ROCK64 Software Releases
Revision as of 16:41, 17 January 2023 by Fxc (talk | contribs) (→‎Android TV 9.x eMMC (No Google Play): updated section)
This page contains a list of all available releases for the ROCK64, as well as links to other resources.
Linux Image Releases
Armbian
Armbian is a Linux distribution designed for ARM boards. They are usually Debian or Ubuntu flavored. To find out more about Armbian and available download options please visit the Armbian ROCK64 site.
Note: The download images are packed in a .7zip archive, please extract the archive first before flashing.
Download:
AOSC
AOSC OS is a general purpose Linux distribution that strives to simplify user experience and improve free and open source software for day-to-day productivity. To learn more about AOSC, please visit the official AOSC website.
Note: AOSC is using LZ4 compression algorithm for the downloads, please visit the LZ4 GitHub site for an utility for extracting the archives
Download:
Default credentials
Default user aosc/anthon
Manjaro ARM
Manjaro editions for Rock64 are available directly from Manjaro. To learn more about Manjaro please visit the Manjaro Forum.
Note: Only supports ROCK64 version 2 SBC!
Download:
ayufan's Linux releases
The community member ayufan offers multiple ROCK64 Linux releases based on Debian and Ubuntu. The forum thread for release can be found here.
Download:
Note: Make sure to download images for the ROCK64.
Default credentials
Default user rock64/rock64
Slackware
Slackware is a very old, interesting, convenient and easy distribution. Visit the project's website here (https://fail.pp.ua). You can follow the ongoing discussion about Slackware on the PINE64 forum (https://forum.pine64.org/showthread.php?tid=5868)
Note: This Slackware build using the ZST compression algorithm, please visit the ZST GitHub site for a decompression utility.
Download:
Default credentials
Default user root/password
To run the OS on eMMC:
  • Copy the image file to micro SD by using SFTP. The image file must have the .img file extension.
  • Boot the board, run below command for flashing to eMMC module
    • Run sudo dd if=[IMAGE] of=/dev/[DEVICE] bs=10M (example: sudo dd if=slack-current-aarch64-xfce_08May18-4.4.126-rock64-build-20180508.img of=/dev/mmcblk1 bs=10M).
    • then edit these two files in eMMC module:
    • mount /dev/mmcblk1p1 /media
    • echo "rootdev=/dev/mmcblk1p1" >> /media/boot/uEnv.txt
    • sed -i 's:mmcblk0p1:mmcblk1p1:' /media/etc/fstab
  • After that, power off the board and remove the microSD card. Then boot with only the eMMC module.
DietPi
DietPi is a lightweight yet easy to setup and feature-rich Linux distribution, based on Debian. To find out more about DietPi, please visit the official documentation. Discuss the ROCK64 build on the PINE64 forum thread.
Download:
Default credentials
Default user root/dietpi
LibreELEC
LibreELEC is a "Just enough OS" Linux distribution combining the Kodi media center with an operating system.
Download:
Volumio 2 Digital Audio Player
Volumio is a Linux-based headless DAP (digital audio player), which connects to your home stereo system or your DAC. Visit the project's website here. You can follow the ongoing discussion about Volumio on the PINE64 forum
Note: Volumio is controlled using a Web-GUI which can be accessed via a web browser using the boards IP or volumio.local/
Download:
Warning: The image appears to be outdated! Handle with caution.
Default credentials
Default user volumio/volumio
R-Cade
Retro Center's R-Cade, the 4K Media Center Arcade. RCade Features 100+ retro-gaming systems, a lightweight web browser, and full 4K UHD media playback
Download:
Lakka
Lakka is a lightweight Linux distribution that transforms a small computer into a full blown retrogaming console. Visit PINE64 forum for more information about the Lakka release. See the Lakka article for specific details regarding the distribution.
Download:
Debian
Debian is an operating system and a distribution of Free Software.
Download:
Installation:
  • Go to the download directory
  • Download firmware.rock64-rk3328.img.gz and partition.img.gz
  • Combine the 2 parts into 1 image file: zcat firmware.rock64-rk3328.img.gz partition.img.gz > debian-installer.img
  • Write the created .img file to microSD card or eMMC Module using dd
  • Plug the microSD/eMMC card in the Rock64 (and connect a serial console) and boot up to start the Debian Installer
See README.concatenateable_images here or README.concatenateable_images here for details regarding the concatenateable images and their installation from non-Linux systems.
Debian by mrfixit2001
Mrfixit2001's minimal Debian build. Version 190514 onward support Rock64-v3 board
Download:
Default credentials
Default user rock/rock
OpenMediaVault
Openmediavault is the next generation network attached storage (NAS) solution. See the OpenMediaVault article for more details. The forum thread concerning this release can be found here.
Download:
Note: The MD5 hash of the .xz file is 7E423EF9146EA15403E7D1B4EA30594A
Notes:
  • Shorting the eMMC PIN with a jumper as shown on the 1st image of Guide to install stock Android build to eMMC module. After power ON the box for 2-3 second, quickly remove the jumper. After boot, it will prompt for confirmation 'Y' to start writing the new image to the eMMC. Then follow the instructions on the screen
  • There's a bug with eMMC in the "Stable" version of openmediavault linked from the wiki page. In order to use eMMC, please you need to be on the latest (pre-release) version which is linked here https://github.com/ayufan-rock64/linux-build/releases
Default credentials
TTY and SSH, except OMV rock64/rock64
OMV for Web admin/openmediavault
OMV for TTY root/openmediavault
NextCloudPi
NextCloudPi comes not only with NextCloud preinstalled, but also with management tools for backups, SSL certificates, SAMBA, enhanced security and more. Visit the project's website. You can follow the ongoing discussion about NextCloudPi on the PINE64 forum.
Download:
Warning: The image is outdated.
Note: The MD5 hash of the .xz file is 1432c8b8082696f38770004b3cb5ac1e
Default credentials
Root user root/1234
Recalbox
Recalbox is a free and open-source operating system created for the emulation and preservation for retro games. Recalbox allows you to re-play a variety of videogame consoles and platforms in your living room with ease. To find out more about Recalbox and available tweaks to the installation please visit the PINE64 forum thread. Visit the project's website for more details.
Note: Only supports ROCK64 ver2 SBC
Download:
NEMS Linux
NEMS stands for "Nagios Enterprise Monitoring Server" and it is a modern pre-configured, customized and ready-to-deploy Nagios Core image designed to run on low-cost micro computers. To find out more about NEMS on the PINE64 and available tweaks to the installation please visit the PINE64 forum thread. To find out more on NEM Linux, please visit their site.
Warning: Only supports ROCK64 ver2 SBC
Download:
Note: The MD5 hash of the .xz file is 6e2088922c5d197db8b8ba3057120389
Note: The installation guide can be found here.
Default credentials
Default user nemsadmin/nemsadmin
BSD Image Releases
NetBSD
NetBSD is a free, fast, secure, and highly portable Unix-like Open Source operating system. To learn more about NetBSD please visit NetBSD main page. Instructions concerning enabling SSH can be found here.
Download:
Default credentials
Root user root/[none]
OpenBSD
You can install OpenBSD on your Rock64 by following these instructions.
FreeBSD
The RockChip FreeBSD page has instructions for installing FreeBSD. Version 13.0 and greater include prebuilt images.
Download:
  • Images for various FreeBSD releases can be found here
Default credentials
SSH access (enabled by default) freebsd/freebsd
Root user root/root
Android Image Releases
The Android 9.0 image for eMMC boot, build 20190617. For the installation of the Playstore on Android 9.0 please follow this forum thread.
Image downloads (for direct flashing):
Image downloads (for Rockchip Tool):
Note: This is Android TV build version. See the guide to flashing eMMC using Rockchip Tools. Please unzip the file first and then use Rockchip tool to flash it. The OTG port located at top USB 2.0 port and it needs USB type A to type A cable.
  • Stock image from pine64.org (544MB, MD5 of the Gzip file 9B717263E7749A732C8B5C7D7D59C5C6, build 20190617)
  • Rooted image from pine64.org (544MB, MD5 of the Gzip file FC5F80C3A939AD0F8DCE5B85F22D20A1, build 20190618)
Notes:
  • Please allow 10-15 minutes on first boot for initialization
Android 9.x (No Google Play)
Android 9.0 Stock Rooted Image [microSD Boot] using DD method [20190621]
Android 9.0 Stock Rooted Image [microSD Boot] using ROCKChip SDDisk tools method [20190621]
Android 8.x TV eMMC (preinstalled Google Play Store)
    • File Size: 561MB
Android 8.x TV
The Android 8.1 stock image for microSD boot, build 20180623.
Download:
Note: The MD5 hash of the .xz file is 85372A568C114ADE7CD9632CEBA193E9
Notes:
  • Write the image to a microSD card using dd and boot it.
Android 7.x eMMC
  • USB 3.0 patches
    • File Size: 558MB
  • See ROCK64 MAC Address on how to set the MAC address.
  • USB 3.0 patches
    • MD5 (XZ file): 7C831F9E6B4311A3B3D4743FBBB628D0
    • File Size: 544MB
Android 7.x
The Android 7.1.2 stock image for microSD boot (rooted), build 20171204.
Download:
Note: The MD5 hash of the .xz file is 56520ED3DB6E587DA140AD314A055EB2
Notes:
  • Has USB 3.0 patches
  • Enable the Real Time Clock support for the Popcorn Hour Transformer
Android TV 7.x eMMC
Android TV 7.x
The Android TV 7.1 community build image for microSD boot by ayufan.
Download:
Android SDK
The Android P SDK (v9.0).
Download:
Note: The MD5 hash of the TAR-GZip file is 1EAC08942E238293E3AF11C7890DF307
