Quartz64 Development
Revision as of 11:42, 2 June 2021 by CounterPillow (talk | contribs) (→‎Upstreaming Status: Add link to the PCIe patch)
Under Construction!
Overview
Upstreaming Status
Video Output Needs porting rockchipdrm/VOP-v2
3D Acceleration Linux Mainline Upstream Mesa panfrost
Video Decode Linux Staging Not in ffmpeg[1] hantro-vpu, using v4l2-requests Speculative status on this also being hantro, can't find rk35* in drivers/staging/media/
Audio Needs porting snd-soc-rockchip-i2s?
In review[2] rk817-codec Up to V12 now
u-boot Waiting on ATF sources
Device Tree Early rk3568 dts in review
Gigabit Ethernet In review[3] rk3566-gmac
linux-next[4] yt8511-phy
IOMMU In review[5] rockchip-iommu
GPIO In review
pinctrl Linux Mainline
Thermal Regulation In review[6] rockchip-thermal
PCIe In review[7] pcie-dw-rockchip
Power Management In review rockchip-pm-domain
Voltage Control In review[8] rk3568-pmu-io-voltage-domain
SPI Needs a driver
Current Status
The following sections give an overview over the current status of different parts of the board. Some parts are waiting on a driver to be written or ported, others only need various adjustments.
General performance is poor, this is likely due to the AHB bus running slow, and may require some major rework of the clock layout to get to acceptable speeds.
Working
  • eMMC
  • SDMMC0 (SD cards)
  • GMAC (Gigabit Ethernet)
  • USB 2.0
  • SATA 2
  • SATA 3
  • UART
    • UART 0 (Pi-bus)
    • UART 1 (Bluetooth)
    • UART 2 (Pi-bus, debug)
  • Video Decode
    • VP8
Partially Working
  • PCI-Express Controller — everything but devices that need cache coherency (e.g. dGPUs) should work
  • USB 3.0 — at 2.0 speeds only, appears to be due to a PHY configuration issue
Confirmed Broken
  • SDMMC1 (WiFi) -- no signals observed on the signal lines whatsoever
Needs Testing
  • GPU — Need a VOP-v2 DRM driver to get display output
  • Battery
  • Audio — Needs I2S driver
  • E-Paper
  • SPI — Needs a driver
Resources
Repositories
Board/SoC Documentation
Booting
Boot Order
The RK3566 boot ROM will search for a valid ID BLOCK in the following order on the support boot media:
  • SPI NOR flash
  • SPI NAND flash
  • eMMC
  • SD-Card
... if this fails, the boot ROM will initialize the USB0 port and wait for a connection from the Rockchip flash/boot tools.
BSP Image Layout
