Quartz64
Revision as of 09:36, 13 February 2021 by Pfeerick (talk | contribs) (Not yet released!)
The Quartz64 is the most recent Single Board Computer offering from Pine64, scheduled for release in 2021. It is powered by a Rockchip RK3566 Quad-Core ARM Cortex A55 64-Bit Processor with a MALI G-52 GPU.
Key features include a PCIe x2 open ended slot (model A) or m.2 (model B), the use of LPDDR4 RAM.
The Quartz64 is equipped with 2GB, 4GB or 8GB LPDDR4 system memory, and 128Mb SPI boot Flash. There is also an optional eMMC module (up to 128GB) and microSD slot for booting. The board is equipped with 1x USB 3.0 type A Host, 3x USB 2.0 Host, Gigabit Ethernet, GPIO Bus, MiPi DSI interface, eink interface (Model A), eDP interface (model A), touch Panel interface (model A), stereo MiPi CSI interface, as well as many other device interfaces such as UART, SPI, I2C, for makers to integrate with sensors and other peripherals. Many different Operating Systems (OS) are freely available from the open source community, such as Android, Linux (Ubuntu, Debian, Arch), and BSD.
  • TBD
SoC and Memory Specification
  • Quad-core ARM Cortex-A55 CPU
  • AArch32 for full backward compatibility with Armv7
  • Include VFP hardware to support single and double-precision operations
  • Integrated 32KB L1 instruction cache, 32KB L1 data cache
Graphic Process Unit GPU Capability
  • Support OpenGL ES 1.1, 2.0, and 3.2
  • Support Vulkan 1.0 and 1.1
  • Support OpenCL 2.0 Full Profile
  • Support 1600Mpix/s fill rate when 800MHz clock frequency
  • Support 38.4GLOPs when 800MHz clock frequency
Neural Process Unit NPU Capability
  • Neural network acceleration engine with processing performance up to 0.8 TOPS
  • Support integer 8, integer 16 convolution operation
  • Support deep learning frameworks: TensorFlow, TF-lite, Pytorch, Caffe, ONNX, MXNet, Keras, Darknet
  • RAM Memory Variants: 2GB - 8GB LPDDR4.
  • Storage Memory: SPI Flash and optional eMMC module from 16GB up to 128GB
Network
  • 10/100/1000Mbps Ethernet
  • WiFi 802.11 b/g/n;ac with Bluetooth 5.0 (optional on model A, build in on model B)
Storage
  • USB - 2 ports on model B, 3 ports on model A USB 2.0 Host port, 1 USB 3.0 Host port
  • native SATA 2.0 Port (only on model A, share with USB 3.0 host port)
Expansion Ports
  • eDP - 4 lanes of 2.7Gbps, up to 2560x1600@60Hz (only on model A)
  • DSI - Display Serial Interface, 4 lanes MiPi, up to 1440P on model A, 2 lanes MiPi, up to 1080p on model B
  • CSI - CMOS Camera Interface, 4 lanes MiPi up to 8 mega pixel on model A, 2 lanes MiPi up to 5 mega pixel on model B
  • TP - Touch Panel Port, SPI with interrupt on model A
  • VBAT - Lithium Battery Connector with temperature sensor input on model A
  • Wifi/BT Module Header - SDIO 3.0 and UART on model A, build in Wifi/BT Module on model B
  • 2x20 pins "Pi2" GPIO Header on model B, 2x10 pins GPO header on model A
  • PCIe 2x open ended slot on model A, m.2 slot on model B
Quartz64 board Information, Schematics, and Certifications
  • Model "A" Baseboard Dimensions: 133mm x 80mm x 19mm
  • Input Power: DC 12V @ 3A 5.5mmOD/2.1mmID Barrel DC Jack connector
  • Model "B" Baseboard Dimensions: 85mm x 56mm x 18.8mm
  • Input Power: DC 5V @ 3A 3.5mmOD/1.35mmID Barrel DC Jack connector
  • Certification:
    • Not yet available
Android SDK
Android 11 SDK
Other Resources
