ROCK64
ROCK64
ROCK64 is a credit card size 4K60P HDR Media Board Computer powered by Rockchip RK3328 Quad-Core ARM Cortex A53 64-Bit Processor and support up to 4GB 1866MHz LPDDR3 memory. It provides eMMC module socket, MicroSD Card slot, Pi-2 Bus, Pi-P5+ Bus, USB 3.0 and many others peripheral devices interface for makers to integrate with sensors and devices. Various Operating System (OS) are made available by open source community such Android 7.1, Debian, Yocto and many more to come.
ROCK64 Software Images
ROCK64 Ver3
Under 'ROCK64 Software and OS Image Download Section' you will find a complete list of currently supported Operating System images that work with the ROCK64 as well as other related software. The list includes OS images and descriptions of:
ROCK64
Some OS images are still in beta or nightly build which are only fit for testing purposes. These should usually be avoided for normal usage, since they are used at your own risk
State of software support for the hardware
Requirement GNU/Linux Android/Linux Kodi/Linux
2160p 30Hz 8bit h264/h265/vp8 partial? 1 yes yes
UI using GPU no yes ?
Youtube no yes no
vp9 / mpeg4 / mpeg2 / 10bit HDR / YCbCr no yes? no 1
SoC and Memory Specification
  • Based on Rockchip RK3328
  • Unified system L2 cache
  • Integrated 32KB L1 instruction cache, 32KB L1 data cache with 4-way set associative
  • One separate power domains for CPU core system to support internal power switch and externally turn on/off based on different application scenario
GPU Architecture
Board Features
Video
  • 4K HDR @ 60fps
  • VP9, up to 4Kx2K @ 60fps
Audio
Network
  • 10/100/1000Mbps Ethernet
Storage
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
ROCK64 Board Information, Schematics and Certifications
R64V3%20RTC%20Batt%20connector.png ROCK64 Rev3 SBC RTC Battery Connector polarity
Other Resources
