ROCK64 Software Releases
Revision as of 21:36, 28 April 2022 by Diederik (talk | contribs) (Add info and links to the official Debian Installer images)
This page contains a list of all available releases for the ROCK64, as well as links to other resources.
Linux Image Releases
Armbian
  • Version 5.88 onward support Rock64-v3 board
  • Armbian pack as 7zip, please unzip first before dd.
Armbian Ubuntu Focal XFCE Desktop [microSD / eMMC Boot]
Armbian Ubuntu Bionic XFCE Desktop [microSD / eMMC Boot]
Armbian Debian Buster for Server and Light Desktop [microSD / eMMC Boot]
Armbian Ubuntu Focal for Server and Light Desktop [microSD / eMMC Boot]
AOSC
  • To learn more about AOSC, please visit the official AOSC website
  • AOSC using LZ4 compression algorithm, please visit the LZ4 github site for utility
  • 8GB microSD card or eMMC module and above
  • Login with
    • username: aosc
    • password: anthon
AOSC KDE Community Build Image [microSD and eMMC Boot]
AOSC GNOME Community Build Image [microSD and eMMC Boot]
AOSC MATE Community Build Image [microSD and eMMC Boot]
AOSC Cinnamon Community Build Image [microSD and eMMC Boot]
AOSC XFCE Community Build Image [microSD and eMMC Boot]
AOSC LXDE Community Build Image [microSD and eMMC Boot]
Manjaro ARM
Manjaro editions for Rock64 are available directly from Manjaro.
Manjaro Rock64 Download Page
  • Only support ROCK64 ver2 SBC
  • To learn more about Manjaro please visit Manjaro Forum
Ubuntu 18.04 Bionic by ayufan
  • ayufan ROCK64 Linux Build GitHub
  • Forum thread concerning this release can be found here
  • Login with
    • username: rock64
    • password: rock64
Ubuntu 18.04 Bionic LXDE Desktop (armhf) Image [microSD / eMMC Boot] [0.9.14]
Ubuntu 18.04 Bionic minimal 64bit (arm64) Image [microSD / eMMC Boot] [0.9.14]
Ubuntu 18.04 Bionic minimal 32bit (armhf) Image [microSD / eMMC Boot] [0.9.14]
Ubuntu 18.04 Bionic containers (DockerCE & Kubernetes) Image [microSD / eMMC Boot] [0.9.14]
Slackware
Slackware Aarch64 XFCE Community Build Image [microSD Boot]
Slackware Aarch64 Miniroot Community Build Image [microSD Boot]
  • To run the OS on eMMC
DietPi
LibreELEC(KODI)
Official LibreElec KODI Build Image [microSD / eMMC boot]
Volumio 2 Digital Audio Player
Volumio Digital Audio Player Community Build Image [microSD Boot] [2.528-2019-01-12]
  • DD image (for 8GB microSD card and above)
  • Login with
    • Username: volumio
    • Password: volumio
Lakka
Debian
Debian Installer - Bullseye
  • Go to Debian Bullseye's official d-i concatenateable images directory
  • Download firmware.rock64-rk3328.img.gz and partition.img.gz
  • Combine the 2 parts into 1 image file: zcat firmware.rock64-rk3328.img.gz partition.img.gz > debian-installer-bullseye-rock64-rk3328.img*
  • Write the created .img file to microSD card or eMMC Module with dd
  • Plug the microSD/eMMC card in the Rock64 and connect a serial console and boot up to start the Debian Installer
*) (for non-Linux systems, consult README.concatenateable_images)
Debian Installer - Daily Build (for Bookworm+)
  • Go to Debian daily build official d-i concatenateable images directory
  • Combine the 2 parts into 1 image file: zcat firmware.rock64-rk3328.img.gz partition.img.gz > debian-installer-daily-build-rock64-rk3328.img*
  • Plug the microSD/eMMC card in the Rock64 and boot up to start the Debian Installer. It should work with both a [bugs.debian.org/1009014 normal display as a serial console]
Debian by ayufan
Debian Stretch Minimal 64bit (arm64) OS Image [microSD / eMMC Boot] [0.8.3]
Debian by mrfixit2001
Minimal Debian [microSD / eMMC Boot]
OpenMediaVault
Stretch OpenMediaVault OS Image 32bit (armhf) [microSD / eMMC Boot] [0.8.3]
Stretch OpenMediaVault OS Image 64bit (arm64) [microSD / eMMC Boot] [0.8.3]
NextCloudPi
NextCloudPi Community Build Image [microSD / eMMC Boot] [03-10-19]
  • Login with
    • username: root
    • password: 1234
Recalbox
Recalbox Community Build Image [microSD / eMMC boot]
Cent OS [No Longer Maintained]
  • Centos-7.4.1708 with kernel from Armbian-5.69 (minimum build)
  • Login with
    • username: root
    • password: centos
NEMS Linux
https://files.pine64.org/sw/pine64_installer/json/nems.jpg
  • Login with
    • Username: nemsadmin
    • Password: nemsadmin
  • Installation Guide
NEMS Linux [microSD / eMMC boot] [v1.5 - build 2]
Fedora [No Longer Maintained]
BSD Image Releases
NetBSD
OpenBSD
FreeBSD
The RockChip FreeBSD page has instructions for installing FreeBSD.
  • Images for various FreeBSD releases can be found here
  • Version 13.0 and greater include prebuilt images. Find the link in the SD Card Images section and download the ROCK64 image.
  • SSH is enable by default and can be accessed with the following account:
username: freebsd
password: freebsd
  • The root account credentials are:
username: root
password: root
Android Image Releases
Android TV 9.x eMMC (No Google Play)
* For install Playstore on Android 9.0, please follows this forum thread
Android 9.0 Stock Image [eMMC Boot] using DD method [20190617]
  • DD image for 16GB eMMC module
  • DD image for 32GB eMMC module
  • DD image for 64GB eMMC module
Android 9.0 Stock Image [eMMC Boot] using ROCKChip tools method [20190617]
  • The OTG port located at top USB 2.0 port, needs USB type A to type A cable.
  • This is Android TV build version
Android 9.0 Stock Rooted Image [eMMC Boot] using DD method [20190618]
Android 9.0 Stock Rooted Image [eMMC Boot] using ROCKChip tools method [20190618]
  • This is Rooted Android TV build version
  • Guide to flashing eMMC using Rockchip Tools
    • MD5 (GZip file): FC5F80C3A939AD0F8DCE5B85F22D20A1
    • File Size: 544MB
Android 9.x (No Google Play)
Android 9.0 Stock Rooted Image [microSD Boot] using DD method [20190621]
Android 9.0 Stock Rooted Image [microSD Boot] using ROCKChip SDDisk tools method [20190621]
Android 8.x TV eMMC (preinstalled Google Play Store)
    • File Size: 561MB
Android 8.x TV
    • File Size: 575MB
Android 7.x eMMC
  • USB 3.0 patches
    • File Size: 558MB
  • See ROCK64 MAC Address on how to set the MAC address.
  • USB 3.0 patches
    • MD5 (XZ file): 7C831F9E6B4311A3B3D4743FBBB628D0
    • File Size: 544MB
Android 7.x
  • USB 3.0 patches
    • File Size: 544MB
Android TV 7.x eMMC
Android TV 7.x
Android SDK
Android P SDK [v9.0]
