ROCK64 Software Releases
Contents
Linux Image Releases
Armbian
Armbian Debian Stretch Desktop [microSD / eMMC Boot] [5.42]
  • Login with
    • username: root
    • password: 1234
Armbian Ubuntu 16.04 Xenial Desktop [microSD / eMMC Boot] [5.42]
  • Login with
    • username: root
    • password: 1234
Debian Stretch
Debian Stretch Minimal 64bit OS Image [microSD / eMMC Boot] [0.7.8]
Ubuntu 18.04 Bionic
Ubuntu 18.04 Bionic LXDE Desktop Image [microSD / eMMC Boot] [0.7.8]
Ubuntu 18.04 Bionic minimal 64bit Image [microSD / eMMC Boot] [0.7.8]
Ubuntu 18.04 Bionic minimal 32bit Image [microSD / eMMC Boot] [0.7.8]
Ubuntu 18.04 Bionic Containers Image (DockerCE & Kubernetes)[microSD / eMMC Boot] [0.7.8]
LibreElec
LibreElec KODI Community Build Image [microSD boot] [Preliminary Alpha]
OpenMediaVault eMMC
NextCloudPi
NextCloudPi Community Build Image [microSD Boot] [2018_05_10]
  • Visit the project's website
  • Login with
    • username: root
    • password: 1234
Lakka
  • Lakka The open source game console; a lightweight Linux distribution that transforms the Rock64 into a full blown retrogaming console
  • Visit PINE64 forum for more information about the Lakka release
    • [le.builds.lakka.tv/Rockchip.ROCK64.arm/Lakka-Rockchip.ROCK64.arm-2.1.img.gz Direct download from Lakka]
  • Lakka Basic Setup
Slackware
Slackware Aarch64 Miniroot Community Build Image [microSD Boot] [20180508]
Slackware Aarch64 XFCE Community Build Image [microSD Boot] [20180508]
  • Login with
    • Username : root
    • Password : password
  • To run the OS on eMMC
DietPi
DietPi Community Build Image [microSD boot]
Volumio Digital Audio Player
Volumio Digital Audio Player Community Build Image [microSD Boot] [2.390-2018-03-27]
  • Login with
    • Username: volumio
    • Password: volumio
Fedora
Yocto
Android Image Releases
Android 8.x eMMC
    • MD5 (XZ file): B9133B6C0B2ECAC57E363A5351D7E58E
    • File Size: 561MB
Android 8.x
    • File Size: 575MB
Android 7.x eMMC
  • USB 3.0 patches
    • File Size: 558MB
  • Set MacAddress on ROCK64
Android 7.x
  • USB 3.0 patches
    • File Size: 544MB
Android TV 7.x eMMC
Android TV 7.x
Android SDK
Android Oreo [v8.1]
