ROCK64 Software Release
Contents
- 1 Linux Image Releases
- 2 Android Image Releases
- 3 Android SDK
Armbian
Armbian Debian Stretch Desktop [microSD / eMMC Boot] [5.42]
- DD image to microSD card or eMMC module and boot. Highly recommend using Etcher
- Direct download from Armbian
- File Size: 616MB
- sha256sum: 736147eadd98b2dbe11d4a0bd9517467fc1e3913190188b717ad5aaa72f8d729
- Login with
- username: root
- password: 1234
- To find out more about Armbian and available options please visit their site
Armbian Ubuntu Xenial [microSD / eMMC Boot] [5.42]
- File Size: 180MB
- sha245sum:53dc448b490ee862a03ea84b8edcc298fb991b0c81c9940ce223467f13b7d39b
- Login with
- username: root
- password: 1234
Debian Stretch
Debian Stretch Minimal 64bit OS Image [microSD / eMMC Boot] [0.7.8]
- Direct download from ayufan's github
- size: 212MB
- Login with
- username: rock64
- password: rock64
- Forum thread concerning this release can be found here
Bionic
Bionic LXDE Community Build Image [microSD Boot] by ayufan
- DD image to microSD card and boot. Highly recommend using Etcher
- Login with
- username: rock64
- password: rock64
Bionic Minimal Community Build Image [microSD Boot] by ayufan
- Login with
- username: rock64
- password: rock64
LibreElec
LibreElec KODI Community Build Image [microSD boot] [Preliminary Alpha]
- The LibreElec Kodi build still in Alpha stage, good for checkout and still not ready for daily use
- Unzip and DD image to microSD card and boot. Highly recommend using Etcher
- Latest images are available on LibreElec's test images page - look for the RK3328 images ending with rock64
- kwiboo's LibreElec images fix an error where you get a blackscreen after a video ends or is stopped
OpenMediaVault eMMC
- openmediavault is the next generation network attached storage (NAS) solution, click link to OMV main page
- DD image to microSD card. Highly recommend using Etcher
- Shorting the eMMC PIN with a jumper as shown on the 1st image of Guide to install stock Android build to eMMC module. After power ON the box for 2-3 second, quickly remove the jumper. After boot, it will prompt for confirmation 'Y' to start writing the new image to the eMMC. Then follow the instructions on the screen
- Release notes on ayufan Linux github
- Direct download from pine64.org
- Direct download from pine64.uk
- MD5 (XZ file): 7E423EF9146EA15403E7D1B4EA30594A
- File Size: 487MB
- Credentials (console/ssh, except OMV): rock64/rock64
- Credentials (OMV for Web): admin/openmediavault
- Credentials (OMV for console): root/openmediavault
- OpenMediaVault Basic Setup
- OpenMediaVault Plugins
OpenMediaVault
Jessie OpenMediaVault Community Build Image [microSD Boot] by ayufan
- Direct download latest release build from ayufan github and look for jessie-openmediavault-rock64-x.x.xx-xx-armhf.img.xz
NextCloudPi
NextCloudPi Community Build Image [microSD Boot] [2018_05_10]
- NextCloudPi comes not only with NextCloud preinstalled, but also with management tools for backups, SSL certificates, SAMBA, enhanced security and more.
- Visit the project's website
- You can follow the ongoing discussion about NextCloudPi on the PINE64 forum
- MD5 (XZ file): 5b29095583a1acdc6a605c5f63dc547e
- File Size: 292MB
- Login with
- username: root
- password: 1234
Lakka
Lakka Community Build Image [microSD Boot]
- Lakka The open source game console is a lightweight Linux distribution that transforms a small computer into a full blown retrogaming console
- Visit PINE64 forum for more information about the Lakka release
- Lakka Basic Setup
Slackware
- Slackware is a very old, interesting, convenient and easy distribution.
- Visit the project's website here (http://fail.pp.ua)
- You can follow the ongoing discussion about Slackware on the PINE64 forum (https://forum.pine64.org/showthread.php?tid=5868)
Slackware Aarch64 Miniroot Community Build Image [microSD Boot] [20180508]
- System without a graphical shell
- MD5 (XZ file): d87bcd4c62221b02ee3083610cbbca7f
- File Size: 166MB
Slackware Aarch64 XFCE Community Build Image [microSD Boot] [20180508]
- System with a graphical shell
- MD5 (XZ file): 8d9b00ea373ded6d9a6e37aa79597b31
- File Size: 626MB
- Login with
- Username : root
- Password : password
- To run the OS on eMMC
- Flash the image to micro SD, power up the board with micro SD and login
- Copy the image file to micro SD by using SFTP. The image file must be in .img. note : root user are not allow transfer file to micro SD.
- After finish copy the file, power off the board and add eMMC module to the board
- Bootup the board, run below command for flashing to eMMC module
- >>dd if=[image file] of=/dev/mmcblk1 bs=10M
- example : dd if=slack-current-aarch64-xfce_08May18-4.4.126-rock64-build-20180508.img of=/dev/mmcblk1 bs=10M
- then edit 2 files in eMMC module:
- >> mount /dev/mmcblk1p1 /media
- >> echo "rootdev=/dev/mmcblk1p1" >> /media/boot/uEnv.txt
- >> sed -i 's:mmcblk0p1:mmcblk1p1:' /media/etc/fstab
- After done, power off board and remove micro SD. Then bootup with only eMMC module.
i3
Xenial i3 Community Build Image [microSD Boot] by ayufan
- Login with
- username: rock64
- password: rock64
DietPi
DietPi Community Build Image [microSD boot]
- DietPi is a lightweight linux distribution of Debian Stretch
- To find out more about DietPi and available tweaks to the installation please visit the PINE64 forum thread
- DD image (for 8GB micoSD card and above)
- Login with
- username: root
- password: dietpi
Volumio Digital Audio Player
Volumio Digital Audio Player Community Build Image [microSD Boot] [2.390-2018-03-27]
- Volumio is a linux-based headless DAP (digital audio player), which connects to your home stereo system or your DAC
- You can follow the ongoing discussion about Volumio on the PINE64 forum
- Direct download from volumio.org
- MD5 (Zip file): 2e2bb2c3e7d0d8db1ad20a055ae2293d
- File Size: 353MB
- Login with
- Username: volumio
- Password: volumio
- Volumio is controlled using a Web-GUI which can be accessed via a web browser using the boards IP or volumio.local/
Fedora
Yocto
- Please follow this Rockchip-Yocto wiki page
- Here is build command: MACHINE=evb-rk3328 DISTRO=rk-wayland . ./setup-environment -b build
Android 8.x eMMC
- DD image to eMMC module. Highly recommend using Etcher
- Shorting the eMMC PIN with a jumper as shown on the 1st image of Guide to install stock Android build to eMMC module. After power ON the box for 2-3 second, quickly remove the jumper, then it will start writing the new image to the eMMC. Please allow around 1 minute of boot up time before UI is presented via HDMI
- Please allow 10-15 minutes boot up time on first time for initialization
- MD5 (XZ file): B9133B6C0B2ECAC57E363A5351D7E58E
- File Size: 561MB
- Please unzip first and then using Android tool to flash in
- The OTG port located at top USB 2.0 port
- Guide to flashing eMMC using Rockchip Tools
- MD5 (XZ file): 9738F060D2F62A83637797363D2B38C9
- File Size: 752MB
Android 8.x
- MD5 (XZ file): 85372A568C114ADE7CD9632CEBA193E9
- File Size: 575MB
Android 7.x eMMC
- USB 3.0 patches
- Enable Real Time Clock support for Popcorn Hour Transformer
- MD5 (XZ file): 43443467DFCAEDE767556843EB4D6707
- File Size: 558MB
- Set MacAddress on ROCK64
- USB 3.0 patches
- MD5 (XZ file): 7C831F9E6B4311A3B3D4743FBBB628D0
- File Size: 544MB
Android 7.x
- USB 3.0 patches
- MD5 (XZ file): 56520ED3DB6E587DA140AD314A055EB2
- File Size: 544MB
Android TV 7.x eMMC
- Release notes on ayufan Android 7.1 github
- Please allow 5 minutes boot up time on first time for initialization
- MD5 (XZ file): 6FD1FA4BE87EC2D4E0862F66541BC6F0
- File Size: 716MB
- For eMMC flash-all image, please unzip first and then use Android tool to flash in
Android TV 7.x
Android SDK
Android Oreo [v8.1]
- Direct Download from pine64.org
- MD5 (TAR-GZip file): bddfc2b99d3f5115791d915508f1b834
- File Size: 67.21GB
