Quartz64
Revision as of 01:47, 10 February 2021 by Tllim (talk | contribs)
The SOEdge is a 3TOPS compute module that can be paired with the SOPine base board or USB 3.0 and PCIe adapters for development. It can connect to a SBC, such as the ROCKPro64 or a regular PC.
SOEdge Software Release
  • TBD
SoC and Memory Specification
  • Quad-core ARM Cortex-A55 CPU
  • AArch32 for full backward compatibility with Armv7
  • Include VFP hardware to support single and double-precision operations
  • Integrated 32KB L1 instruction cache, 32KB L1 data cache
Graphic Process Unit GPU Capability
  • Support OpenGL ES 1.1, 2.0, and 3.2
  • Support Vulkan 1.0 and 1.1
  • Support OpenCL 2.0 Full Profile
  • Support 1600Mpix/s fill rate when 800MHz clock frequency
  • Support 38.4GLOPs when 800MHz clock frequency
Neural Process Unit NPU Capability
  • Neural network acceleration engine with processing performance up to 0.8 TOPS
  • Support integer 8, integer 16 convolution operation
  • Support deeplearning frameworks: TensorFlow, TF-lite, Pytorch, Caffe, ONNX, MXNet, Keras, Darknet
  • RAM Memory Variants: 2GB - 8GB LPDDR4.
  • Storage Memory: SPI Flash and optional eMMC module from 16GB up to 128GB
Network
  • 10/100/1000Mbps Ethernet
  • WiFi 802.11 b/g/n;ac with Bluetooth 5.0 (optional on model A)
Storage
  • USB - 2 USB 2.0 Host port, 1 USB 3.0 Host port
  • native SATA 2.0 Port (only on model A, share with USB 3.0 host port)
Expansion Ports
  • eDP - 4 lanes of 2.7Gbps, up to 2560x1600@60Hz (only on model A)
  • DSI - Display Serial Interface, 4 lanes MiPi, up to 1440P on model A, 2 lanes MiPi, up to 1080p on model B
  • CSI - CMOS Camera Interface, 4 lanes MiPi up to 8 mega pixel on model A, 2 lanes MiPi up to 5 mega pixel on model B
  • TP - Touch Panel Port, SPI with interrupt on model A
  • VBAT - Lithium Battery Connector with temperature sensor input on model A
  • Wifi/BT Module Header - SDIO 3.0 and UART on model A, build in Wifi/BT Module on model B
  • 2x20 pins "Pi2" GPIO Header on model B, 2x5 pins GPO header on
  • PCIe 2x open ended slot on model A, m.2 slot on model B
Quartz64 board Information, Schematics, and Certifications
  • Model "A" Baseboard Dimensions: 133mm x 80mm x 19mm
  • Input Power: DC 12V @ 3A 5.5OD/2.1ID Barrel DC Jack connector
SOEdge/SOPine Cluster Board Resource
Other Resources
