ROCK64
Revision as of 08:43, 2 October 2017 by Pineadmin (talk | contribs)
PINE64
Please visit the Main Page for more information about PINE64.
ROCK64
ROCK64 is a credit card size 4K60P HDR Media Board Computer powered by Rockchip RK3328 Quad-Core ARM Cortex A53 64-Bit Processor and support up to 4GB 1866MHz LPDDR3 memory. It provides eMMC module socket, MicroSD Card slot, Pi-2 Bus, Pi-P5+ Bus, USB 3.0 and many others peripheral devices interface for makers to integrate with sensors and devices. Various Operating System (OS) are made available by open source community such Android 7.1, Debian, Yocto and many more to come.
ROCK64 Software Images
Stock Build Android 7.1.2 [microSD Boot] [20170809] Release version
  • DD image to microSD card and boot. Highly recommend using Etcher.
  • Improvement on HD Audio bitstream output
  • Improvement on 4K HDR playback
  • Optimize SDRAM performance
  • Added support for more LPDDR3 brand
    • MD5 (XZ file): 182D76FB3D6E17A41FDB3EC5A07679D6
    • File Size: 586MB
Stock Build Android 7.1.2 [microSD to eMMC Boot] [20170809] Release version
  • DD image to microSD card. Highly recommend using Etcher.
    • MD5 (XZ file): C19C1B9369F65C1AE4A0485414197564
    • File Size: 547MB
Stock Build Android 7.1.2 [eMMC Boot] [20170809] Release version
  • Please unzip first and then using Android tool to flash in.
    • MD5 (GZip file): 27591E7FF9489CD04CDDBFD8FFDE885F
    • File Size: 726MB
Community Build Android TV 7.1 Release version
Community Build Android TV 7.1 [microSD to eMMC Boot] [v0.3.4-r86] Release version
Stock Build Debian Jessie LXDE Linux Kernel ver 4.4 [microSD Boot] [20170809] Release version
  • Added packages: libreoffice aisleriot build-essential emacs gcc geany gimp git gnome-mines gnome-sudoku htop libpixman-1-dev nano vim
  • Login with
    • username: linaro
    • password: linaro
Community Build Debian Stretch Minimal Linux Kernel ver 4.4 [microSD Boot]
Community Build Debian Jessie Minimal Linux Kernel ver 4.4 [microSD Boot]
Community Build Xenial Mate Linux Kernel ver 4.4 [microSD Boot]
Community Build Xenial Minimal Linux Kernel ver 4.4 [microSD Boot]
Community Build LibreElec KODI Preliminary Alpha build Kernel ver 4.4 [microSD boot]
Community Build Jessie OpenMediaVault Linux Kernel ver 4.4 [microSD Boot]
Community Build Jessie OpenMediaVault Linux Kernel ver 4.4 [microSD to eMMC Boot] [0.5.10-118]
Community Build Xenial i3 Linux Kernel ver 4.4 [microSD Boot]
Community Build Fedora Linux Preliminary Minimal build Kernel ver 4.4 [microSD boot]
  • Release soon
Some OS images are still in beta or nightly build which are only fit for testing purposes. These should usually be avoided for normal usage, since they are used at your own risk.
SoC and Memory Specification
  • Based on Rockchip RK3328
  • Unified system L2 cache
  • Integrated 32KB L1 instruction cache, 32KB L1 data cache with 4-way set associative
  • One separate power domains for CPU core system to support internal power switch and externally turn on/off based on different application scenario
GPU Architecture
Board Features
Video
  • HDMI 2.0a output up to 4K@60Hz
  • 4K HDR @ 60fps
  • VP9, up to 4Kx2K @ 60fps
Audio
Network
  • 10/100/1000Mbps Ethernet
Storage
  • 2 USB2.0 Dedicated Host port (one of them is USB-OTG)
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
ROCK64 Board Information and Schematics
Other Resources
