ROCK64 Software Releases
Revision as of 15:17, 17 January 2023 by Fxc (talk | contribs) (→‎R-Cade: updated)
This page contains a list of all available releases for the ROCK64, as well as links to other resources.
Linux Image Releases
Armbian
Armbian is a Linux distribution designed for ARM boards. They are usually Debian or Ubuntu flavored. To find out more about Armbian and available download options please visit the Armbian ROCK64 site.
Note: The download images are packed in a .7zip archive, please extract the archive first before flashing.
Download:
AOSC
AOSC OS is a general purpose Linux distribution that strives to simplify user experience and improve free and open source software for day-to-day productivity. To learn more about AOSC, please visit the official AOSC website.
Note: AOSC is using LZ4 compression algorithm for the downloads, please visit the LZ4 GitHub site for an utility for extracting the archives
Download:
Default credentials
Default user aosc/anthon
Manjaro ARM
Manjaro editions for Rock64 are available directly from Manjaro. To learn more about Manjaro please visit the Manjaro Forum.
Note: Only supports ROCK64 version 2 SBC!
Download:
ayufan's Linux releases
The community member ayufan offers multiple ROCK64 Linux releases based on Debian and Ubuntu. The forum thread for release can be found here.
Download:
Note: Make sure to download images for the ROCK64.
Default credentials
Default user rock64/rock64
Slackware
Slackware is a very old, interesting, convenient and easy distribution. Visit the project's website here (https://fail.pp.ua). You can follow the ongoing discussion about Slackware on the PINE64 forum (https://forum.pine64.org/showthread.php?tid=5868)
Note: This Slackware build using the ZST compression algorithm, please visit the ZST GitHub site for a decompression utility.
Download:
Default credentials
Default user root/password
To run the OS on eMMC_
  • Copy the image file to micro SD by using SFTP. The image file must have the .img file extension.
  • Boot the board, run below command for flashing to eMMC module
    • Run sudo dd if=[IMAGE] of=/dev/[DEVICE] bs=10M (example: sudo dd if=slack-current-aarch64-xfce_08May18-4.4.126-rock64-build-20180508.img of=/dev/mmcblk1 bs=10M).
    • then edit these two files in eMMC module:
    • mount /dev/mmcblk1p1 /media
    • echo "rootdev=/dev/mmcblk1p1" >> /media/boot/uEnv.txt
    • sed -i 's:mmcblk0p1:mmcblk1p1:' /media/etc/fstab
  • After that, power off the board and remove the microSD card. Then boot with only the eMMC module.
DietPi
DietPi is a lightweight yet easy to setup and feature-rich Linux distribution, based on Debian. To find out more about DietPi, please visit the official documentation. Discuss the ROCK64 build on the PINE64 forum thread.
Download:
Default credentials
Default user root/dietpi
LibreELEC
LibreELEC is a "Just enough OS" Linux distribution combining the Kodi media center with an operating system.
Download:
Volumio 2 Digital Audio Player
Volumio is a Linux-based headless DAP (digital audio player), which connects to your home stereo system or your DAC. Visit the project's website here. You can follow the ongoing discussion about Volumio on the PINE64 forum
Note: Volumio is controlled using a Web-GUI which can be accessed via a web browser using the boards IP or volumio.local/
Download:
Warning: The image appears to be outdated! Handle with caution.
Default credentials
Default user volumio/volumio
R-Cade
Retro Center's R-Cade, the 4K Media Center Arcade. RCade Features 100+ retro-gaming systems, a lightweight web browser, and full 4K UHD media playback
Download:
Lakka
Debian
Debian Installer - Bullseye
  • Go to Debian Bullseye's official d-i concatenateable images directory
  • Download firmware.rock64-rk3328.img.gz and partition.img.gz
  • Combine the 2 parts into 1 image file: zcat firmware.rock64-rk3328.img.gz partition.img.gz > debian-installer-bullseye-rock64-rk3328.img*
  • Write the created .img file to microSD card or eMMC Module with dd
  • Plug the microSD/eMMC card in the Rock64 and connect a serial console and boot up to start the Debian Installer
*) (for non-Linux systems, consult README.concatenateable_images)
Debian Installer - Daily Build (for Bookworm+)
  • Go to Debian's daily build official d-i concatenateable images directory
  • Combine the 2 parts into 1 image file: zcat firmware.rock64-rk3328.img.gz partition.img.gz > debian-installer-daily-build-rock64-rk3328.img*
  • Plug the microSD/eMMC card in the Rock64 and boot up to start the Debian Installer. It should work with both a normal display and a serial console
Debian by mrfixit2001
Minimal Debian [microSD / eMMC Boot]
OpenMediaVault
Stretch OpenMediaVault OS Image 32bit (armhf) [microSD / eMMC Boot] [0.8.3]
Stretch OpenMediaVault OS Image 64bit (arm64) [microSD / eMMC Boot] [0.8.3]
NextCloudPi
NextCloudPi Community Build Image [microSD / eMMC Boot] [03-10-19]
  • Visit the project's website
  • Login with
    • username: root
    • password: 1234
Recalbox
Recalbox Community Build Image [microSD / eMMC boot]
Cent OS [No Longer Maintained]
  • Only support ROCK64 ver2 SBC
  • Centos-7.4.1708 with kernel from Armbian-5.69 (minimum build)
  • Login with
    • username: root
    • password: centos
NEMS Linux
https://files.pine64.org/sw/pine64_installer/json/nems.jpg
  • Login with
    • Username: nemsadmin
    • Password: nemsadmin
  • Installation Guide
NEMS Linux [microSD / eMMC boot] [v1.5 - build 2]
BSD Image Releases
NetBSD
NetBSD is a free, fast, secure, and highly portable Unix-like Open Source operating system. To learn more about NetBSD please visit NetBSD main page. Instructions concerning enabling SSH can be found here.
Download:
Default credentials
Root user root/[none]
OpenBSD
You can install OpenBSD on your Rock64 by following these instructions.
FreeBSD
The RockChip FreeBSD page has instructions for installing FreeBSD. Version 13.0 and greater include prebuilt images.
Download:
  • Images for various FreeBSD releases can be found here
Default credentials
SSH access (enabled by default) freebsd/freebsd
Root user root/root
Android Image Releases
Android TV 9.x eMMC (No Google Play)
* For install Playstore on Android 9.0, please follows this forum thread
Android 9.0 Stock Image [eMMC Boot] using DD method [20190617]
  • DD image for 16GB eMMC module
  • DD image for 32GB eMMC module
  • DD image for 64GB eMMC module
Android 9.0 Stock Image [eMMC Boot] using ROCKChip tools method [20190617]
  • The OTG port located at top USB 2.0 port, needs USB type A to type A cable.
  • This is Android TV build version
Android 9.0 Stock Rooted Image [eMMC Boot] using DD method [20190618]
Android 9.0 Stock Rooted Image [eMMC Boot] using ROCKChip tools method [20190618]
  • This is Rooted Android TV build version
  • Guide to flashing eMMC using Rockchip Tools
    • MD5 (GZip file): FC5F80C3A939AD0F8DCE5B85F22D20A1
    • File Size: 544MB
Android 9.x (No Google Play)
Android 9.0 Stock Rooted Image [microSD Boot] using DD method [20190621]
Android 9.0 Stock Rooted Image [microSD Boot] using ROCKChip SDDisk tools method [20190621]
Android 8.x TV eMMC (preinstalled Google Play Store)
    • File Size: 561MB
Android 8.x TV
    • File Size: 575MB
Android 7.x eMMC
  • USB 3.0 patches
    • File Size: 558MB
  • See ROCK64 MAC Address on how to set the MAC address.
  • USB 3.0 patches
    • MD5 (XZ file): 7C831F9E6B4311A3B3D4743FBBB628D0
    • File Size: 544MB
Android 7.x
  • USB 3.0 patches
    • File Size: 544MB
Android TV 7.x eMMC
Android TV 7.x
Android SDK
Android P SDK [v9.0]
