ROCK64
ROCK64
ROCK64 is a credit-card size 4K60P HDR Media Board Computer powered by Rockchip RK3328 Quad-Core ARM Cortex A53 64-Bit Processor and supports up to 4GB 1866MHz LPDDR3 memory. It provides an eMMC module socket, MicroSD Card slot, Pi-2 Bus, Pi-P5+ Bus, USB 3.0, and many other peripheral interfaces for makers to integrate with sensors and other devices. Many different Operating Systems (OS) are freely available from the open source community, such as Android 7.1, Debian, and Yocto.
ROCK64 Software Images
Under ROCK64 Software Release you will find a complete list of currently supported Operating System images that work with the ROCK64 as well as other related software.
Some OS images are still in beta or nightly build which are only fit for testing purposes. These should usually be avoided for normal usage, since they are used at your own risk
State of Software Support for the Hardware
Requirement GNU/Linux Android/Linux Kodi/Linux
2160p 30Hz 8bit h264/h265/vp8 partial? 1 yes yes
UI using GPU no yes yes
Youtube no yes no
vp9 / mpeg4 / mpeg2 / 10bit HDR / YCbCr no yes? yes
Upstreaming Status
Video Output Linux Mainline rockchipdrm With mpv, you'll need to specify something like mpv --gpu-context=drm --drm-connector=1.HDMI-A-1 to get it to play back on a VT
3D Acceleration Linux Mainline Upstream Mesa lima Very recent version recommended for the best experience
Video Decode Linux Mainline Not in ffmpeg hantro_vpu, using v4l2m2m Moved out of staging in 5.13, ffmpeg patch set seemingly abandoned as no response was made to a patch review in several months. Git branch with commits
Audio Linux Mainline snd_soc_rockchip_*
SoC and Memory Specification
  • Based on Rockchip RK3328
  • Quad-core Cortex-A53 up to 1.5GHz CPU running at 1296 MHz
  • Unified system L2 cache
  • Includes VFP v3 hardware to support single and double-precision operations
  • Integrated 32KB L1 instruction cache, 32KB 4-way set associative L1 data cache
  • One separate power domain for CPU core system to support internal power switch, and to externally turn on/off based on different application scenario
GPU Architecture
Board Features
Video
  • 4K HDR @ 60fps
  • VP9, up to 4Kx2K @ 60fps
Audio
Network
  • 10/100/1000Mbps Ethernet
Storage
  • 128Mbit (16MB) on-board SPI flash memory (empty by default) - bootable?
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
ROCK64 Board Information, Schematics and Certifications
https://files.pine64.org/doc/rock64/R64V3%20RTC%20Batt%20connector.png ROCK64 Rev3 SBC RTC Battery Connector polarity
Other Resources
