Quartz64
Revision as of 01:33, 14 July 2021 by Tllim (talk | contribs)
The Quartz64 is the most recent Single Board Computer offering from Pine64, scheduled for release in 2021. It is powered by a Rockchip RK3566 Quad-Core ARM Cortex A55 64-Bit Processor with a MALI G-52 GPU.
Key features include a PCIe x4 open ended slot (model A) or m.2 (model B) using one Gen2 lane electrically, and the use of LPDDR4 RAM.
The Quartz64 has three LPDDR4 system memory options: 2GB, 4GB or 8GB. For booting, there is a 128Mb SPI boot Flash, an eMMC module socket (supporting up to 128GB) and microSD slot. The board is equipped with 1x USB 3.0 type A Host, 3x USB 2.0 Host, Gigabit Ethernet, SATA (model A), GPIO Bus, MiPi DSI interface, e-ink interface (model A), eDP interface (model A), touch Panel interface (model A), MiPi CSI interface, as well as many other device interfaces such as UART, SPI, I2C, for makers to integrate with sensors and other peripherals. Many different Operating Systems (OS) are freely available from the open source community, such as Linux (Ubuntu, Debian, Arch), BSD, and Android.
  • TBD
SoC and Memory Specifications
  • Supports Vulkan 1.0 and 1.1
NPU (Neural Processing Unit) Capabilities
  • RAM Memory Variants: 2GB, 4GB, 8GB LPDDR4.
  • SPI Flash: 128Mbit / 16MByte
Network
  • 10/100/1000Mbps Ethernet
  • WiFi 802.11 b/g/n/ac with Bluetooth 5.0 (optional on model A, built in on model B)
Storage
  • microSD - bootable, supports SDHC and SDXC, storage up to 2TB
  • USB - 2 ports on model B, 3 ports on model A USB 2.0 Host port, 1 USB 3.0 Host port
  • one native SATA 3.0 6Gb/s Port (only on model A, shared with USB 3.0 host port)
  • optional eMMC module from 16GB up to 128GB
Expansion Ports
  • eDP - 4 lanes of 2.7Gbps, up to 2560x1600@60Hz (only on model A)
  • DSI - Display Serial Interface, 4 lanes MiPi, up to 1440P on model A, 2 lanes MiPi, up to 1080p on model B
  • CSI - CMOS Camera Interface, 4 lanes MiPi up to 8 mega pixel on model A, 2 lanes MiPi up to 5 mega pixel on model B
  • TP - Touch Panel Port, SPI with interrupt on model A
  • VBAT - Lithium Battery Connector with temperature sensor input on model A
  • Wifi/BT Module Header - SDIO 3.0 and UART on model A, build in Wifi/BT Module on model B
  • 2x20 pins "Pi2" GPIO Header on model B, 2x10 pins GPO header on model A
  • PCIe x4 open ended slot on model A, m.2 slot on model B, one Gen2 lane due to SoC constraints
GPIO Pins (Quartz64 Model A)
Attention! GPIOs are 3.3V!
Assigned To Pin Nr. Pin Nr. Assigned To
3.3 V 1 2 5 V
I2C3_SDA_M0 a,b 3 4 5 V
I2C3_SCL_M0 a,b 5 6 GND
CPU_REFCLK_OUT 7 8 UART2_TX_M0_DEBUG
GND 9 10 UART2_RX_M0_DEBUG
SPI1_MOSI_M1 11 12 UART0_TX a
SPI1_MISO_M1 13 14 UART0_RX a
SPI1_CLK_M1 15 16 GND
SPI1_CS0_M1 17 18 SPDIF_OUT c
GND 19 20 3.3V
Notes
  1. can be a PWM pin
  2. pulled high to 3.3V through 2.2kOhm resistor
  3. low-pass filtered with cutoff of 220 MHz
Source: Page 28 of the board schematics.
Quartz64 Board Information, Schematics, and Certifications
  • Model "A" Baseboard Dimensions: 133mm x 80mm x 19mm
  • Input Power: DC 12V @ 3A 5.5mmOD/2.1mmID center-positive Barrel DC Jack connector
  • Model "B" Baseboard Dimensions: 85mm x 56mm x 18.8mm
  • Input Power: DC 5V @ 3A 3.5mmOD/1.35mmID Barrel DC Jack connector
  • Certifications:
    • Disclaimer: Please note that PINE64 SBC is not a "final" product and in general certification is not necessary. However, PINE64 still submit the SBC for FCC and CE certification and obtain the certificates to proof that SBC board is capable on passing the testing. Please note a final commercial product needs to performs its owns testing and obtains its owns certificates.
    • Quartz64 model-A FCC Certificate
    • Quartz64 model-A CE Certificate
Development efforts
Information and resources of the ongoing development effort for the Quartz64 can be found on the Quartz64 Development page, where the current status of various board functions can be found, and whether they have landed in upstream.
Android SDK
Android 11 SDK for Quart64 model A SBC
Android 11 Production Test Build for Quart64 model A SBC
Android 11 Stock Image [eMMC Boot] using DD method [20210604]
  • DD image to eMMC module using USB adapter for eMMC module and boot. Highly recommend using Etcher
  • This is test build that used during product testing
  • DD image for 8GB eMMC module
  • DD image for 16GB eMMC module
  • DD image for 32GB eMMC module
  • DD image for 64GB eMMC module
Android 11 Production Test Build for Quart64 model A SBC [eMMC Boot] using ROCKChip tools method [20210604]
  • Please unzip first and then using Rockchip Android tool ver 2.84 to flash in
  • For Windows OS environment, please install the DriverAssistant v5.11 driver first
  • The OTG port located at top USB 2.0 port on top of USB 3.0 port, needs USB type A to type A cable.
Troubleshooting
Stability/Boot Issues With Missing Battery Shunt
If there is no battery plugged into the board, the jumper labelled "ON/OFF_BATT" must be in place. If this is set wrong, stability issues such as failures to boot will occur.
No Ethernet Connectivity
Make sure the kernel is built with CONFIG_MOTORCOMM_PHY set to y. Building it as a module (m) and then relying on module auto-loading is unlikely to work as the PHY chip lacks its manufacturer ID.
