Quartz64
Revision as of 23:57, 9 February 2021 by Tllim (talk | contribs) (Created page with "The SOEdge is a 3TOPS compute module that can be paired with the SOPine base board or USB 3.0 and PCIe adapters for development. It can connect to a SBC, such as the ROCKPro64...")
The SOEdge is a 3TOPS compute module that can be paired with the SOPine base board or USB 3.0 and PCIe adapters for development. It can connect to a SBC, such as the ROCKPro64 or a regular PC.
SOEdge Software Release
  • TBD
SoC and Memory Specification
  • Dual-core ARM Cortex-A35 Processor@1600-2000Mhz
  • A power-efficient ARM 64-Bit Armv8-A architecture
  • AArch32 for full backward compatibility with Armv7
  • VFPv4 Floating Point Unit
  • TrustZone security technology
  • Neon Advanced SIMD
  • DSP and SIMD extensions
  • VFPv4 Floating point
  • 128KB L2 cache
Neural Process Unit NPU Capability
  • RAM Memory Variants: 2GB DDR4.
  • Storage Memory: SPI Flash and optional eMMC module from 16GB up to 128GB
SOEdge Baseboard Features
Network
  • 10/100/1000Mbps Etherne
Storage
  • USB - 2 USB2.0 Host port
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
  • PCIe 2x open ended slot
SOEdge Module and Baseboard Information, Schematics, and Certifications
  • Model "A" Baseboard Dimensions: 133mm x 80mm x 19mm
  • Input Power: DC 12V @ 3A 5.5OD/2.1ID Barrel DC Jack connector
SOEdge/SOPine Cluster Board Resource
Other Resources
