ROCK64
Contents
ROCK64
ROCK64 is a credit card size 4K60P HDR Media Board Computer powered by Rockchip RK3328 Quad-Core ARM Cortex A53 64-Bit Processor and support up to 4GB 1866MHz LPDDR3 memory. It provides eMMC module socket, MicroSD Card slot, Pi-2 Bus, Pi-P5+ Bus, USB 3.0 and many others peripheral devices interface for makers to integrate with sensors and devices. Various Operating System (OS) are made available by open source community such Android 7.1, Debian, Yocto and many more to come.
ROCK64 Software Images
- OS build Installation Guide and tools:
ROCK64 Ver3 and Ver2
Under 'ROCK64 Software and OS Image Download Section' you will find a complete list of currently supported Operating System images that work with the ROCK64 as well as other related software. The list includes OS images and descriptions of:
Bionic Desktop LXDE (microSD /eMMC Boot)
Bionic Minimal 64bit (microSD /eMMC Boot)
Bionic Minimal 32bit (microSD /eMMC Boot)
Bionic Minimal Containers (microSD /eMMC Boot)
ROCK64 Ver2 only
Some OS images are still in beta or nightly build which are only fit for testing purposes. These should usually be avoided for normal usage, since they are used at your own risk
- ayufan Linux
- ayufan Android 7.1
- Raybuntu LibreElec KODI | Kwiboo LibreElec KODI
- Fire219 Fedora
- Lakka | RetroPie-Setup
- Armbian
- Arch Linux
- NextCloudPi
- Slackware
State of software support for the hardware
Requirement | GNU/Linux | Android/Linux | Kodi/Linux |
2160p 30Hz 8bit h264/h265/vp8 | partial? 1 | yes | yes |
UI using GPU | no | yes | ? |
Youtube | no | yes | no |
vp9 / mpeg4 / mpeg2 / 10bit HDR / YCbCr | no | yes? | no 1 |
SoC and Memory Specification
- Based on Rockchip RK3328
- Quad-core Cortex-A53 up to 1.5GHz CPU
- Full implementation of the ARM architecture v8-A instruction set
- ARM Neon Advanced SIMD (single instruction, multiple data) support for accelerated media and signal processing computation
- ARMv8 Cryptography Extensions
- In-order pipeline with symmetric dual-issue of most instructions
- Unified system L2 cache
- Include VFP v3 hardware to support single and double-precision operations
- Integrated 32KB L1 instruction cache, 32KB L1 data cache with 4-way set associative
- TrustZone technology support
- Full CoreSight debug solution
- One separate power domains for CPU core system to support internal power switch and externally turn on/off based on different application scenario
- PD_A53: Cortex-A53 + Neon + FPU + L1 I/D Cache of core 2/3
- One isolated voltage domain to support DVFS
GPU Architecture
- ARM Mali-450MP2 Dual-core GPU
- OpenGL ES 1.1 and 2.0, OpenVG1.1
- LPDDR3 RAM Memory Variants: 1GB, 2GB and 4GB.
- Storage Memory: ROCK64 boards have 128Mb built-in SPI Flash memory but not yet in use, currently use bootable microSD Cards or bootable attachable eMMC.
Board Features
Video
- Digital Video output up to [email protected]
- 4K HDR @ 60fps
- H.264/AVC Base/Main/High/High10 profile @ level 5.1; up to 4Kx2K @ 60fps
- H.265/HEVC Main/Main10 profile @ level 5.1 High-tier; up to 4Kx2K @ 60fps
- VP9, up to 4Kx2K @ 60fps
- MPEG-1, ISO/IEC 11172-2, up to 1080P @ 60fps
- MPEG-2, ISO/IEC 13818-2, [email protected], [email protected], up to 1080P @ 60fps
- MPEG-4, ISO/IEC 14496-2, [email protected], [email protected], up to 1080P @ 60fps
- VC-1, [email protected], [email protected], [email protected], up to 1080P @ 60fps
- MVC is supported based on H.264 or H.265, up to 1080P @ 60fps
Audio
- 3.5mm A/V Jack (Composite Video Output and RCA Stereo support using conversion cable)
Network
- 10/100/1000Mbps Ethernet
- WiFi 802.11 b/g/n with Bluetooth 4.0 (optional USB dongle)
Storage
- microSD - bootable, support SDHC and SDXC, storage up to 256GB
- eMMC - bootable (optional eMMC Module)
- 1 USB3.0 Dedicated Host port
- 2 USB2.0 Dedicated Host port (top one is USB-OTG)
Expansion Ports
- 2x20 pins "Pi2" GPIO Header
- 2x11 pins "Pi P5+" GPIO Header (with 2nd 10/100Mbps Ethernet pins)
ROCK64 Board Information, Schematics and Certifications
- Board Dimensions: 85mm x 56mm x 18.8mm
- Input Power: +5V @3A with 3.5mm/1.35mm Type H Barrel type DC connector (@2A still work if no heavy loading on USB 3.0 port)
- ROCK64 ver 3.0 SBC related info
ROCK64 Rev3 SBC RTC Battery Connector polarity
- ROCK64 ver 2.0 SBC related info
- Github on ROCK64 GPIO library, thanks to Leapo
- Good documentation about ROCK64 GPIO pins article
- ROCK64 Audio DAC with 10/100Mbps Ethernet POT Board Schematic
- ROCK64 3-D autodesk drawing, thanks and courtesy of TeaPack
- ROCK64 Certifications:
- Disclaimer: Please note that PINE64 SBC is not a "final" product and in general certification is not necessary. However, PINE64 still submit the SBC for FCC, CE, and ROHS certification and obtain the certificates to proof that SBC board is capable on passing the testing. Please note a final commercial product needs to performs its owns testing and obtains its owns certificates.
- ROCK64 FCC Certificate
- ROCK64 CE Certificate
- ROCK64 RoHS Certificate
- Rockchip RK3328 SoC information:
- LPDDR3 (178 Balls) SDRAM:
- eMMC information:
- SPI NOR Flash information:
- Ethernet related info:
- Peripheral related info:
- Enclosure information:
- Remote control button mapping
