ROCK64 Software Releases
Revision as of 21:41, 29 December 2019 by Tllim (talk | contribs)
Contents
Linux Image Releases
Armbian
  • Version 5.88 onward support Rock64-v3 board
  • Armbian pack as 7zip, please unzip first before dd.
Armbian Ubuntu Bionic Desktop on mainline Kernel [microSD / eMMC Boot]
Armbian Debian Buster on mainline Kernel [microSD / eMMC Boot]
Armbian Ubuntu Bionic Desktop on legacy BSP Kernel [microSD / eMMC Boot]
Armbian Debian Buster on legacy BSP Kernel [microSD / eMMC Boot]
LibreELEC(KODI)
Official LibreElec KODI Leia 9.2 Build Image [microSD / eMMC boot]
Debian Stretch
Debian Stretch Minimal 64bit (arm64) OS Image [microSD / eMMC Boot] [0.8.3]
Debian by mrfixit2001
Minimal Debian [microSD / eMMC Boot]
Ubuntu 18.04 Bionic
Ubuntu 18.04 Bionic LXDE Desktop Image [microSD / eMMC Boot] [0.8.3]
Ubuntu 18.04 Bionic minimal 64bit (arm64) Image [microSD / eMMC Boot] [0.8.3]
Ubuntu 18.04 Bionic minimal 32bit (armhf) Image [microSD / eMMC Boot] [0.8.3]
Ubuntu 18.04 Bionic Containers Image (DockerCE & Kubernetes)[microSD / eMMC Boot] [0.8.3]
OpenMediaVault
Stretch OpenMediaVault OS Image 32bit (armhf) [microSD / eMMC Boot] [0.8.3]
Stretch OpenMediaVault OS Image 64bit (arm64) [microSD / eMMC Boot] [0.8.3]
NextCloudPi
NextCloudPi Community Build Image [microSD / eMMC Boot] [03-10-19]
  • Visit the project's website
  • Login with
    • username: root
    • password: 1234
Lakka
Slackware
Slackware Aarch64 Miniroot Community Build Image [microSD Boot] [20190623]
Slackware Aarch64 XFCE Community Build Image [microSD Boot] [20190623]
  • Login with
    • Username : root
    • Password : password
  • To run the OS on eMMC
DietPi
DietPi Community Build Image [microSD / eMMC boot]
NEMS Linux
  • Login with
    • Username: nemsadmin
    • Password: nemsadmin
  • Installation Guide
NEMS Linux [microSD / eMMC boot] [v1.5 - build 2]
Cent OS
  • Centos-7.4.1708 with kernel from Armbian-5.69 (minimum build)
  • Login with
    • username: root
    • password: centos
Manjaro ARM
  • To learn more about Manjaro please visit Manjaro Forum
    • username: manjaro
    • password: manjaro
Manjaro KDE ARM Community Build Image [microSD / eMMC Boot] [19.04]
Manjaro LXQT ARM Community Build Image [microSD / eMMC Boot] [19.04]
Manjaro ARM Minimal Community Build Image [microSD / eMMC Boot] [19.04]
Recalbox
Recalbox Community Build Image [microSD / eMMC boot]
Volumio Digital Audio Player
Volumio Digital Audio Player Community Build Image [microSD Boot] [2.528-2019-01-12]
  • Login with
    • Username: volumio
    • Password: volumio
Fedora
Yocto
BSD Image Releases
NetBSD
    • username: root
    • password: [none]
OpenBSD
Android Image Releases
Android 9.x eMMC
Android 9.0 Stock Image [eMMC Boot] using DD method [20190617]
  • This is Android TV build version
  • DD image for 16GB eMMC module
  • DD image for 32GB eMMC module
  • DD image for 64GB eMMC module
Android 9.0 Stock Image [eMMC Boot] using ROCKChip tools method [20190617]
  • The OTG port located at top USB 2.0 port, needs USB type A to type A cable.
Android 9.0 Stock Rooted Image [eMMC Boot] using DD method [20190618]
  • This is Rooted Android TV build version
Android 9.0 Stock Rooted Image [eMMC Boot] using ROCKChip tools method [20190618]
  • Guide to flashing eMMC using Rockchip Tools
    • MD5 (GZip file): FC5F80C3A939AD0F8DCE5B85F22D20A1
    • File Size: 544MB
Android 9.x
Android 9.0 Stock Rooted Image [microSD Boot] using DD method [20190621]
Android 9.0 Stock Rooted Image [microSD Boot] using ROCKChip SDDisk tools method [20190621]
Android 8.x eMMC
    • File Size: 561MB
Android 8.x
    • File Size: 575MB
Android 7.x eMMC
  • USB 3.0 patches
    • File Size: 558MB
  • Set MacAddress on ROCK64
Android 7.x
  • USB 3.0 patches
    • File Size: 544MB
Android TV 7.x eMMC
Android TV 7.x
Android SDK
Android P SDK [v9.0]
