ROCK64 Software Releases
Revision as of 03:17, 29 December 2020 by Tllim (talk | contribs)
Linux Image Releases
Armbian
https://files.pine64.org/sw/pine64_installer/json/armbian.png
  • Version 5.88 onward support Rock64-v3 board
  • Armbian pack as 7zip, please unzip first before dd.
Armbian Ubuntu Focal XFCE Desktop [microSD / eMMC Boot]
Armbian Ubuntu Bionic XFCE Desktop [microSD / eMMC Boot]
Armbian Debian Buster for Server and Light Desktop [microSD / eMMC Boot]
Armbian Ubuntu Focal for Server and Light Desktop [microSD / eMMC Boot]
AOSC
  • To learn more about AOSC, please visit the official AOSC website
  • AOSC using LZ4 compression algorithm, please visit the LZ4 github site for utility
  • 8GB microSD card or eMMC module and above
  • Login with
    • username: aosc
    • password: anthon
AOSC KDE Community Build Image [microSD and eMMC Boot]
AOSC GNOME Community Build Image [microSD and eMMC Boot]
AOSC MATE Community Build Image [microSD and eMMC Boot]
AOSC Cinnamon Community Build Image [microSD and eMMC Boot]
AOSC XFCE Community Build Image [microSD and eMMC Boot]
AOSC LXDE Community Build Image [microSD and eMMC Boot]
Manjaro ARM
https://files.pine64.org/sw/pine64_installer/json/manjaro.png
  • Only support ROCK64 ver2 SBC
  • To learn more about Manjaro please visit Manjaro Forum
    • username: manjaro
    • password: manjaro
Manjaro KDE ARM Community Build Image [microSD / eMMC Boot] [19.04]
Manjaro LXQT ARM Community Build Image [microSD / eMMC Boot] [19.04]
Manjaro ARM Minimal Community Build Image [microSD / eMMC Boot] [19.04]
Slackware
https://files.pine64.org/sw/pine64_installer/json/slackware.png
Slackware Aarch64 XFCE Community Build Image [microSD Boot]
Slackware Aarch64 Miniroot Community Build Image [microSD Boot]
  • To run the OS on eMMC
DietPi
LibreELEC(KODI)
https://files.pine64.org/sw/pine64_installer/json/libreelec.png
Official LibreElec KODI Build Image [microSD / eMMC boot]
Volumio 2 Digital Audio Player
https://files.pine64.org/sw/pine64_installer/json/volumio.png
Volumio Digital Audio Player Community Build Image [microSD Boot] [2.528-2019-01-12]
  • Login with
    • Username: volumio
    • Password: volumio
Debian Stretch
https://files.pine64.org/sw/pine64_installer/json/debian.png
Debian Stretch Minimal 64bit (arm64) OS Image [microSD / eMMC Boot] [0.8.3]
Debian by mrfixit2001
Minimal Debian [microSD / eMMC Boot]
Ubuntu 18.04 Bionic
https://files.pine64.org/sw/pine64_installer/json/penguin.png
Ubuntu 18.04 Bionic LXDE Desktop Image [microSD / eMMC Boot] [0.8.3]
Ubuntu 18.04 Bionic minimal 64bit (arm64) Image [microSD / eMMC Boot] [0.8.3]
Ubuntu 18.04 Bionic minimal 32bit (armhf) Image [microSD / eMMC Boot] [0.8.3]
Ubuntu 18.04 Bionic Containers Image (DockerCE & Kubernetes)[microSD / eMMC Boot] [0.8.3]
OpenMediaVault
https://files.pine64.org/sw/pine64_installer/json/omv.png
Stretch OpenMediaVault OS Image 32bit (armhf) [microSD / eMMC Boot] [0.8.3]
Stretch OpenMediaVault OS Image 64bit (arm64) [microSD / eMMC Boot] [0.8.3]
NextCloudPi
https://files.pine64.org/sw/pine64_installer/json/nextcloudpi.png
NextCloudPi Community Build Image [microSD / eMMC Boot] [03-10-19]
  • Login with
    • username: root
    • password: 1234
Recalbox
https://files.pine64.org/sw/pine64_installer/json/recalbox.png
Recalbox Community Build Image [microSD / eMMC boot]
Cent OS
https://files.pine64.org/sw/pine64_installer/json/centos.jpg
  • Centos-7.4.1708 with kernel from Armbian-5.69 (minimum build)
  • Login with
    • username: root
    • password: centos
NEMS Linux [No Longer Maintained]
https://files.pine64.org/sw/pine64_installer/json/nems.jpg
  • Login with
    • Username: nemsadmin
    • Password: nemsadmin
  • Installation Guide
NEMS Linux [microSD / eMMC boot] [v1.5 - build 2]
Lakka
https://files.pine64.org/sw/pine64_installer/json/lakka.png
Fedora [No Longer Maintained]
https://files.pine64.org/sw/pine64_installer/json/fedora.png
BSD Image Releases
NetBSD
    • username: root
    • password: [none]
OpenBSD
Android Image Releases
Android TV 9.x eMMC (No Google Play)
https://files.pine64.org/sw/pine64_installer/json/android_9.png
* For install Playstore on Android 9.0, please follows this forum thread
Android 9.0 Stock Image [eMMC Boot] using DD method [20190617]
  • DD image for 16GB eMMC module
  • DD image for 32GB eMMC module
  • DD image for 64GB eMMC module
Android 9.0 Stock Image [eMMC Boot] using ROCKChip tools method [20190617]
  • The OTG port located at top USB 2.0 port, needs USB type A to type A cable.
  • This is Android TV build version
Android 9.0 Stock Rooted Image [eMMC Boot] using DD method [20190618]
Android 9.0 Stock Rooted Image [eMMC Boot] using ROCKChip tools method [20190618]
  • This is Rooted Android TV build version
  • Guide to flashing eMMC using Rockchip Tools
    • MD5 (GZip file): FC5F80C3A939AD0F8DCE5B85F22D20A1
    • File Size: 544MB
Android 9.x (No Google Play)
Android 9.0 Stock Rooted Image [microSD Boot] using DD method [20190621]
Android 9.0 Stock Rooted Image [microSD Boot] using ROCKChip SDDisk tools method [20190621]
Android 8.x TV eMMC (preinstalled Google Play Store)
https://files.pine64.org/sw/pine64_installer/json/android_8.png
    • File Size: 561MB
Android 8.x TV
    • File Size: 575MB
Android 7.x eMMC
https://files.pine64.org/sw/pine64_installer/json/android_7.png
  • USB 3.0 patches
    • File Size: 558MB
  • Set MacAddress on ROCK64
Android 7.x
  • USB 3.0 patches
    • File Size: 544MB
Android TV 7.x eMMC
Android TV 7.x
Android SDK
Android P SDK [v9.0]
