60Hz with HDCP 1.4/2.2
Video
Audio
  • 3.5mm Phone Jack
Camera
Network
  • 10/100/1000Mbps Ethernet
Storage
  • 1 USB3.0 Host port
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
  • ROCK64 Certifications:
Other Resources
