ROCK64
PINE64
Please visit the Main Page for more information about PINE64.
ROCK64
ROCK64 is a credit card size 4K60P HDR Media Board Computer powered by Rockchip RK3328 Quad-Core ARM Cortex A53 64-Bit Processor and support up to 4GB 1866MHz LPDDR3 memory. It provides eMMC module socket, MicroSD Card slot, Pi-2 Bus, Pi-P5+ Bus, USB 3.0 and many others peripheral devices interface for makers to integrate with sensors and devices. Various Operating System (OS) are made available by open source community such Android 7.1, Debian, Yocto and many more to come.
ROCK64 Software Images
Stock Android 7.1.2 [microSD Boot] [20170725] Release version
  • Unzip and DD image to microSD card and boot. Highly recommend using Etcher.
  • Improvement on HD Audio bitstream output
Community Build Android TV 7.1.2 [eMMC Boot] [ver 0.1.8] Pre-Release version
Stock Android 7.1.2 [eMMC Boot] [20170804] Release version
  • eMMC zipped image, please unzip first and then using Android tool to flash in
  • Improvement on 4K HDR playback
  • Optimize SDRAM performance
Stock Debian Jessie LXDE Linux Kernel ver 4.4 [microSD Boot] [20170705] Engineering version
Community Build Debian Stretch Minimal Linux Kernel ver 4.4 [microSD Boot] [ver 0.4.16]
Community Build Debian Jessie Minimal Linux Kernel ver 4.4 [microSD Boot] [ver 0.4.16]
Community Build Xenial Mate Linux Kernel ver 4.4 [microSD Boot] [ver 0.4.16]
Community Build Xenial Minimal Linux Kernel ver 4.4 [microSD Boot]
Community Build LibreElec KODI Preliminary Alpha build Kernel ver 4.4 [microSD boot]
Community Build Jessie OpenMediaVault Linux Kernel ver 4.4 [microSD Boot]
Community Build Xenial i3 Linux Kernel ver 4.4 [microSD Boot] [ver 0.4.16]
Community Build Fedora Linux Preliminary Minimal build Kernel ver 4.4
  • Release soon
SoC and Memory Specification
  • Based on Rockchip RK3328
  • Unified system L2 cache
  • Integrated 32KB L1 instruction cache, 32KB L1 data cache with 4-way set associative
  • One separate power domains for CPU core system to support internal power switch and externally turn on/off based on different application scenario
GPU Architecture
Board Features
Video
  • HDMI 2.0a output up to 4K@60Hz
  • 4K HDR @ 60fps
  • VP9, up to 4Kx2K @ 60fps
Audio
Network
  • 10/100/1000Mbps Ethernet
Storage
  • 2 USB2.0 Dedicated Host port (one of them is USB-OTG)
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
ROCK64 Board Information and Schematics
Other Resources
