Quartz64
Revision as of 01:25, 10 February 2021 by Tllim (talk | contribs)
The SOEdge is a 3TOPS compute module that can be paired with the SOPine base board or USB 3.0 and PCIe adapters for development. It can connect to a SBC, such as the ROCKPro64 or a regular PC.
SOEdge Software Release
  • TBD
SoC and Memory Specification
  • A power-efficient ARM 64-Bit Armv8-A architecture
  • AArch32 for full backward compatibility with Armv7
  • VFPv4 Floating Point Unit
  • TrustZone security technology
  • Neon Advanced SIMD
  • DSP and SIMD extensions
  • VFPv4 Floating point
  • 128KB L2 cache
Graphic Process Unit GPU Capability
  • RAM Memory Variants: 2GB - 8GB LPDDR4.
  • Storage Memory: SPI Flash and optional eMMC module from 16GB up to 128GB
Network
  • 10/100/1000Mbps Ethernet
  • WiFi 802.11 b/g/n;ac with Bluetooth 5.0 (optional on model A)
Storage
  • USB - 2 USB 2.0 Host port, 1 USB 3.0 Host port
  • native SATA 2.0 Port (only on model A, share with USB 3.0 host port)
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
  • PCIe 2x open ended slot
SOEdge Module and Baseboard Information, Schematics, and Certifications
  • Model "A" Baseboard Dimensions: 133mm x 80mm x 19mm
  • Input Power: DC 12V @ 3A 5.5OD/2.1ID Barrel DC Jack connector
SOEdge/SOPine Cluster Board Resource
Other Resources
