ROCK64
Revision as of 22:05, 28 April 2022 by Diederik (talk | contribs) (→‎Quick Links to the Source of OS Images Build: Replace outdated LibreELEC links with the official one)
The ROCK64
The ROCK64 is a credit-card size 4K60P HDR Media Board Computer powered by Rockchip RK3328 Quad-Core ARM Cortex A53 64-Bit Processor and supports up to 4GB 1866MHz LPDDR3 memory. It provides an eMMC module socket, MicroSD Card slot, Pi-2 Bus, Pi-P5+ Bus, USB 3.0, and many other peripheral interfaces for makers to integrate with sensors and other devices.
It supports many different open source operating systems, such as Android, Debian, and Yocto.
Software releases
Under ROCK64 Software Releases you will find a complete list of currently supported operating system images, which work with the ROCK64, as well as other related software.
Some OS images are still in beta or nightly build which are only fit for testing purposes. These should usually be avoided for normal usage, since they are used at your own risk.
State of Software Support for the Hardware
Requirement GNU/Linux Android/Linux Kodi/Linux
2160p 30Hz 8bit h264/h265/vp8 partial? 1 yes yes
UI using GPU no yes yes
Youtube no yes no
vp9 / mpeg4 / mpeg2 / 10bit HDR / YCbCr no yes? yes
Upstreaming Status
Video Output Linux Mainline rockchipdrm With mpv, you'll need to specify something like mpv --gpu-context=drm --drm-connector=1.HDMI-A-1 to get it to play back on a VT
3D Acceleration Linux Mainline Upstream Mesa lima Very recent version recommended for the best experience. Has weird glitches on HDMI output in weston.
Video Decode Linux Staging Broken/Not in ffmpeg hantro_vpu and rockchip_vdec, using v4l2-requests Soon to be moved out of staging, ffmpeg patch set seemingly abandoned, does not work on newer kernels. Git branch with commits
Audio Linux Mainline snd_soc_rockchip_*
Power Button Linux Mainline rk805_pwrkey If your PWR switch does nothing unless held, this may need to be loaded manually with modprobe or by putting it in /etc/modules-load.d/
Analog Video Output Needs porting rockchip_drm_tve Definitely needs some cleanup before it'd be ready for mainline, and needs some dt bindings written.
SoC and Memory Specification
  • Unified system L2 cache
  • Includes VFP v3 hardware to support single and double-precision operations
  • Integrated 32KB L1 instruction cache, 32KB 4-way set associative L1 data cache
  • One separate power domain for CPU core system to support internal power switch, and to externally turn on/off based on different application scenario
Frequencies & Voltages
Frequency Voltage
408 MHz 0.950 V
600 MHz 0.950 V
816 MHz 1.000 V
1008 MHz 1.100 V
1200 MHz 1.225 V
1296 MHz 1.300 V
Power Draw
These numbers for power draw have been measured through an USB power monitor (FNB38) while running the stress utility, whereby "cpu" stands for stress --cpu 4 and "vm" stands for stress --vm 4. The former spins on the CPU, the latter stresses the memory. Real workloads are usually a mix of both. The tests were ran through ssh, with nothing besides power and ethernet plugged into the ROCK64
Please keep in mind that under real world usage, many other factors come into play. Having a display connected, running a graphical session, I/O and most importantly the connected USB peripherals can add a lot.
Helpful refresher on the formula for power (W) on DC: power = current × voltage, because the power factor is 1. The ROCK64 runs on 5V, so use that to calculate current if you need to.
Frequency Power cpu Power vm
1296 MHz 2.64 W 2.95 W
1200 MHz 2.32 W 2.69 W
1008 MHz 1.90 W 2.31 W
816 MHz 1.62 W 2.05 W
600 MHz 1.45 W 1.85 W
408 MHz 1.33 W 1.72 W
Idle (no load) 1.10 W
It appears a good upper bound for a headless setup is in the neighbourhood of 3 W, or the energy contained in 0.025 bananas per hour.
GPU Architecture
Board Features
The ROCK64 and a size comparison
Video
  • 4K HDR @ 60fps
  • VP9, up to 4Kx2K @ 60fps
Audio
Network
  • 10/100/1000Mbps Ethernet
Storage
  • microSD - bootable, supports SDHC and SDXC and storage up to 256GB
  • 128Mbit (16MB) on-board SPI flash memory (empty by default) - bootable? Usually accessible as a Linux MTD device at /dev/mtd0
Expansion Ports
All GPIO pins, including UART, operate at 3.3V. (See VCCIO5 in the schematics.)
  • 2x20 pins "Pi2" GPIO Header
ROCK64 Board Information, Schematics and Certifications
Enclosures
The ROCK64 fits in three officially sold cases.
Troubleshooting
HDMI output disconnects as soon as it connects
Some older monitors seemingly can get into a weird state wherein the ROCK64 is unable to establish a proper connection with them. User:CounterPillow has seen this happen on an iiyama ProLite G2773HS connected over HDMI, and an Acer P225HQL connected over an HDMI to DVI adapter. The symptoms usually are that you see the monitor briefly turn on its backlight without displaying a picture, but then immediately either shutting off again or showing a "No Signal" message.
The solution is to completely power down your ROCK64, also removing its power source. Then plug in the monitor, and start up the ROCK64 afterwards. You should now be getting a picture again.
Power button doesn't do anything on a short press (Linux)
Make sure the rk805_pwrkey module is loaded, e.g. with lsmod | grep rk805_pwrkey. If it doesn't show up, do a modprobe rk805_pwrkey as root. To make this persistent, create a 99-rk805_pwrkey.conf in /etc/modules-load.d/ with the content rk805_pwrkey
If it still doesn't work, make sure your init system is actually listening to the button press. With systemd, check /etc/systemd/logind.conf and make sure it's either all commented out (uses defaults) or contains something like HandlePowerKey=poweroff. You can change the short press action by setting HandlePowerKey to one of "ignore", "poweroff", "reboot", "halt", "kexec", "suspend", "hibernate", "hybrid-sleep", "suspend-then-hibernate", or "lock".
Other Resources
