ROCK64
PINE64
Please visit the Main Page for more information about PINE64.
ROCK64
ROCK64 is a credit card size 4K60P HDR Media Board Computer powered by Rockchip RK3328 Quad-Core ARM Cortex A53 64-Bit Processor and support up to 4GB 1866MHz LPDDR3 memory. It provides eMMC module socket, MicroSD Card slot, Pi-2 Bus, Pi-P5+ Bus, USB 3.0 and many others peripheral devices interface for makers to integrate with sensors and devices. Various Operating System (OS) are made available by open source community such Android 7.1, Debian, Yocto and many more to come.
ROCK64 Software Images
Community Build Android TV 7.1 [ver 0.1.8]
Stock Android 7.1 [20170712] Engineering version
  • eMMC zipped image, please unzip first and then using Android tool to flash in
Stock Debian Linux Kernel ver 4.4 [20170705] Engineering version
  • Unzip and DD image to microSD card and boot. Highly recommend using Etcher.
Community Build Xenial Mate Kernel ver 4.4 Pre-release version [ver 0.4.0]
Community Build Xenial i3 Kernel ver 4.4 Pre-release version [ver 0.4.0]
Community Build Arch Linux Preliminary Minimal build Kernel ver 4.4
Community Build Fedora Linux Preliminary Minimal build Kernel ver 4.4
  • Yocto
  • Release soon
SoC and Memory Specification
  • Based on Rockchip RK3328
  • Unified system L2 cache
  • Integrated 32KB L1 instruction cache, 32KB L1 data cache with 4-way set associative
  • One separate power domains for CPU core system to support internal power switch and externally turn on/off based on different application scenario
GPU Architecture
  • Storage Memory: ROCK64 boards do not have built-in Flash memory but use bootable microSD Cards or bootable attachable eMMC.
Board Features
Video
  • HDMI 2.0a output up to 4K@60Hz
  • 4K HDR @ 60fps
  • VP9, up to 4Kx2K @ 60fps
Audio
Network
  • 10/100/1000Mbps Ethernet
Storage
  • 2 USB2.0 Dedicated Host port (one of them is USB-OTG)
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
ROCK64 Board Information and Schematics
Other Resources
