Project Don't be evil
Revision as of 15:42, 26 April 2019 by Tllim (Talk | contribs)
Jump to: navigation, search
The Project "Don't be evil" - Phase 2 of PINE64 Smartphone "PinePhone" Development Kit
Project Don't be evil is an actual smartphone developer kit for the PINE64 Smartphone dubbed "PinePhone". It is used in the early stages of development as a starting point for affiliated projects. PinePhone development has been broken down into three distinct phases:
  • First phase - Project Anakin
  • Second phase - purpose-built development kit code named "Don't be evil" and introduced at FOSDEM 2019
  • Lastly, the third phase which is the PinePhone itself - scheduled to be prototype released in Q3 2019 and BTO batch released with mobile OS parents in Q4 2019 (pending on software development).
Image: 500 pixels Image: 500 pixels
Project Don't be evil, Baseboard and SOPine Module Information, and Schematics
SoC and Memory Specification
  • Based on Allwinner A64/R18
    • R18 and A64 are identical SoC but R18 committed for 10 years supply by vendor.
  • Quad-core ARM Cortex-A53 [email protected]
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • RAM Memory Variants: 2GB LPDDR3.
  • Storage Memory: SPI Flash and optional eMMC module from 16GB up to 64GB
Postmarket OS Early Alpha test build [microSD Boot] =
  • Suitable for PinePhone "Don't Be Evil" Dev Kit version 1.1 and version 1.2
  • There are two type of LCD panels. For long touch screen cable, please use the build with inverted wording.
UBPorts mainline build
KDE Plasma Mobile build
  • Not Yet Ready *
Sailfish OS build
  • Not Yet Ready *
Maemo Leste build
  • Not Yet Ready *
NixOS build
  • Not Yet Ready *
LuneOS build
  • Not Yet Ready *
Nemo Mobile build
  • Not Yet Ready *
Mali-400 64-bit Driver
Quick Links to Build Sources of OS Images
Some these OS images labelled as beta or nightly builds which means they are only fit for testing purposes
These images should be used at your own risk and are not fit for normal use
Errata for ver1.1 and ver1.2 board
The PinePhone doesn't charge due to VBUS on SOPine module is not connected. Please connect R9688 solder pads with 0 ohm resistor or using thin wire bridge up the solder pads. Location shows as below:
The SOPINE's SPI NOR flash storage and the devkit's camera flash (heh) share the same GPIO pins. The flash storage may not be used.
On the camera flash GPIO conflict, the new assignment of GPIO PB3 pin for SGM3140 FLASH_EN and GPIP PD7 for FLASH_TRIGOUT. Please note that PD7 is also LCD_ID pin which may not be used.
GPIO PB3 location.jpg GPIO PB3 location
U54 SGM3140 FLASH EN pin location.jpg U54 SGM3140 FLASH_EN pin location
Flash GPIO Reassigned.jpg Flash GPIOs Reassigned wiring
Other Resources
