ROCK64 Software Release
Revision as of 06:11, 25 June 2018 by Tllim (talk | contribs)
Contents
Linux Image Releases
Armbian
Armbian Debian Stretch Desktop [microSD Boot] [4.4.124]
Armbian Ubuntu Xenial [microSD Boot] [4.4.124]
Debian
Debian Stretch Mate Community Build Image [microSD Boot] [0.5.15-136-20171222]
Debian Stretch Minimal Community Build Image [microSD Boot] by ayufan
Debian Jessie Minimal Community Build Image [microSD Boot] by ayufan
Bionic
Bionic LXDE Community Build Image [microSD Boot] by ayufan
Bionic Minimal Community Build Image [microSD Boot] by ayufan
Xenial Mate eMMC
Xenial Mate Community Build Image [microSD to eMMC] [0.5.15-136]
Xenial Mate
Xenial Mate Community Build Image [microSD Boot] by ayufan
Artful Minimal Image
Artful Minimal Community Build Image [microSD Boot] by ayufan
Xenial Minimal Image
Xenial Minimal Community Build Image [microSD Boot] by ayufan
LibreElec
LibreElec KODI Community Build Image [microSD boot] [Preliminary Alpha]
OpenMediaVault eMMC
OpenMediaVault
Jessie OpenMediaVault Community Build Image [microSD Boot] by ayufan
NextCloudPi
NextCloudPi Community Build Image [microSD Boot] [2018_05_10]
  • Visit the project's website
  • Login with
    • username: root
    • password: 1234
Lakka
Lakka Community Build Image [microSD Boot]
Slackware
Slackware Aarch64 Miniroot Community Build Image [microSD Boot] [20180508]
Slackware Aarch64 XFCE Community Build Image [microSD Boot] [20180508]
  • Login with
    • Username : root
    • Password : password
  • To run the OS on eMMC
i3
Xenial i3 Community Build Image [microSD Boot] by ayufan
DietPi
DietPi Community Build Image [microSD boot]
Volumio Digital Audio Player
Volumio Digital Audio Player Community Build Image [microSD Boot] [2.390-2018-03-27]
  • Login with
    • Username: volumio
    • Password: volumio
Fedora
Yocto
Android Image Releases
Android 8.x eMMC
Android 8.1. Stock Image [eMMC Boot] [20180606]
    • MD5 (XZ file): B9133B6C0B2ECAC57E363A5351D7E58E
    • File Size: 561MB
Android 8.x
    • File Size: 575MB
Android 7.x eMMC
  • USB 3.0 patches
    • File Size: 558MB
  • Set MacAddress on ROCK64
Android 7.x
  • USB 3.0 patches
    • File Size: 544MB
Android TV 7.x eMMC
Android TV 7.x
