Project Don't be evil
Revision as of 00:18, 24 March 2019 by UniversalSuperBox (talk | contribs)
Contents
The Project "Don't be evil" - Phase 2 of PINE64 Smartphone "PinePhone" Development Kit
Project Don't be evil is an actual smartphone developer kit for the PINE64 Smartphone dubbed "PinePhone". It is used in the early stages of development as a starting point for affiliated projects. PinePhone development has been broken down into three distinct phases:
- First phase - Project Anakin
- Second phase - purpose-built development kit code named "Don't be evil" and introduced at FOSDEM 2019
- Lastly, the third phase which is the PinePhone itself - scheduled to be prototype released in Q3 2019 and BTO batch released with mobile OS parents in Q4 2019 (pending on software development).
Project Don't be evil, Baseboard and SOPine Module Information, and Schematics
- Baseboard Dimensions: 165mm x 76mm x 19.5mm
- Input Power: DC 5V @ 2A, 3.7V Li-Ion battery connector, USB type-C connector
- Baseboard Schematic:
- SOPine Module Schematic:
- Wifi/BT module information:
- PINE A64 Pi-2/Eular/Ext Bus/Wifi Bus Connector Pin Assignment (Updated 15/Feb/2016)
SoC and Memory Specification
- Based on Allwinner A64/R18
- R18 and A64 are identical SoC but R18 committed for 10 years supply by vendor.
- Quad-core ARM Cortex-A53 Processor@1152Mhz
- A power-efficient ARM v8 architecture
- 64 and 32bit execution states for scalable high performance
- Support NEON Advanced SIMD (Single Instruction Multiple Data) instruction for acceleration of media and signal processing function
- Support Large Physical Address Extensions(LPAE)
- VFPv4 Floating Point Unit
- 32KB L1 Instruction cache and 32KB L1 Data cache
- 512KB L2 cache
GPU Architecture
- ARM Mali400MP2 Dual-core GPU
- Support OpenGL ES 2.0 and OpenVG 1.1 standard
- RAM Memory Variants: 2GB LPDDR3.
- Storage Memory: SPI Flash and optional eMMC module from 16GB up to 64GB
- Allwinner A64/R18 SoC information:
- Allwinner A64 SoC Brief Introduction
- Allwinner R18 SoC Brief Introduction
- Allwinner A64/R18 SoC Data Sheet V1.1 (Official Released Version)
- Allwinner A64/R18 SoC User Manual V1.0 (Official Release Version)
- X-Powers AXP803 PMU (Power Management Unit) information:
- LPDDR3 information:
- eMMC information:
- SPI NOR Flash information:
- Project Don't be evil module/component related information:
- 2MPixel front CMOS Camera module information:
- 5MPixel Rear CMOS Camera module information:
- LCD Touch Screen Panel information:
- Lithium Battery information:
- Ethernet PHY information:
- LTE module information:
- Sensors:
UBPorts mainline build
KDE Plasma Mobile build
- Not Yet Ready *
Postmarket OS build
- Not Yet Ready *
Sailfish OS build
- Not Yet Ready *
Maemo OS build
- Not Yet Ready *
NixOS build
- Not Yet Ready *
Mali-400 64-bit Driver
Quick Links to Build Sources of OS Images
Some these OS images labelled as beta or nightly builds which means they are only fit for testing purposes
These images should be used at your own risk and are not fit for normal use
Errata
The SOPINE's SPI NOR flash storage and the devkit's camera flash (heh) share the same GPIO pins. The flash storage may not be used.
