ROCKPro64
Revision as of 20:22, 12 April 2023 by Fxc (talk | contribs) (→‎Board Layout: fix)
The ROCKPro64
The ROCKPro64 is the most powerful Single Board Computer released by PINE64. It is powered by a Rockchip RK3399 Hexa-Core (dual ARM Cortex A72 and quad ARM Cortex A53) 64-Bit Processor with a Mali T-860 Quad-Core GPU. The key features include a PCIe x4 open ended slot, the use of LPDDR4 RAM, and industry standard heatsink mounting holes.
The ROCKPro64 is equipped with 2GB or 4GB LPDDR4 system memory, and 128Mb SPI boot Flash. There is also an optional eMMC module (up to 128GB) and microSD slot for booting. The board is equipped with 1x USB 3.0 type C Host with DP 1.2, 1x USB 3.0 type A Host, 2x USB 2.0 Host, Gigabit Ethernet, PI-2 GPIO Bus, MiPi DSI interface, eDP interface, touch Panel interface, stereo MiPi CSI interface, as well as many other device interfaces such as UART, SPI, I2C, for makers to integrate with sensors and other peripherals. Many different Operating Systems (OS) are freely available from the open source community, such as Android, Linux (Ubuntu, Debian, Arch), and BSD.
Getting Started
The article ROCKPro64 Getting Started gives important information to get the board up and running.
Software releases
In the ROCKPro64 Software Releases page, you will find a complete list of currently supported Operating System images that work with the ROCKPro64, as well as other related software. The Software Release page has links to download the images as well as high level instructions to load each image.
Please see the Getting started page for detailed discussion of what you need (prerequisites) as well as instructions if the high level instructions are insufficient.
Board Layout
A hi-res picture of v2.1 rear.
A thermal image of v2.1 front (upside-down).
An annotated ROCKPro64
Main Chips
  • RK3399 system-on-chip (1)
  • LPDDR4 SDRAM 1 (18)
  • LPDDR4 SDRAM 2 (3)
  • SPI NOR flash memory (17)
  • ES8316 Sound Codec (on rear of board)
  • The heatsink mounting holes around the RK3399 are 59 mm apart
Switches
The Power button (11, SW3): is the same as on your mobile phone - press and release after about 1 second to power on. Press and hold for about 3 seconds to power off.
The Reset button (10, SW901): performs a reset.
The Recover button (28, SW900): used to enter maskrom mode.
Connectors, Sockets and Headers
Diagram Schematic
designator
Silkscreen
label
Number
of pins
Description
2 U39 PI-2-bus 40 Pi-2 bus
4 J8 +FAN- 2 PWM controlled fan header
5 J10 SPDIF 3 SPDIF header
6 U6 +RTC- 2 RTC battery backup header
7 U31 Wifi-BT 16 SDIO WIFI/BT module-MIMO 2
8 USB3 9 USB-3 and USB Type C
9 USB1 2×4 Dual USB-2
12 IR1 IR 3 infrared receiver socket
13 J16 Headphone+mic 4 Headphone + mic 3.5mm jack
- CON16 GND PWR RST GND 4 Power & reset, unpopulated
header near Headphone jack
14 U29 EMMC 34 eMMC connector
14* J13 13 TF-card, a.k.a. microSD
(* under 14 on the bottom side)
15 U30 14 SDIO WIFI/BT module-MIMO 1
16 SW4 2 Jumper to #Disable eMMC
19 J15 PCI 64 PCI-express X4 socket
20 J21 DSI 30 DSI
21 J22 EDP 30 LCD EDP
22 CON1 TP 6 touch panel connector
23 CON15 4 DC out for SATA disk cable
(direct connect from DC-IN)
24 J11 DC-IN 2 Power input, positive tip;
12V/3A (minimum) recommended
25 U32 8 8P8C (often referred to as 'RJ45')
26 J14 19 HDMI
27 J17 MIPI CAM 32 MIPI-1
29 J19 MIPI CAM 32 MIPI-2
30 J18 CIF 26 CIF
LEDs
A red LED behind the reset button is DIY - it is lit for example if the board is in OTG mode with an Ayufan image, or if an Android image is in standby mode.
Jumpers
Disable eMMC
The possible combinations are summarised in the table below.
  • 1 = present
  • 0 = not present
µSD eMMC SW4 boot from
0 0 0 unsupported
0 0 1 unsupported
0 1 0 eMMC
0 1 1 unsupported
1 0 0 SDCard
1 0 1 SDCard
1 1 0 eMMC
1 1 1 SDCard
Disable SPI (while booting)
There is a second possibility to jumper your ROCKPro64: If you mess-up your SPI and are unable to boot, jumpering pins 23 (CLK) and 25 pin (GND) on the PI-2-bus header will disable the SPI as a boot device. (This was taken from the IRC logs, 09 August 2018 @ 17:23) You have to remove the jumper 2 seconds after having started your RP64 (before the white LED turns ON) otherwise the SPI will be missing and you won't be able to flash it. Ayufan images contain (at the moment) only one script for the SPI and the RP64, it's "rockpro64_reset_spi_flash". Other SPI scripts are dedicated to the R64 (as it is written on the name) and it will mess-up your RP64 SPI if you use them.
Hardware Compatibility
The hardware compatibility list can be found under ROCKPro64 Hardware compatibility.
Board Features
SoC and Memory Specification
  • Based on Rockchip RK3399
  • Cortex-A72:
    • DSP & SIMD extensions
    • VFPv4 floating point
  • Cortex-A53:
GPU Architecture
  • The highest performance GPUs built on Arm Mali’s famous Midgard architecture, the Mali-T860 GPU is designed for complex graphics use cases and provides stunning visuals for UHD content.
  • Frequency: 650MHz
  • Throughput: 1300Mtri/s, 10.4Gpix/s
  • OpenGL® ES 1.1, 1.2, 2.0, 3.1, 3.2, Vulkan 1.0*, OpenCL™ 1.1, 1.2, DirectX® 11 FL11_1, RenderScript™.
Display
  • Dual VOP: one supports resolutions up to 4096x2160 and AFBC; the other supports resolutions up to 2560x1600
  • eDP 1.3 (4 lanes with 10.8Gbps) to support displays, with PSR
Video
  • 4K HDR @ 30fps
  • VP9, up to 4Kx2K @ 60fps
Audio
  • 3.5mm Phone Jack
  • 3-pin S/PDIF header
  • Audio via Digital Video port
Camera
  • Dual MIPI CSI,dual ISP, maximum input resolution of 13M pixels
Network
  • 10/100/1000Mbps Ethernet - Capable of pushing 941 MBit/s in iperf3
  • Wi-Fi 802.11 ac/a/b/g/n with Bluetooth 4.01 (old version with 2x2) / Bluetooth 5 (new version with 1x1) (optional)
Storage
  • 1 USB3.0 Host port
  • 2 USB2.0 Dedicated Host ports
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
GPIO Pins
Assigned To Pin Nr. Pin Nr. Assigned To
3.3 V 1 2 5 V
GPIO1_C4 (I2C8_SDA) a 3 4 5 V
GPIO1_C5 (I2C8_SCL) a 5 6 GND
GPIO4_D0 (CPU_GPCLK) 7 8 GPIO4_C4 (UART2_TX)
GND 9 10 GPIO4_C3 (UART2_RX)
GPIO1_C6 11 12 GPIO3_D0 (I2S0_CLK)
GPIO1_C2 13 14 GND
GPIO1_A1 15 16 GPIO1_A4
3.3 V 17 18 GPIO4_C5 [SPDIF]
[UART4_TX] GPIO1_B0 (SPI1_TXD) 19 20 GND
[UART4_RX] GPIO1_A7 (SPI1_RXD) 21 22 GPIO4_D1
GPIO1_B1 (SPI1_CLK) 23 24 GPIO1_B2 (SPI1_CSN0)
GND 25 26 GPIO1_B5
GPIO1_B3 (I2C4_SDA) 27 28 GPIO1_B4 (I2C4_SCL)
GPIO4_D3 29 30 GND
GPIO4_D4 31 32 GPIO3_D4 (I2S0_SDI1SDO3)
GPIO3_D5 (I2S0_SDI2SDO2) 33 34 GND
GPIO3_D2 (I2S0_LRCKTX) 35 36 GPIO3_D6 (I2S0_SDI3SDO1)
GPIO3_D1 (I2S0_LRCKRX) 37 38 GPIO3_D3 (I2S0_SDI0)
GND 39 40 GPIO3_D7 (I2S0_SDO0)
Notes
  • pulled high to 3.3V through 2.2kOhm resistor
Linux /dev/gpiochip Assignments
Pin Nr. 3 5 7 8 10 11 12 13 15 16 18 19 21 22 23 24 26 27 28 29 31 32 33 35 36 37 38 40
Chip 1 1 4 4 4 1 3 1 1 1 4 1 1 4 1 1 1 1 1 4 4 3 3 3 3 3 3 3
Line 20 21 24 20 19 22 24 18 1 4 21 8 7 25 9 10 13 11 12 27 28 28 29 26 30 25 27 31
On Linux, using the new /dev/gpiochip API, the n in GPIOn_XX appears to correlate to the number of the /dev/gpiochipn, and the XX to the definition RK_PXX of lines in include/dt-bindings/pinctrl/rockchip.h of the Linux kernel source. Having these named in the dts would be nice.
You can use libgpiod to drive them, and test them with the included tools (gpioinfo, gpioset, ...)
For example, gpioset 4 25=1 (run as root) would turn pin 22 on. Do beware that poking the wrong GPIO pin can lock up your system.
The conversion table at right is also available as a C header file.
Working Features
Feature/Option Android Android Version Linux Linux Version Test/Verify Steps Notes Product Link
PINE64 LCD Touchscreen (Screen/Touch) Yes/Yes No/No Maybe this will help get this working? 7″ LCD Touch Screen Panel
Wireless
ROCKPro64 2×2 MIMO Dual Band WiFi 802.11AC / Bluetooth 4.2 Module (old) ROCKPro64 1x1 Dual Band WiFi 802.11AC / Bluetooth 5.0 Module (new)
Yes/Yes No/No In 0.7.9 Ayufan linux releases this is deliberately disabled for stability reasons. ROCKPro64 1x1 Dual Band WiFi 802.11AC / Bluetooth 5.0 Module
USB OTG use this script: rockpro64_enable_otg.sh, then configure ip on usb0: ifconfig usb0 169.169.222.222 and run iperf, you should likely see about 200-300MB/s ROCKPro64_Main_Page#OTG_mode
USB Mass Storage USB2/USB3 Yes/yes Yes/Yes
Dedicated Fan Power (pwm1) Yes You might want to use ATS.
GPIO pins (raw or via RPI python scripts) Check out what Frank Mankel has done.
MIPI CSI Camera 1 and 2
eDP
HDMI Audio Yes 7.1.2 Yes 4.4.132-1083 - 4.4.138-1100 Stopped working in 4.4.154.1105. Ayufan is looking into it.
3.5mm Audio/Mic
USB-C Host
Display via USB-C Yes 7.x and 8.x eDP via USB-C per tillim. No sound on Android 7.x. Sound does work on Android 8.x
ROCKPro64 PLAYBOX ENCLOSURE N/A N/A N/A Ventilation does not exist, thus requires manual changes to add venting. Case should be modified to account power adapter not being centered in cut holes. Opening the case once close without modifying it first is near impossible without special tools. Graphene heatsink is included and does well for Linux but not Android. https://pine64.com/?product=rockpro64-playbox-enclosure
ROCKPro64 30mm Tall Profile Heatsink N/A N/A N/A https://store.pine64.org/?product=rockpro64-heatsink
ROCKPro64 20mm Mid Profile Heatsink N/A N/A N/A https://pine64.com/?product=rockpro64-20mm-mid-profile-heatsink
Fan For ROCKPro64 20mm Mid Profile Heatsink N/A N/A N/A You might want to use fanctl to control the fan while keeping your CPU cool https://pine64.com/?product=fan-for-rockpro64-20mm-mid-profile-heatsink
HDMI output 4K@60Hz
PCIe 2.1
Real Time Clock (RTC) battery backup https://store.pine64.org/?product=rtc-backup-battery-cr-battery
Boot from USB/PXE
RockChip themselves have tables of supported features at 4.4 and mainline kernel versions in their wiki here.
Certifications:
  • Disclaimer: Please note that PINE64 SBC is not a "final" product and in general certification is not necessary. However, PINE64 still submit the SBC for FCC, CE, and ROHS certification and obtain the certificates to proof that SBC board is capable on passing the testing. Please note a final commercial product needs to performs its owns testing and obtains its owns certificates.
  • ROCKPro64 FCC Certificate
  • ROCKPro64 CE Certificate
  • ROCKPro64 RoHS Report
Rockchip RK3399 SoC information:
LPDDR4 (200 Balls) SDRAM:
eMMC information:
SPI NOR Flash information:
Heatsink related info:
Wireless related info:
Ethernet related info:
Peripheral related info:
Remote control button mapping:
Audio Codec (ES8316) (under board):
PWM controlled fan, SPDIF, and RTC Battery Backup headers:
Useful Articles and Blog Posts
The NAS Case for the ROCKPro64
Please follow this this link for detailed instructions on how to assemble the ROCKPro64 NAS Case.
The NAS Case instructions also contains detailed information about:
  • what the NAS Case ships with
  • What additional things you need to purchase for your NAS Case
  • What optional things you can consider purchasing for your NAS build
  • What OS Image we recommend you use for your NAS build
  • IO accessibility after installing the ROCKPro64 into the NAS Case
  • NAS Case Exploded View
  • NAS Case Drawing
3D printable ITX mounting brackets
A Quartz64-A mounted in an ITX case using 3D printed brackets
Allows mounting a ROCKPro64-A or Quartz64-A board inside a regular PC case that conforms to the ITX standard, using 3D printed brackets:
  • AMF/STL/STEP files plus the original FreeCAD file used to create the models File:RP64-A Q64-A to ITX mounting brackets.zip
  • Make sure to flip the two brackets by 180 degrees on one of the horizontal axes (X/Y) in your slicer of choice before printing to avoid unnecessary supports
  • To allow enough clearance between the board and the bracket you either need to print four copies of the washer model or add nut(s) between the board and the bracket
  • If using nuts for the clearance between the board and the brackets, make sure it creates at least 3.2mm of spacing in between
  • Depending on the accuracy and calibration of a 3D printer, slight deviation can occur and you likely need to manually widen some of the holes to allow screws to fit
Other Resources
Troubleshooting
No Video or GPU Acceleration on Debian
If you can log in through serial but don't get any video or GPU acceleration on Debian, this is likely due to Debian's decision to compile the devfreq governors as loadable modules but not including them early enough for panfrost to be able to be provided with one of them.
The usual sign of this being the case is the following line in your log: [drm:panfrost_devfreq_init [panfrost]] *ERROR* Couldn't initialize GPU devfreq
Log in to your ROCKPro64, and run the following:
sudo -i
echo governor_simpleondemand >> /etc/initramfs-tools/modules && update-initramfs -u -k $(uname -r)
exit
Then, reboot.
