ROCK64
Revision as of 22:42, 28 October 2020 by Fxc (talk | contribs) (wiki style)
ROCK64
ROCK64 is a credit-card size 4K60P HDR Media Board Computer powered by Rockchip RK3328 Quad-Core ARM Cortex A53 64-Bit Processor and supports up to 4GB 1866MHz LPDDR3 memory. It provides an eMMC module socket, MicroSD Card slot, Pi-2 Bus, Pi-P5+ Bus, USB 3.0, and many other peripheral interfaces for makers to integrate with sensors and other devices. Many different Operating Systems (OS) are freely available from the open source community, such as Android 7.1, Debian, and Yocto.
ROCK64 Software Images
ROCK64 Ver3 and Ver2
Under 'ROCK64 Software and OS Image Download Section' you will find a complete list of currently supported Operating System images that work with the ROCK64 as well as other related software. The list includes OS images and descriptions of:
Armbian Debian Buster on mainline Kernel (microSD / eMMC Boot)
Armbian Debian Buster on legacy BSP Kernel (microSD / eMMC Boot)
Bionic Minimal 64bit (microSD /eMMC Boot)
Bionic Minimal Containers (microSD /eMMC Boot)
LibreElec for KODI (microSD / eMMC Boot)
Debian by ayufan (microSD / eMMC Boot)
Debian by mrfixit2001 (microSD / eMMC Boot)
OpenMediaVault 64bit (microSD / eMMC boot)
NextCloudPi(microSD /eMMC Boot)
Slackware(microSD /eMMC Boot)
Recalbox(microSD /eMMC Boot)
Netbsd2.png NetBSD (microSD / eMMC Boot)
Android 9.x (eMMC)
Android 8.x (eMMC) / Android 8.x (microSD Boot)
Android 7.x (eMMC) / Android 7.x (microSD Boot)
Android TV 7.x (eMMC) / Android TV 7.x (microSD Boot)
ROCK64 Ver2 only
Manjaro KDE ARM (microSD /eMMC Boot) / Manjaro LXQT ARM (microSD /eMMC Boot)
Manjaro ARM Minimal (microSD /eMMC Boot)
Cent OS (microSD /eMMC Boot)
DietPi (microSD /eMMC Boot)
Lakka(microSD /eMMC Boot)
NEMS Linux (microSD /eMMC Boot)
Volumio Digital Audio Player (microSD /eMMC Boot)
Fedora (microSD /eMMC Boot)
Yocto
Some OS images are still in beta or nightly build which are only fit for testing purposes. These should usually be avoided for normal usage, since they are used at your own risk
State of software support for the hardware
Requirement GNU/Linux Android/Linux Kodi/Linux
2160p 30Hz 8bit h264/h265/vp8 partial? 1 yes yes
UI using GPU no yes yes
Youtube no yes no
vp9 / mpeg4 / mpeg2 / 10bit HDR / YCbCr no yes? yes
SoC and Memory Specification
  • Based on Rockchip RK3328
  • Unified system L2 cache
  • Integrated 32KB L1 instruction cache, 32KB L1 data cache with 4-way set associative
  • One separate power domains for CPU core system to support internal power switch and externally turn on/off based on different application scenario
GPU Architecture
Board Features
Video
  • 4K HDR @ 60fps
  • VP9, up to 4Kx2K @ 60fps
Audio
Network
  • 10/100/1000Mbps Ethernet
Storage
  • 128Mbit (16MB) on-board SPI flash memory (empty by default) - bootable?
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
ROCK64 Board Information, Schematics and Certifications
https://files.pine64.org/doc/rock64/R64V3%20RTC%20Batt%20connector.png ROCK64 Rev3 SBC RTC Battery Connector polarity
Other Resources
