Project Don't be evil
Revision as of 18:03, 22 February 2023 by Fxc (talk | contribs) (Moved to top)
The Project Don't be evil is the phase two of PINE64's smartphone, the PinePhone Development Kit. Project Don't be evil is an actual smartphone developer kit for the PINE64 Smartphone dubbed "PinePhone". It is used in the early stages of development as a starting point for affiliated projects.
The PinePhone development has been broken down into three distinct phases:
  • First phase - Project Anakin
  • Second phase - purpose-built development kit code named "Don't be evil" and introduced at FOSDEM 2019
  • Lastly, the third phase which is the PinePhone itself - scheduled to be prototype released in Q3 2019 and BTO batch released with mobile OS parents in Q4 2019 (pending on software development).
Baseboard and SOPine Module Information, and Schematics
  • Baseboard Dimensions: 165mm x 76mm x 19.5mm
  • Input Power: DC 5V @ 2A, 3.7V Li-Ion battery connector, USB type-C connector
Baseboard Schematic:
SOPine Module Schematic:
Wifi/BT module information:
Pin assignment:
SoC and Memory Specification
Based on the Allwinner A64/R18. The R18 and A64 are identical SoC but R18 committed for 10 years supply by vendor.
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • RAM Memory Variants: 2GB LPDDR3.
  • Storage Memory: SPI Flash and optional eMMC module from 16GB up to 64GB
Allwinner A64/R18 SoC information:
X-Powers AXP803 PMU (Power Management Unit) information:
LPDDR3 information:
eMMC information:
SPI NOR Flash information:
Related datasheets
2MPixel front CMOS Camera module information:
5MPixel Rear CMOS Camera module information:
LCD Touch Screen Panel information:
Lithium Battery information:
Ethernet PHY information:
LTE module information:
Sensors:
Software releases
Some these OS images labelled as beta or nightly builds which means they are only fit for testing purposes. These images should be used at your own risk and are not fit for normal use.
postmarketOS
Download:
Instructions:
Notes:
  • postmarketOS early alpha test build for microSD boot
  • for 8GB microSD cards and above
  • Suitable for PinePhone "Don't Be Evil" Dev Kit version 1.1 and version 1.2
  • There are two type of LCD panels. For long touch screen cable, please use the build with inverted wording.
Sailfish OS
The Sailfish OS image is build on Gitlab CI, the latest image can be installed using our flashing script written in Bash.
The script downloads the image and bootloader from our CI, extracts everything and burns it onto the SD card.
Instructions:
  4. Execute it: ./flash-it.sh
  5. Follow the instructions. Some commands in the script require root permissions (for example: mounting and flashing the SD card).
Notes:
  • The script will format and flash the SD card, make sure that you don't have any important data on the SD card!
Maemo Leste build
Download:
Notes:
  • Works on dev kit versions 1.1 and 1.2
  • Write the image to a micro SD (8GB+) or eMMC
LuneOS build
Download:
Notes:
Mali Driver
For the Mali driver see Mali_Driver.
Errata for ver1.1 and ver1.2 board
1. Please DON'T insert micro SIM card to dev kit board micro SIM card slot, the SIM data, VPP, and GND signal have been misplaced. A miciPCIe adapter with sim card holder 9shown as below photo) will be provide to developers to correct this mistake.
2. The PinePhone dev kit doesn't charge due to VBUS on SOPine module is not connected. Please connect R9688 solder pads with 0 ohm resistor or using thin wire bridge up the solder pads. Location shows as below:
3. The SOPINE's SPI NOR flash storage and the devkit's camera flash (heh) share the same GPIO pins. The flash storage may not be used.
4. On the camera flash GPIO conflict, the new assignment of GPIO PB3 pin for SGM3140 FLASH_EN and GPIP PD7 for FLASH_TRIGOUT. Please note that PD7 is also LCD_ID pin which may not be used.
Images:
Other Resources
