ROCK64 Software Releases
Contents
Linux Image Releases
Armbian
Armbian Debian Stretch Desktop [microSD / eMMC Boot] [5.65]
  • Login with
    • username: root
    • password: 1234
Armbian Ubuntu 18.04 Bionic Desktop [microSD / eMMC Boot] [5.65]
  • Login with
    • username: root
    • password: 1234
Debian Stretch
Debian Stretch Minimal 64bit OS Image [microSD / eMMC Boot] [0.7.8]
Debian Stretch for V3
Debian Stretch Minimal 64bit OS Image [microSD / eMMC Boot] [20190509]
  • Login with
    • username: rock
    • password: rock
Ubuntu 18.04 Bionic
Ubuntu 18.04 Bionic LXDE Desktop Image [microSD / eMMC Boot] [0.7.8]
Ubuntu 18.04 Bionic minimal 64bit Image [microSD / eMMC Boot] [0.7.8]
Ubuntu 18.04 Bionic minimal 32bit Image [microSD / eMMC Boot] [0.7.8]
Ubuntu 18.04 Bionic Containers Image (DockerCE & Kubernetes)[microSD / eMMC Boot] [0.7.8]
LibreELEC Nightly Build
LibreElec KODI Community Build Image [microSD / eMMC boot] [NIGHTLY BUILD IMAGES]
OpenMediaVault
Stretch OpenMediaVault OS Image armhf [microSD / eMMC Boot] [0.7.8]
Stretch OpenMediaVault OS Image arm64 [microSD / eMMC Boot] [0.7.8]
NextCloudPi
NextCloudPi Community Build Image [microSD Boot] [11-04-18]
  • Visit the project's website
  • Login with
    • username: root
    • password: 1234
Lakka
  • Lakka The open source game console; a lightweight Linux distribution that transforms the Rock64 into a full blown retrogaming console
  • Visit PINE64 forum for more information about the Lakka release
    • [le.builds.lakka.tv/Rockchip.ROCK64.arm/Lakka-Rockchip.ROCK64.arm-2.1.img.gz Direct download from Lakka]
  • Lakka Basic Setup
Slackware
Slackware Aarch64 Miniroot Community Build Image [microSD Boot] [20190201]
Slackware Aarch64 XFCE Community Build Image [microSD Boot] [20190201]
  • Login with
    • Username : root
    • Password : password
  • To run the OS on eMMC
DietPi
DietPi Community Build Image [microSD boot]
NEMS Linux
  • Login with
    • Username: nemsadmin
    • Password: nemsadmin
  • Installation Guide
NEMS Linux [microSD / eMMC boot] [v1.5 - build 2]
Cent OS
  • Centos-7.4.1708 with kernel from Armbian-5.69 (minimum build)
Debian by mrfixit2001
Minimal Debian [microSD / eMMC Boot]
Recalbox
Recalbox Community Build Image [microSD / eMMC boot]
Volumio Digital Audio Player
Volumio Digital Audio Player Community Build Image [microSD Boot] [2.528-2019-01-12]
Volumio Digital Audio Player Community Build Image [microSD Boot] [2.462-2018-09-29]
Volumio Digital Audio Player Community Build Image [microSD Boot] [2.390-2018-03-27]
  • Login with
    • Username: volumio
    • Password: volumio
Fedora
Yocto
BSD Image Releases
NetBSD
    • [www.invisible.ca/arm/201807241220Z/NetBSD-evbarm-aarch64-201807241220Z-rock64.img.gz Download directly from NetBSD]
    • size: 336MB
    • username: root
    • password: [none]
OpenBSD
Android Image Releases
Android 8.x eMMC
    • File Size: 561MB
Android 8.x
    • File Size: 575MB
Android 7.x eMMC
  • USB 3.0 patches
    • File Size: 558MB
  • Set MacAddress on ROCK64
Android 7.x
  • USB 3.0 patches
    • File Size: 544MB
Android TV 7.x eMMC
Android TV 7.x
Android SDK
Android Oreo [v8.1]
